XServer fails to start with proprietary driver on Quadro card
I have a ThinkPad W540 with an Intel HD 4600 Graphics and a dedicated Quadro K2100m. The machine is running on linux (Fedora 22 Gnome Desktop), because I prefer linux for developing and because of the shell.
For a school project I need CUDA running, but when I install the NVIDIA drivers the Xserver refuses to start. (Xorg logs in appendix; I see that now the errors are different. They used to be “Could not find screens”)
But in the terminal (when switching with CTRL + ALT + 2) I am now able to run CUDA programs. As I am developing a Java programm that uses CUDA it would be nice though to have a graphical environment to be able to use Intellij.
I also tried this method (optimus with nvidia drivers) with no sucess:
http://negativo17.org/complex-setup-with-nvidia-optimus-nouveau-prime-on-fedora-19-2/
Also that method had no sucess:
http://rpmfusion.org/Howto/nVidia
I installed the 352.41 version of the driver. As soon as I removed the driver (and deleted my custom xorg.conf) the XServer is starting normal again.
On my gaming rig with a GTX 480 the same setup worked like a charm out of the box, so I suspect that the optimus constellation with the Quadro card to be the problem, because I tried similar setups on a T540p (which only difference is that it has a GT730m instead of the K2100m).
I would be fine in just turning off the Intel card as power is no problem. Another possible way would be to disable the NVIDIA card and just use it for CUDA. Anything is fine as long as I have GUI and can run CUDA. I already lost 3 full days to this problem and that with a graphics card that is especially made for “better driver support”. :(
I hope someone can help me with this issue.
/etc/X11/Xorg.conf generated by nvidia-xconfig
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 352.41  (buildmeister@swio-display-x64-rhel04-11)  Sat Aug 22 00:01:10 PDT 2015
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
    FontPath        "/usr/share/fonts/default/Type1"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/input/mice"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
/var/log/Xorg.0.log
[   195.345]
X.Org X Server 1.17.2
Release Date: 2015-06-16
[   195.345] X Protocol Version 11, Revision 0
[   195.345] Build Operating System:  4.0.4-202.fc21.x86_64
[   195.345] Current Operating System: Linux ThinkPadW540.local 4.1.5-200.fc22.x86_64 #1 SMP Mon Aug 10 23:38:23 UTC 2015 x86_64
[   195.345] Kernel command line: BOOT_IMAGE=/vmlinuz-4.1.5-200.fc22.x86_64 root=/dev/mapper/fedora-root ro rd.lvm.lv=fedora/swap rd.luks.uuid=luks-37138645-3389-4176-9138-30ad25ce6b76 rd.lvm.lv=fedora/root nouveau.modeset=0 rd.driver.blacklist=nouveau rhgb quiet
[   195.345] Build Date: 15 July 2015  08:16:41AM
[   195.345] Build ID: xorg-x11-server 1.17.2-2.fc22
[   195.345] Current version of pixman: 0.32.6
[   195.345] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[   195.345] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   195.345] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Sep 26 12:10:56 2015
[   195.345] (==) Using config file: "/etc/X11/xorg.conf"
[   195.345] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   195.345] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   195.345] (==) ServerLayout "layout"
[   195.345] (**) |-->Screen "nvidia" (0)
[   195.345] (**) |   |-->Monitor "<default monitor>"
[   195.345] (**) |   |-->Device "nvidia"
[   195.345] (==) No monitor specified for screen "nvidia".
	Using a default monitor configuration.
