i installed a Virtual Machine with Server 2022 on a ESXI host and Win Server Host and redirect the GPU into the VM, but if i install the driver from NVIDIA the VM crashes… on both systems. this is so annoying.
what is the right way to install a M60 Tesla on a virtual machine?
Thank you.
this is error message from windows log
Der Computer wurde nach einem schwerwiegenden Fehler neu gestartet. Der Fehlercode war: 0x0000007e (0xffffffffc0000005, 0xfffff801e3233711, 0xffffae8a015d3fc8, 0xffffae8a015d37e0). Ein volles Abbild wurde gespeichert in: C:\Windows\MEMORY.DMP. Berichts-ID: 1bcdb36a-d8da-4560-8753-a57e2be7ab5c.
You always need the vGPU driver for WDDM support with Datacenter GPUs. So you will also need to pay for vGPU licenses. vGPU 13.x is also available in the NV licensing portal.
Do you really expect me to suggest how to bypass vGPU licensing?
pls do not get me wrong, i only want to try to install a test station to test some things but nothing works. and direct passtrough is also a option for me but doesnt work because i prefer hyper-v.
where can i buy a vgpu licencing? i need one user. the complete system is not really simple
It should be pretty easy to find the right vGPU version to download. As you already have portal access you already got a 90 days eval for vGPU.
Anyways, the driver install needs to work without the need for a vGPU license. It doesn’t matter if you use DDA or vDGA. Either way should work with M60 and the given guest driver.
GPU is now in Graphic mode, but nothing works and host crashs again (now i installed it on a server 2022 host system to check if the driver work. but driver for datacenter tesla m60 doesnt work… but why? Why have nvidia 2 drivers for one graphic card. i dont understand anything :(
