I’m working with Xavier NX development kit, but I replaced the original SoM to SoM with 16GB eMMC on it.
I’m tryed to install JetPack 4.5.1 and also JetPack 4.6.
In SDK manager I can choose between Xavier NX and Xavier NX devkit.
I tried to use all 4 scenarios, none of them worked.
After the failure in sdkmanager, I navigated to the newly created Linux_for_Tegra folder and also tried to burn the SoM from there with different configurations, like jetson-xavier-nx-devkit or jetson-xavier-nx-devkit-emms.
The SoM is in recovery mode, each time before the burn process.
Sometimes the burn process succeed, but the board is not able to boot.
According to your previous comment, it sounds like there are 2 issues here.
You firstly said “Sometimes the burn process succeed, but the board is not able to boot.”. Which means the board is able to get flashed but not able to boot.
For the flash issue, please make sure it is not due to micro usb cable or host side, try different host and cables if possible. Also, use other NX device to validate your hardware is also an option.
For the boot issue, the log tells that some partitions on your NX are lost. Which means the flash process is incomplete.
Is the log you just shared from a “successful flashed” case?
The flash process is failed and the log is of the next boot.
Ignore y previously mentioned state that sometimes is succeded.
I can’t burn and I can’t boot the development kit + SoM with 16GB eMMC on it.
Please advise, how I can make it work (without the use of SDCARD).
I got the latest sdkmanager, I got HW. I’m using a PC with Ubuntu 18.04 on it.
How to make it works from a scratch?
Thanks in advance