[   195.345] (**) |-->Inactive Device "intel"
[   195.345] (==) Automatically adding devices
[   195.345] (==) Automatically enabling devices
[   195.345] (==) Automatically adding GPU devices
[   195.345] (**) FontPath set to:
	/usr/share/fonts/default/Type1,
	catalogue:/etc/X11/fontpath.d,
	built-ins
[   195.345] (==) ModulePath set to "/usr/lib64/xorg/modules"
[   195.345] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[   195.345] (II) Loader magic: 0x81be00
[   195.345] (II) Module ABI versions:
[   195.345] 	X.Org ANSI C Emulation: 0.4
[   195.345] 	X.Org Video Driver: 19.0
[   195.345] 	X.Org XInput driver : 21.1
[   195.345] 	X.Org Server Extension : 9.0
[   195.347] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c505
[   195.347] (II) xfree86: Adding drm device (/dev/dri/card1)
[   195.347] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 9 paused 0
[   195.347] (II) xfree86: Adding drm device (/dev/dri/card0)
[   195.347] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[   195.349] (--) PCI:*(0:0:2:0) 8086:0416:17aa:221e rev 6, Mem @ 0xb1400000/4194304, 0xa0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[   195.349] (--) PCI: (0:1:0:0) 10de:11fc:17aa:221e rev 161, Mem @ 0xb0000000/16777216, 0x80000000/268435456, 0x90000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[   195.349] (II) LoadModule: "glx"
[   195.349] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[   195.354] (II) Module glx: vendor="NVIDIA Corporation"
[   195.354] 	compiled for 4.0.2, module version = 1.0.0
[   195.354] 	Module class: X.Org Server Extension
[   195.354] (II) NVIDIA GLX Module  352.41  Fri Aug 21 22:40:16 PDT 2015
[   195.354] (II) LoadModule: "nvidia"
[   195.354] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[   195.355] (II) Module nvidia: vendor="NVIDIA Corporation"
[   195.355] 	compiled for 4.0.2, module version = 1.0.0
[   195.355] 	Module class: X.Org Video Driver
[   195.355] (II) LoadModule: "intel"
[   195.355] (II) Loading /usr/lib64/xorg/modules/drivers/intel_drv.so
[   195.355] (II) Module intel: vendor="X.Org Foundation"
[   195.355] 	compiled for 1.17.1, module version = 2.99.917
[   195.355] 	ABI class: X.Org Video Driver, version 19.0
[   195.355] (II) NVIDIA dlloader X Driver  352.41  Fri Aug 21 22:14:01 PDT 2015
[   195.355] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[   195.355] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[   195.355] (II) intel: Driver for Intel(R) HD Graphics: 2000-6000
[   195.355] (II) intel: Driver for Intel(R) Iris(TM) Graphics: 5100, 6100
[   195.355] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics: 5200, 6200, P6300
[   195.355] (++) using VT number 1
[   195.355] (II) Loading sub module "fb"
[   195.355] (II) LoadModule: "fb"
[   195.355] (II) Loading /usr/lib64/xorg/modules/libfb.so
[   195.355] (II) Module fb: vendor="X.Org Foundation"
[   195.355] 	compiled for 1.17.2, module version = 1.0.0
[   195.355] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   195.355] (II) Loading sub module "wfb"
[   195.355] (II) LoadModule: "wfb"
[   195.355] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[   195.356] (II) Module wfb: vendor="X.Org Foundation"
[   195.356] 	compiled for 1.17.2, module version = 1.0.0
[   195.356] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   195.356] (II) Loading sub module "ramdac"
[   195.356] (II) LoadModule: "ramdac"
[   195.356] (II) Module "ramdac" already built-in
[   195.356] (II) intel(G0): Using Kernel Mode Setting driver: i915, version 1.6.0 20150327
[   195.356] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"nvidia" for depth/fbbpp 24/32
[   195.356] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[   195.356] (==) NVIDIA(0): RGB weight 888
[   195.356] (==) NVIDIA(0): Default visual is TrueColor
[   195.356] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[   195.356] (**) NVIDIA(0): Option "ConstrainCursor" "no"
[   195.356] (**) NVIDIA(0): Enabling 2D acceleration
[   195.538] (II) NVIDIA: Allocated GPU:0 (GPU-43302000-e069-84ef-4fdf-a74ebec35fba) @
[   195.538] (II) NVIDIA:     PCI:0000:01:00.0
[   195.539] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[   195.539] (--) NVIDIA(0):     DFP-0
[   195.539] (--) NVIDIA(0):     DFP-1
[   195.539] (--) NVIDIA(0): DFP-0: disconnected
[   195.539] (--) NVIDIA(0): DFP-0: Internal TMDS
[   195.539] (--) NVIDIA(0): DFP-0: 165.0 MHz maximum pixel clock
[   195.539] (--) NVIDIA(0): DFP-1: disconnected
[   195.539] (--) NVIDIA(0): DFP-1: Internal DisplayPort
[   195.539] (--) NVIDIA(0): DFP-1: 960.0 MHz maximum pixel clock
[   195.540] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20150116)
[   195.541] (II) NVIDIA(0): NVIDIA GPU Quadro K2100M (GK106GL) at PCI:1:0:0 (GPU-0)
[   195.541] (--) NVIDIA(0): Memory: 2097152 kBytes
[   195.541] (--) NVIDIA(0): VideoBIOS: 80.06.63.00.1a
[   195.541] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[   195.550] (EE) NVIDIA(0): Failed to assign any connected display devices to X screen 0.
