Our customized carrier board with NX SOM often shows the following pcie error messages while it is booting. System gets stuck at these error messages without entering Desktop.
[ 3.717805] pcieport 0004:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0000(Requester ID)
[ 3.718075] pcieport 0004:00:00.0: device [10de:1ad1] error status/mask=00004000/00400000
[ 3.718266] pcieport 0004:00:00.0: [14] Completion Timeout (First)
[ 3.718968] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 3.723270] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 3.724046] tegradc 15200000.nvdisplay: hdmi: edid read failed
[ 3.793826] pcieport 0004:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0000(Requester ID)
[ 3.794230] pcieport 0004:00:00.0: device [10de:1ad1] error status/mask=00004000/00400000
[ 3.794492] pcieport 0004:00:00.0: [14] Completion Timeout (First)
[ 3.869799] pcieport 0004:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0000(Requester ID)
[ 3.870234] pcieport 0004:00:00.0: device [10de:1ad1] error status/mask=00004000/00400000
[ 3.870503] pcieport 0004:00:00.0: [14] Completion Timeout (First)
[ 3.953845] pcieport 0004:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0000(Requester ID)
[ 3.954248] pcieport 0004:00:00.0: device [10de:1ad1] error status/mask=00004000/00400000
[ 3.954511] pcieport 0004:00:00.0: [14] Completion Timeout (First)
[ 4.037831] pcieport 0004:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0000(Requester ID)
[ 4.038269] pcieport 0004:00:00.0: device [10de:1ad1] error status/mask=00004000/00400000
[ 4.038539] pcieport 0004:00:00.0: [14] Completion Timeout (First)
[ 4.117863] pcieport 0004:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0000(Requester ID)
[ 4.379118] pcieport 0004:00:00.0: device [10de:1ad1] error status/mask=00004000/00400000
[ 4.423130] pcieport 0004:00:00.0: [14] Completion Timeout (First)
Here is the full boot log:
boot_stuck_pciex1_0323.log (61.1 KB)
According to the “pcieport 0004:00:00.0: PCIe Bus Error” in log, we use a PCIe switch on the PCIE1 bus(Ctrl #4, PCIe x1). We are not sure if this boot failure issue is caused by it.
Could you help advise how to debug this kind of PCIe issue?
