I want to run an XDP program that supports jumbo frames (9k MTU) on a ConnectX-6 card. My program is loaded to the kernel with frags (multi-buffer) support enabled (SEC(“xdp.frags”)), but when rx_striding_rq is enabled all packets passed to the program have data and data_end pointers pointing to the same memory address, so my program doesn’t work correctly.
I’m using MLNX_OFED drivers, version 24.04-0.7.0. The release notes for this version explicitly say support for this feature is present:
- Added XDP multi-buffer support to the default RQ type (Striding RQ)
Steps to reproduce:
- Configure interface to use 9k MTU
- Enable rx_striding_rq (ethtool --set-priv-flags rx_striding_rq on)
- Load XDP program with multi-buffer support enabled (SEC(“xdp.frags”))
If I disable rx_striding_rq, all works fine. I’m using a Ubuntu-provided kernel 6.5.0-35. I also tried with kernel 6.8.0-39 and the problem persists.
I also tried using the in-tree mlx5 driver instead of the one provided by MLNX_OFED. But on both kernels tested, the issue was the same. The program is loaded, but the pointers received by the XDP program are bogus.
I also tried changing the MTU value, and looks like all works fine until MTU 3498. Up from there the problem starts to happen.
Given the performance benefits of using rx_striding_rq, I’d like to run my XDP program with jumbo frame support and rx_striding_rq enabled at the same time. Is it possible? Is this a known driver/kernel bug?
More information about my system:
# cat /etc/os-release
PRETTY_NAME="Ubuntu 22.04.4 LTS"
NAME="Ubuntu"
VERSION_ID="22.04"
VERSION="22.04.4 LTS (Jammy Jellyfish)"
VERSION_CODENAME=jammy
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=jammy
# ethtool -i enp3s0np0
driver: mlx5_core
version: 24.04-0.7.0
firmware-version: 20.32.2004 (DEL0000000013)
expansion-rom-version:
bus-info: 0000:03:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: yes
# uname -a
Linux gr2-sao 6.5.0-35-generic #35~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Tue May 7 09:00:52 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
# lspci -vvvv
03:00.0 Ethernet controller: Mellanox Technologies MT28908 Family [ConnectX-6]
Subsystem: Mellanox Technologies MT28908 Family [ConnectX-6]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 66
NUMA node: 0
Region 0: Memory at 90000000 (64-bit, prefetchable) [size=32M]
Expansion ROM at 94200000 [disabled] [size=1M]
Capabilities: [60] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 25.000W
DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 256 bytes, MaxReadReq 4096 bytes
DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 16GT/s, Width x16, ASPM not supported
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s (downgraded), Width x16 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABC, TimeoutDis+ NROPrPrP- LTR-
10BitTagComp+ 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 65ms to 210ms, TimeoutDis- LTR- OBFF Disabled,
AtomicOpsCtl: ReqEn+
LnkCap2: Supported Link Speeds: 2.5-16GT/s, Crosslink- Retimer+ 2Retimers+ DRS-
LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [48] Vital Product Data
Product Name: Mellanox ConnectX-6 Single Port VPI HDR100 QSFP Adapter
Read-only fields:
[PN] Part number: 07TKND
[EC] Engineering changes: A01
[MN] Manufacture ID: 1028
[SN] Serial number: TW07TKND7873506JT0DW
[VA] Vendor specific: DSV1028VPDR.VER2.1
[VB] Vendor specific: FFV20.32.20.04
[VC] Vendor specific: NPY1
[VD] Vendor specific: PMTD
[VE] Vendor specific: NMVMellanox Technologies, Inc.
[VG] Vendor specific: DCM1001FFFFFF
[VH] Vendor specific: L1D0
[VU] Vendor specific: TW07TKND7873506JT0DWMLNXS0D0F0
[RV] Reserved: checksum good, 3 byte(s) reserved
End
Capabilities: [9c] MSI-X: Enable+ Count=64 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [c0] Vendor Specific Information: Len=18 <?>
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot-,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt+ UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP+ FCP+ CmpltTO+ CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC+ UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr+ BadTLP+ BadDLLP+ Rollover+ Timeout+ AdvNonFatalErr+
AERCap: First Error Pointer: 04, ECRCGenCap+ ECRCGenEn+ ECRCChkCap+ ECRCChkEn+
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 0
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [1c0 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn- PerformEqu-
LaneErrStat: 0
Capabilities: [320 v1] Lane Margining at the Receiver <?>
Capabilities: [370 v1] Physical Layer 16.0 GT/s <?>
Capabilities: [420 v1] Data Link Feature <?>
Kernel driver in use: mlx5_core
Kernel modules: mlx5_core