[   195.550] (EE) NVIDIA(0):     Set AllowEmptyInitialConfiguration if you want the server
[   195.550] (EE) NVIDIA(0):     to start anyway
[   195.550] (EE) NVIDIA(0): Failing initialization of X screen 0
[   195.557] (II) NVIDIA: Freed GPU:0 (GPU-43302000-e069-84ef-4fdf-a74ebec35fba) @
[   195.557] (II) NVIDIA:     PCI:0000:01:00.0
[   195.572] (II) UnloadModule: "nvidia"
[   195.572] (II) UnloadSubModule: "wfb"
[   195.572] (II) UnloadSubModule: "fb"
[   195.572] (--) intel(G0): Integrated Graphics Chipset: Intel(R) HD Graphics 4600
[   195.572] (--) intel(G0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 4 threads
[   195.572] (==) intel(G0): Depth 24, (--) framebuffer bpp 32
[   195.572] (==) intel(G0): RGB weight 888
[   195.572] (==) intel(G0): Default visual is TrueColor
[   195.572] (II) intel(G0): Output eDP1 has no monitor section
[   195.572] (--) intel(G0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[   195.572] (II) intel(G0): Enabled output eDP1
[   195.572] (II) intel(G0): Output VGA1 has no monitor section
[   195.572] (II) intel(G0): Enabled output VGA1
[   195.572] (II) intel(G0): Output DP1 has no monitor section
[   195.572] (II) intel(G0): Enabled output DP1
[   195.572] (II) intel(G0): Output HDMI1 has no monitor section
[   195.572] (II) intel(G0): Enabled output HDMI1
[   195.572] (II) intel(G0): Output DP2 has no monitor section
[   195.572] (II) intel(G0): Enabled output DP2
[   195.572] (II) intel(G0): Output HDMI2 has no monitor section
[   195.572] (II) intel(G0): Enabled output HDMI2
[   195.572] (II) intel(G0): Output DP2-1 has no monitor section
[   195.572] (II) intel(G0): Enabled output DP2-1
[   195.573] (II) intel(G0): Output DP2-2 has no monitor section
[   195.573] (II) intel(G0): Enabled output DP2-2
[   195.573] (II) intel(G0): Output DP2-3 has no monitor section
[   195.573] (II) intel(G0): Enabled output DP2-3
[   195.573] (--) intel(G0): Using a maximum size of 256x256 for hardware cursors
[   195.573] (II) intel(G0): Output VIRTUAL1 has no monitor section
[   195.573] (II) intel(G0): Enabled output VIRTUAL1
[   195.573] (II) intel(G0): EDID for output eDP1
[   195.573] (II) intel(G0): Manufacturer: MEI  Model: 96a2  Serial#: 0
[   195.573] (II) intel(G0): Year: 2013  Week: 255
[   195.573] (II) intel(G0): EDID Version: 1.4
[   195.573] (II) intel(G0): Digital Display Input
[   195.573] (II) intel(G0): 8 bits per channel
[   195.573] (II) intel(G0): Digital interface is DisplayPort
[   195.573] (II) intel(G0): Max Image Size [cm]: horiz.: 34  vert.: 19
[   195.573] (II) intel(G0): Gamma: 2.20
[   195.573] (II) intel(G0): No DPMS capabilities specified
[   195.573] (II) intel(G0): Supported color encodings: RGB 4:4:4
[   195.573] (II) intel(G0): First detailed timing is preferred mode
[   195.573] (II) intel(G0): Preferred mode is native pixel format and refresh rate
[   195.573] (II) intel(G0): redX: 0.652 redY: 0.329   greenX: 0.324 greenY: 0.600
[   195.573] (II) intel(G0): blueX: 0.150 blueY: 0.045   whiteX: 0.312 whiteY: 0.329
[   195.573] (II) intel(G0): Manufacturer's mask: 0
[   195.573] (II) intel(G0): Supported detailed timing:
[   195.573] (II) intel(G0): clock: 302.5 MHz   Image Size:  340 x 190 mm
[   195.573] (II) intel(G0): h_active: 2880  h_sync: 2924  h_sync_end 2928 h_blank_end 3076 h_border: 0
[   195.573] (II) intel(G0): v_active: 1620  v_sync: 1629  v_sync_end 1630 v_blanking: 1640 v_border: 0
[   195.573] (II) intel(G0): v_active: 1620  v_sync: 1629  v_sync_end 1630 v_blanking: 1967 v_border: 0
[   195.573] (II) intel(G0): Ranges: V min: 49 V max: 61 Hz, H min: 96 H max: 100 kHz, PixClock max 305 MHz
[   195.573] (II) intel(G0):  VVX16T028J00
[   195.573] (II) intel(G0): EDID (in hex):
[   195.573] (II) intel(G0): 	00ffffffffffff0034a9a29600000000
[   195.573] (II) intel(G0): 	ff170104a52213780212a1a754539926
[   195.573] (II) intel(G0): 	0b505400000001010101010101010101
[   195.573] (II) intel(G0): 	0101010101012a7640c4b05414602c04
[   195.573] (II) intel(G0): 	910058c11000001e2a7640c4b0545b61
[   195.573] (II) intel(G0): 	2c04910058c11000001e000000fd0031
[   195.573] (II) intel(G0): 	3d60641e010a202020202020000000fe
[   195.573] (II) intel(G0): 	005656583136543032384a30300a0050
[   195.573] (II) intel(G0): EDID vendor "MEI", prod id 38562
[   195.573] (II) intel(G0):     EDID quirk: Use maximum size instead of detailed timing sizes.
