How can I write an output datafile “file.dat” with more than 3 coluns?
When I use:
open(1,file=“file.dat”,status=“unknown”)
do j=1,nj
do i=1,ni
write(1,*) x,x,x,x,x
end do
end do
The data in the file becames:
x x x
x x
Instead of
x x x x x
Can you help me?
Thanks in advanced
Hi mathe1s,
You’ll need to use an explicit format in your write statement. Something like:
% cat test.f90
program foo
integer,parameter :: ni=5
integer,parameter :: nj=5
integer,parameter :: nk=5
real :: a(ni,nj,5)
integer :: i,j,k
do j=1,nj
do i=1,ni
do k=1,nk
a(i,j,k) = real(k) / (real(i)*real(j))
end do
end do
end do
open(1,file="file.dat",status="unknown")
do j=1,nj
do i=1,ni
write(1,'(5f15.10)'), a(i,j,1), a(i,j,2), a(i,j,3), a(i,j,4), a(i,j,5)
end do
end do
close(1)
end program foo
% pgfortran test.f90; ./a.out
% cat file.dat
1.0000000000 2.0000000000 3.0000000000 4.0000000000 5.0000000000
0.5000000000 1.0000000000 1.5000000000 2.0000000000 2.5000000000
0.3333333433 0.6666666865 1.0000000000 1.3333333731 1.6666666269
0.2500000000 0.5000000000 0.7500000000 1.0000000000 1.2500000000
0.2000000030 0.4000000060 0.6000000238 0.8000000119 1.0000000000
0.1666666716 0.3333333433 0.5000000000 0.6666666865 0.8333333135
0.1250000000 0.2500000000 0.3750000000 0.5000000000 0.6250000000
0.1000000015 0.2000000030 0.3000000119 0.4000000060 0.5000000000
0.1111111119 0.2222222239 0.3333333433 0.4444444478 0.5555555820
0.0833333358 0.1666666716 0.2500000000 0.3333333433 0.4166666567
0.0666666701 0.1333333403 0.2000000030 0.2666666806 0.3333333433
0.0625000000 0.1250000000 0.1875000000 0.2500000000 0.3125000000
0.0500000007 0.1000000015 0.1500000060 0.2000000030 0.2500000000
0.0399999991 0.0799999982 0.1199999973 0.1599999964 0.2000000030
Hope this helps,
Mat
