Could someone be so kind and check the Xavier tegra_chip_id for me ?
/sys/module/tegra_fuse/parameters/tegra_chip_id
Need to update some build scripts before i get my Xavier on monday…
Hi Spawn32, it’s numeric ID is 25 (0x19 in hex). The Xavier chip is also referred to as T194, hence the hex value of 0x19. The other Tegra chips follow a similar scheme.
nvidia@xavier:~$ cat /sys/module/tegra_fuse/parameters/tegra_chip_id
25
Thanks to both of you, nice to be able to prepare stuff before i receive it :)