[   195.573] (II) intel(G0): Using EDID range info for horizontal sync
[   195.573] (II) intel(G0): Using EDID range info for vertical refresh
[   195.573] (II) intel(G0): Printing DDC gathered Modelines:
[   195.573] (II) intel(G0): Modeline "2880x1620"x0.0  302.50  2880 2924 2928 3076  1620 1629 1630 1640 +hsync +vsync (98.3 kHz eP)
[   195.573] (II) intel(G0): Modeline "2880x1620"x0.0  302.50  2880 2924 2928 3076  1620 1629 1630 1967 +hsync +vsync (98.3 kHz e)
[   195.573] (II) intel(G0): Not using default mode "320x240" (doublescan mode not supported)
[   195.573] (II) intel(G0): Not using default mode "400x300" (doublescan mode not supported)
[   195.573] (II) intel(G0): Not using default mode "512x384" (doublescan mode not supported)
[   195.573] (II) intel(G0): Not using default mode "640x480" (doublescan mode not supported)
[   195.573] (II) intel(G0): Not using default mode "640x512" (doublescan mode not supported)
[   195.573] (II) intel(G0): Not using default mode "800x600" (doublescan mode not supported)
[   195.573] (II) intel(G0): Not using default mode "896x672" (doublescan mode not supported)
[   195.573] (II) intel(G0): Not using default mode "928x696" (doublescan mode not supported)
[   195.573] (II) intel(G0): Not using default mode "960x720" (doublescan mode not supported)
[   195.573] (II) intel(G0): Not using default mode "700x525" (doublescan mode not supported)
[   195.573] (II) intel(G0): Not using default mode "1024x768" (doublescan mode not supported)
[   195.573] (II) intel(G0): Not using mode "2560x1440" (bad mode clock/interlace/doublescan)
[   195.573] (II) intel(G0): Printing probed modes for output eDP1
[   195.573] (II) intel(G0): Modeline "2880x1620"x60.0  302.50  2880 2924 2928 3076  1620 1629 1630 1640 +hsync +vsync (98.3 kHz eP)
[   195.573] (II) intel(G0): Modeline "2880x1620"x50.0  302.50  2880 2924 2928 3076  1620 1629 1630 1967 +hsync +vsync (98.3 kHz e)
[   195.573] (II) intel(G0): Modeline "2048x1536"x60.0  266.95  2048 2200 2424 2800  1536 1537 1540 1589 -hsync +vsync (95.3 kHz d)
[   195.573] (II) intel(G0): Modeline "1920x1440"x60.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz d)
[   195.573] (II) intel(G0): Modeline "1856x1392"x60.0  218.30  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.4 kHz d)
[   195.573] (II) intel(G0): Modeline "1792x1344"x60.0  204.80  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.7 kHz d)
[   195.573] (II) intel(G0): Modeline "2048x1152"x60.0  197.97  2048 2184 2408 2768  1152 1153 1156 1192 -hsync +vsync (71.5 kHz)
[   195.573] (II) intel(G0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz)
[   195.573] (II) intel(G0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz d)
[   195.573] (II) intel(G0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[   195.573] (II) intel(G0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz)
[   195.573] (II) intel(G0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[   195.573] (II) intel(G0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[   195.573] (II) intel(G0): Modeline "1440x810"x60.0   95.04  1440 1512 1664 1888  810 811 814 839 -hsync +vsync (50.3 kHz)
[   195.573] (II) intel(G0): Modeline "1368x768"x60.0   85.86  1368 1440 1584 1800  768 769 772 795 -hsync +vsync (47.7 kHz)
[   195.573] (II) intel(G0): Modeline "1280x720"x60.0   74.48  1280 1336 1472 1664  720 721 724 746 -hsync +vsync (44.8 kHz)
[   195.573] (II) intel(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[   195.573] (II) intel(G0): Modeline "1024x576"x60.0   46.99  1024 1064 1168 1312  576 577 580 597 -hsync +vsync (35.8 kHz)
[   195.573] (II) intel(G0): Modeline "960x540"x60.0   40.78  960 992 1088 1216  540 541 544 559 -hsync +vsync (33.5 kHz)
[   195.573] (II) intel(G0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[   195.573] (II) intel(G0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[   195.573] (II) intel(G0): Modeline "864x486"x60.0   32.90  864 888 976 1088  486 487 490 504 -hsync +vsync (30.2 kHz)
[   195.573] (II) intel(G0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[   195.573] (II) intel(G0): Modeline "720x405"x60.0   22.18  720 728 800 880  405 406 409 420 -hsync +vsync (25.2 kHz)
[   195.573] (II) intel(G0): Modeline "640x360"x60.0   17.19  640 640 704 768  360 361 364 373 -hsync +vsync (22.4 kHz)
[   195.573] (II) intel(G0): EDID for output DP1
[   195.573] (II) intel(G0): EDID for output DP2
[   195.573] (II) intel(G0): EDID for output DP2-1
[   195.620] (II) intel(G0): EDID for output DP2-2
[   195.620] (II) intel(G0): Manufacturer: ACI  Model: 23c1  Serial#: 16843009
[   195.620] (II) intel(G0): Year: 2013  Week: 10
[   195.620] (II) intel(G0): EDID Version: 1.3
[   195.620] (II) intel(G0): Digital Display Input
