Make fails with error when trying to configure libcud.a
Sepcs:
- Kernel: 5.15.133.1-microsoft-standard-WSL2
- WSL: 2.0.14
- nvcc on WSL works
➜ ~ nvcc
nvcc fatal : No input files specified; use option --help for more information
- nvcc on windows does not
C:\Windows\System32\lxss\lib>nvcc
'nvcc' is not recognized as an internal or external command,
operable program or batch file.
Symlinks created for libcuda.so and libcuda.so.1
These are added to the path
/usr/local/cuda-12.3/lib64:/usr/local/cuda-12.3/bin:/usr/lib/wsl/lib
nvidia-smi output from WSL
| NVIDIA-SMI 535.129.01 Driver Version: 537.70 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA T1000 On | 00000000:01:00.0 On | N/A |
| 36% 47C P8 N/A / 50W | 1288MiB / 4096MiB | 2% Default |
| | | N/A |
| 1 NVIDIA T1000 On | 00000000:02:00.0 Off | N/A |
| 51% 34C P8 N/A / 50W | 0MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 24 G /Xwayland N/A |
| 1 N/A N/A 24 G /Xwayland N/A |
nvidia-smi output from windows
| NVIDIA-SMI 537.70 Driver Version: 537.70 CUDA Version: 12.2 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA T1000 WDDM | 00000000:01:00.0 On | N/A |
| 36% 46C P8 N/A / 50W | 1257MiB / 4096MiB | 2% Default |
| | | N/A |
| 1 NVIDIA T1000 WDDM | 00000000:02:00.0 Off | N/A |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 6444 C+G ...on\122.0.2365.52\msedgewebview2.exe N/A |
| 0 N/A N/A 7088 C+G C:\Windows\explorer.exe N/A |
| 0 N/A N/A 8568 C+G ...ekyb3d8bbwe\PhoneExperienceHost.exe N/A |
| 0 N/A N/A 9332 C+G ...Programs\Microsoft VS Code\Code.exe N/A |
| 0 N/A N/A 15444 C+G ...2txyewy\StartMenuExperienceHost.exe N/A |
| 0 N/A N/A 15752 C+G ....Search_cw5n1h2txyewy\SearchApp.exe N/A |
| 0 N/A N/A 16792 C+G ...crosoft\Edge\Application\msedge.exe N/A |
| 0 N/A N/A 16956 C+G ...CBS_cw5n1h2txyewy\TextInputHost.exe N/A |
| 0 N/A N/A 19916 C+G ...070_x64__8wekyb3d8bbwe\ms-teams.exe N/A |
| 0 N/A N/A 20220 C+G ...les\Microsoft OneDrive\OneDrive.exe N/A |
| 0 N/A N/A 20768 C+G ...x86)\Jabra\Direct6\jabra-direct.exe N/A |
| 0 N/A N/A 22140 C+G ...siveControlPanel\SystemSettings.exe N/A |
| 0 N/A N/A 26876 C+G ...on\122.0.2365.59\msedgewebview2.exe N/A |
| 0 N/A N/A 27844 C+G ...64__8wekyb3d8bbwe\CalculatorApp.exe N/A |
| 0 N/A N/A 28964 C+G ...5n1h2txyewy\ShellExperienceHost.exe N/A |
| 0 N/A N/A 29588 C+G ...__8wekyb3d8bbwe\WindowsTerminal.exe N/A |
| 0 N/A N/A 32084 C+G ...oogle\Chrome\Application\chrome.exe N/A |
| 0 N/A N/A 38576 C+G ...t.LockApp_cw5n1h2txyewy\LockApp.exe N/A |
| 0 N/A N/A 38740 C+G ...(x86)\Heimdal\Heimdal.ThorAgent.exe N/A |
The error
Copying translator module into output directory
[ 0%] Built target translate
[ 13%] Built target preprocess
[ 13%] Performing configure step for 'libcudd.a'
configure.ac:131: warning: The macro 'AC_TRY_RUN' is obsolete.
configure.ac:131: You should run autoupdate.
./lib/autoconf/general.m4:2995: AC_TRY_RUN is expanded from...
lib/m4sugar/m4sh.m4:690: _AS_IF_ELSE is expanded from...
lib/m4sugar/m4sh.m4:697: AS_IF is expanded from...
./lib/autoconf/general.m4:2249: AC_CACHE_VAL is expanded from...
configure.ac:131: the top level
configure: error: cannot run /bin/bash ./build-aux/config.sub
make[2]: *** [search/CMakeFiles/libcudd.a.dir/build.make:92: /home/bartek/projects/private/GNN-planning-paper/fast-downward-symbolic-optimal-actions/src/search/cudd-3.0.0/src/libcudd.a-stamp/libcudd.a-configure] Error 2
make[1]: *** [CMakeFiles/Makefile2:198: search/CMakeFiles/libcudd.a.dir/all] Error 2
