Hi there,
I just got me a new Laptop, with a GFX1060 Laptop Edition (6GB) in (https://www.mysn.de/schenker-high-performance-notebooks/schenker-h507). I went ahead and installed Arch, since I need the newer Kernels to do power management correctly with the Skylake architecture.
It is a freshly installed system. I just did the basic setup and headed to the Bumblebee Setup (https://wiki.archlinux.org/index.php/bumblebee). Additionally I installed xorg-xinit to get X running.
I figured out, that I could startx, but only as root. So I installed gdm, activated the service and installed some window managers (i3 (preferred), cinnamon and gnome).
The output works fine on my external monitor, but my internal monitor still shows the boot sequence. When I switch tty it is on my internal monitor (http://imgur.com/bTwHI5W for reference).
lspci | grep VGA:
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06)
01:00.0 VGA compatible controller: NVIDIA Corporation GP106M [GeForce GTX 1060] (rev a1)
nvidia-xconfig --query-gpu-info without external monitor:
GPU #0:
Name : GeForce GTX 1060
UUID : GPU-262a6a83-51e8-e4a3-ad46-14dbea0f73ad
PCI BusID : PCI:1:0:0
Number of Display Devices: 0
nvidia-xconfig --query-gpu-info with external monitor:
Number of GPUs: 1
GPU #0:
Number of Display Devices: 1
Display Device 0 (TV-0):
EDID Name : Samsung SyncMaster
Minimum HorizSync : 26.000 kHz
Maximum HorizSync : 68.000 kHz
Minimum VertRefresh : 23 Hz
Maximum VertRefresh : 75 Hz
Maximum PixelClock : 150.000 MHz
Maximum Width : 1920 pixels
Maximum Height : 1080 pixels
Preferred Width : 1680 pixels
Preferred Height : 1050 pixels
Preferred VertRefresh : 60 Hz
Physical Width : 160 mm
Physical Height : 90 mm
nvidia-smi
| NVIDIA-SMI 375.20 Driver Version: 375.20 |
| 0 GeForce GTX 1060 On | 0000:01:00.0 On | N/A |
| N/A 39C P8 6W / N/A | 69MiB / 6104MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 442 G /usr/lib/xorg-server/Xorg 0MiB |
| 0 614 G /usr/lib/xorg-server/Xorg 67MiB |
cat /etc/X11/xinit/xinitrc.d/20-nvidia.sh
#!/bin/bash
xrandr --setprovideroutputsource modesetting NVIDIA-0
xrandr --auto
setxkbmap de
My dmesg: https://paste.kde.org/pobzlnlyc
PS: It is no Hardware-Issue, since I have an external drive with Windows 10, where the displaying works fine.
PPS: I have no additional xorg-config files, only what came with the installation of nvidia and bumblebee.
PPPS: I have Nvidia driver persistance activated
PPPPS: Also some fonts in some programms seem to be f’ed up: http://imgur.com/a/IzGQW
nvidia-bug-report.log.gz (107 KB)