[   195.620] (II) intel(G0): Max Image Size [cm]: horiz.: 51  vert.: 29
[   195.620] (II) intel(G0): Gamma: 2.20
[   195.620] (II) intel(G0): DPMS capabilities: StandBy Suspend Off
[   195.620] (II) intel(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[   195.620] (II) intel(G0): First detailed timing is preferred mode
[   195.620] (II) intel(G0): redX: 0.640 redY: 0.333   greenX: 0.312 greenY: 0.626
[   195.620] (II) intel(G0): blueX: 0.153 blueY: 0.070   whiteX: 0.313 whiteY: 0.329
[   195.620] (II) intel(G0): Supported established timings:
[   195.620] (II) intel(G0): 720x400@70Hz
[   195.620] (II) intel(G0): 640x480@60Hz
[   195.620] (II) intel(G0): 640x480@72Hz
[   195.620] (II) intel(G0): 640x480@75Hz
[   195.620] (II) intel(G0): 800x600@56Hz
[   195.620] (II) intel(G0): 800x600@60Hz
[   195.620] (II) intel(G0): 800x600@72Hz
[   195.620] (II) intel(G0): 800x600@75Hz
[   195.620] (II) intel(G0): 1024x768@60Hz
[   195.620] (II) intel(G0): 1024x768@70Hz
[   195.620] (II) intel(G0): 1024x768@75Hz
[   195.620] (II) intel(G0): 1280x1024@75Hz
[   195.620] (II) intel(G0): 1152x864@75Hz
[   195.620] (II) intel(G0): Manufacturer's mask: 0
[   195.620] (II) intel(G0): Supported standard timings:
[   195.620] (II) intel(G0): #0: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[   195.620] (II) intel(G0): #1: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[   195.620] (II) intel(G0): #2: hsize: 1280  vsize 1024  refresh: 75  vid: 36737
[   195.620] (II) intel(G0): #3: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[   195.620] (II) intel(G0): #4: hsize: 1280  vsize 960  refresh: 60  vid: 16513
[   195.620] (II) intel(G0): #5: hsize: 1440  vsize 900  refresh: 60  vid: 149
[   195.620] (II) intel(G0): #6: hsize: 1600  vsize 1200  refresh: 60  vid: 16553
[   195.620] (II) intel(G0): Supported detailed timing:
[   195.620] (II) intel(G0): clock: 148.5 MHz   Image Size:  510 x 290 mm
[   195.620] (II) intel(G0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[   195.620] (II) intel(G0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[   195.620] (II) intel(G0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 83 kHz, PixClock max 155 MHz
[   195.620] (II) intel(G0): Monitor name: VX238
[   195.620] (II) intel(G0): Serial No: D3LMRS000048
[   195.620] (II) intel(G0): clock: 74.2 MHz   Image Size:  510 x 290 mm
[   195.620] (II) intel(G0): v_active: 540  v_sync: 542  v_sync_end 547 v_blanking: 562 v_border: 0
[   195.621] (II) intel(G0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
[   195.621] (II) intel(G0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[   195.621] (II) intel(G0): Supported detailed timing:
[   195.621] (II) intel(G0): clock: 27.0 MHz   Image Size:  510 x 290 mm
[   195.621] (II) intel(G0): h_active: 720  h_sync: 736  h_sync_end 798 h_blank_end 858 h_border: 0
[   195.621] (II) intel(G0): v_active: 480  v_sync: 489  v_sync_end 495 v_blanking: 525 v_border: 0
[   195.621] (II) intel(G0): Number of EDID sections to follow: 1
[   195.621] (II) intel(G0): EDID (in hex):
[   195.621] (II) intel(G0): 	00ffffffffffff000469c12301010101
[   195.621] (II) intel(G0): 	0a17010380331d78eadd45a3554fa027
[   195.621] (II) intel(G0): 	125054afcf80714f8180818fb3008140
[   195.621] (II) intel(G0): 	9500a9400101023a801871382d40582c
[   195.621] (II) intel(G0): 	4500fe221100001e000000fd00384b1e
[   195.621] (II) intel(G0): 	530f000a202020202020000000fc0056
[   195.621] (II) intel(G0): 	583233380a20202020202020000000ff
[   195.621] (II) intel(G0): 	0044334c4d52533030303034380a01c9
[   195.621] (II) intel(G0): 	02031df14a900403011412051f101323
[   195.621] (II) intel(G0): 	0907078301000065030c001000023a80
[   195.621] (II) intel(G0): 	1871382d40582c4500fe221100001e01
[   195.621] (II) intel(G0): 	1d8018711c1620582c2500fe22110000
[   195.621] (II) intel(G0): 	9e011d007251d01e206e285500fe2211
[   195.621] (II) intel(G0): 	00001e8c0ad08a20e02d10103e9600fe
[   195.621] (II) intel(G0): 	22110000180000000000000000000000
[   195.621] (II) intel(G0): 	000000000000000000000000000000e6
[   195.621] (II) intel(G0): Not using mode "1600x1200" (bad mode clock/interlace/doublescan)
[   195.621] (II) intel(G0): Printing probed modes for output DP2-2
[   195.621] (II) intel(G0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[   195.621] (II) intel(G0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   195.621] (II) intel(G0): Modeline "1920x1080"x60.0  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[   195.621] (II) intel(G0): Modeline "1680x1050"x60.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[   195.621] (II) intel(G0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   195.621] (II) intel(G0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   195.621] (II) intel(G0): Modeline "1440x900"x60.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[   195.621] (II) intel(G0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[   195.621] (II) intel(G0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   195.621] (II) intel(G0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   195.621] (II) intel(G0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[   195.621] (II) intel(G0): Modeline "1280x720"x60.0   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   195.621] (II) intel(G0): Modeline "1024x768"x75.0   78.80  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.1 kHz e)
[   195.621] (II) intel(G0): Modeline "1024x768"x70.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   195.621] (II) intel(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   195.621] (II) intel(G0): Modeline "800x600"x72.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   195.621] (II) intel(G0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   195.621] (II) intel(G0): Modeline "800x600"x60.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   195.621] (II) intel(G0): Modeline "800x600"x56.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   195.621] (II) intel(G0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[   195.621] (II) intel(G0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   195.621] (II) intel(G0): Modeline "720x480"x60.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   195.621] (II) intel(G0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   195.621] (II) intel(G0): Modeline "640x480"x73.0   31.50  640 664 704 832  480 489 491 520 -hsync -vsync (37.9 kHz e)
[   195.621] (II) intel(G0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   195.621] (II) intel(G0): Modeline "640x480"x60.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   195.621] (II) intel(G0): Modeline "720x400"x70.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   195.621] (II) intel(G0): EDID for output DP2-3
[   195.629] (II) intel(G0): EDID for output HDMI1
[   195.629] (II) intel(G0): EDID for output HDMI2
[   195.630] (II) intel(G0): EDID for output VGA1
[   195.630] (II) intel(G0): EDID for output VIRTUAL1
[   195.630] (II) intel(G0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[   195.630] (==) intel(G0): TearFree disabled
[   195.630] (**) intel(G0): Display dimensions: (340, 190) mm
[   195.630] (**) intel(G0): DPI set to (76, 102)
[   195.630] (II) Loading sub module "dri2"
[   195.630] (II) LoadModule: "dri2"
[   195.630] (II) Module "dri2" already built-in
[   195.630] (II) Loading sub module "present"
[   195.630] (II) LoadModule: "present"
[   195.630] (II) Module "present" already built-in
[   195.630] (EE) Screen(s) found, but none have a usable configuration.
[   195.630] (EE)
Fatal server error:
[   195.630] (EE) no screens found(EE)
[   195.630] (EE)
Please consult the Fedora Project support
	 at http://wiki.x.org
 for help.
[   195.630] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   195.630] (EE)
[   195.636] (EE) Server terminated with error (1). Closing log file.
/var/log/Xorg.1.log
[  1255.392]
[  1255.399] X Protocol Version 11, Revision 0
[  1255.401] Build Operating System:  4.0.4-202.fc21.x86_64
[  1255.403] Current Operating System: Linux ThinkPadW540.local 4.1.5-200.fc22.x86_64 #1 SMP Mon Aug 10 23:38:23 UTC 2015 x86_64
[  1255.403] Kernel command line: BOOT_IMAGE=/vmlinuz-4.1.5-200.fc22.x86_64 root=/dev/mapper/fedora-root ro rd.lvm.lv=fedora/swap rd.luks.uuid=luks-37138645-3389-4176-9138-30ad25ce6b76 rd.lvm.lv=fedora/root nouveau.modeset=0 rd.driver.blacklist=nouveau rhgb quiet
[  1255.408] Build Date: 15 July 2015  08:16:41AM
[  1255.410] Build ID: xorg-x11-server 1.17.2-2.fc22
[  1255.412] Current version of pixman: 0.32.6
[  1255.417] 	Before reporting problems, check http://wiki.x.org
[  1255.417] Markers: (--) probed, (**) from config file, (==) default setting,
[  1255.426] (==) Log file: "/var/log/Xorg.1.log", Time: Wed Sep 23 11:06:29 2015
[  1255.428] (==) Using config file: "/etc/X11/xorg.conf"
[  1255.430] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  1255.432] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  1255.432] (==) ServerLayout "Layout0"
[  1255.432] (**) |-->Screen "Screen0" (0)
[  1255.432] (**) |   |-->Monitor "Monitor0"
[  1255.432] (**) |   |-->Device "Device0"
[  1255.432] (**) |-->Input Device "Keyboard0"
[  1255.432] (**) |-->Input Device "Mouse0"
[  1255.433] (==) Automatically adding devices
[  1255.433] (==) Automatically enabling devices
[  1255.433] (==) Automatically adding GPU devices
[  1255.433] (**) FontPath set to:
	built-ins
[  1255.433] (==) ModulePath set to "/usr/lib64/xorg/modules"
[  1255.433] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[  1255.433] (WW) Disabling Keyboard0
[  1255.433] (WW) Disabling Mouse0
[  1255.433] (II) Loader magic: 0x81be00
[  1255.433] (II) Module ABI versions:
[  1255.433] 	X.Org ANSI C Emulation: 0.4
[  1255.433] 	X.Org Video Driver: 19.0
[  1255.433] 	X.Org XInput driver : 21.1
[  1255.433] 	X.Org Server Extension : 9.0
[  1255.436] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[  1255.436] (II) xfree86: Adding drm device (/dev/dri/card0)
[  1255.436] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 8 paused 0
[  1255.438] (--) PCI:*(0:0:2:0) 8086:0416:17aa:221e rev 6, Mem @ 0xb1400000/4194304, 0xa0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[  1255.438] (--) PCI: (0:1:0:0) 10de:11fc:17aa:221e rev 161, Mem @ 0xb0000000/16777216, 0x80000000/268435456, 0x90000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[  1255.438] (II) LoadModule: "glx"
[  1255.438] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[  1255.444] (II) Module glx: vendor="NVIDIA Corporation"
[  1255.444] 	compiled for 4.0.2, module version = 1.0.0
[  1255.444] 	Module class: X.Org Server Extension
[  1255.444] (II) NVIDIA GLX Module  352.41  Fri Aug 21 22:40:16 PDT 2015
[  1255.444] (II) LoadModule: "intel"
[  1255.444] (II) Loading /usr/lib64/xorg/modules/drivers/intel_drv.so
[  1255.444] (II) Module intel: vendor="X.Org Foundation"
[  1255.444] 	compiled for 1.17.1, module version = 2.99.917
[  1255.444] 	Module class: X.Org Video Driver
[  1255.444] 	ABI class: X.Org Video Driver, version 19.0
[  1255.444] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
[  1255.444] (II) intel: Driver for Intel(R) HD Graphics: 2000-6000
[  1255.444] (II) intel: Driver for Intel(R) Iris(TM) Graphics: 5100, 6100
[  1255.444] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics: 5200, 6200, P6300
[  1255.444] (++) using VT number 2
[  1255.444] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20150327
[  1255.445] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 4600
[  1255.445] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 4 threads
[  1255.445] (**) intel(0): Depth 24, (--) framebuffer bpp 32
[  1255.445] (==) intel(0): RGB weight 888
[  1255.445] (==) intel(0): Default visual is TrueColor
[  1255.446] (II) intel(0): Output eDP1 using monitor section Monitor0
[  1255.446] (--) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[  1255.446] (II) intel(0): Enabled output eDP1
[  1255.446] (II) intel(0): Output VGA1 has no monitor section
[  1255.446] (II) intel(0): Enabled output VGA1
[  1255.446] (II) intel(0): Output DP1 has no monitor section
[  1255.446] (II) intel(0): Enabled output DP1
[  1255.446] (II) intel(0): Output HDMI1 has no monitor section
[  1255.446] (II) intel(0): Enabled output HDMI1
[  1255.446] (II) intel(0): Output DP2 has no monitor section
[  1255.446] (II) intel(0): Enabled output DP2
[  1255.446] (II) intel(0): Output HDMI2 has no monitor section
[  1255.446] (II) intel(0): Enabled output HDMI2
[  1255.446] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[  1255.446] (II) intel(0): Output VIRTUAL1 has no monitor section
[  1255.446] (II) intel(0): Enabled output VIRTUAL1
[  1255.446] (--) intel(0): Output eDP1 using initial mode 2880x1620 on pipe 0
[  1255.446] (==) intel(0): TearFree disabled
[  1255.446] (==) intel(0): DPI set to (96, 96)
[  1255.446] (II) Loading sub module "dri2"
[  1255.446] (II) LoadModule: "dri2"
[  1255.446] (II) Module "dri2" already built-in
[  1255.446] (II) Loading sub module "present"
[  1255.446] (II) LoadModule: "present"
[  1255.446] (II) Module "present" already built-in
[  1255.446] (==) Depth 24 pixmap format is 32 bpp
[  1255.446] (II) intel(0): SNA initialized with Haswell (gen7.5, gt2) backend
[  1255.446] (==) intel(0): Backing store enabled
[  1255.446] (==) intel(0): Silken mouse enabled
[  1255.446] (II) intel(0): HW Cursor enabled
[  1255.446] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[  1255.446] (**) intel(0): DPMS enabled
[  1255.446] (==) intel(0): Display hotplug detection enabled
[  1255.446] (II) intel(0): [DRI2] Setup complete
[  1255.446] (II) intel(0): [DRI2]   DRI driver: i965
[  1255.446] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[  1255.446] (II) intel(0): direct rendering: DRI2 enabled
[  1255.446] (II) intel(0): hardware support for Present enabled
[  1255.446] (--) RandR disabled
[  1255.449] (II) SELinux: Disabled by boolean
[  1255.449] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
[  1255.453] (II) intel(0): switch to mode 2880x1620@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[  1255.453] (II) intel(0): Setting screen physical size to 762 x 428
[  1255.468] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[  1255.468] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[  1255.468] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  1255.468] (**) Power Button: Applying InputClass "system-keyboard"
[  1255.468] (II) LoadModule: "libinput"
[  1255.468] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[  1255.468] (II) Module libinput: vendor="X.Org Foundation"
[  1255.468] 	compiled for 1.17.2, module version = 0.13.0
[  1255.468] 	Module class: X.Org XInput Driver
[  1255.468] 	ABI class: X.Org XInput driver, version 21.1
[  1255.469] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 15 paused 0
[  1255.469] (II) Using input driver 'libinput' for 'Power Button'
[  1255.469] (**) Power Button: always reports core events
[  1255.469] (**) Option "Device" "/dev/input/event2"
[  1255.469] (II) input device 'Power Button', /dev/input/event2 is tagged by udev as: Keyboard
[  1255.469] (II) input device 'Power Button', /dev/input/event2 is a keyboard
[  1255.469] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[  1255.469] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[  1255.469] (**) Option "xkb_layout" "us,us,at"
[  1255.469] (**) Option "xkb_variant" "intl,,"
[  1255.481] (II) input device 'Power Button', /dev/input/event2 is tagged by udev as: Keyboard
[  1255.481] (II) input device 'Power Button', /dev/input/event2 is a keyboard
[  1255.481] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[  1255.481] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[  1255.481] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[  1255.481] (**) Video Bus: Applying InputClass "system-keyboard"
[  1255.482] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 18 paused 0
[  1255.482] (II) Using input driver 'libinput' for 'Video Bus'
[  1255.482] (**) Video Bus: always reports core events
[  1255.482] (**) Option "Device" "/dev/input/event5"
[  1255.482] (II) input device 'Video Bus', /dev/input/event5 is tagged by udev as: Keyboard
[  1255.482] (II) input device 'Video Bus', /dev/input/event5 is a keyboard
[  1255.482] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7/event5"
[  1255.482] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[  1255.482] (**) Option "xkb_layout" "us,us,at"
[  1255.482] (**) Option "xkb_variant" "intl,,"
[  1255.482] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[  1255.483] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[  1255.483] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[  1255.483] (**) Video Bus: Applying InputClass "system-keyboard"
[  1255.483] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 19 paused 0
[  1255.483] (II) Using input driver 'libinput' for 'Video Bus'
[  1255.483] (**) Video Bus: always reports core events
[  1255.483] (**) Option "Device" "/dev/input/event6"
[  1255.483] (II) input device 'Video Bus', /dev/input/event6 is tagged by udev as: Keyboard
[  1255.483] (II) input device 'Video Bus', /dev/input/event6 is a keyboard
[  1255.483] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/LNXVIDEO:01/input/input8/event6"
[  1255.483] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[  1255.483] (**) Option "xkb_layout" "us,us,at"
[  1255.483] (**) Option "xkb_variant" "intl,,"
[  1255.484] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[  1255.484] (II) No input driver specified, ignoring this device.
[  1255.484] (II) This device may have been added with another device file.
[  1255.484] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[  1255.484] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[  1255.484] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[  1255.484] (**) Sleep Button: Applying InputClass "system-keyboard"
[  1255.484] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 20 paused 0
[  1255.484] (II) Using input driver 'libinput' for 'Sleep Button'
[  1255.484] (**) Sleep Button: always reports core events
[  1255.484] (**) Option "Device" "/dev/input/event1"
[  1255.484] (II) input device 'Sleep Button', /dev/input/event1 is tagged by udev as: Keyboard
[  1255.484] (II) input device 'Sleep Button', /dev/input/event1 is a keyboard
[  1255.484] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[  1255.484] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[  1255.484] (**) Option "xkb_layout" "us,us,at"
[  1255.484] (**) Option "xkb_variant" "intl,,"
[  1255.485] (II) input device 'Sleep Button', /dev/input/event1 is tagged by udev as: Keyboard
[  1255.485] (II) input device 'Sleep Button', /dev/input/event1 is a keyboard
[  1255.485] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event9)
[  1255.485] (II) No input driver specified, ignoring this device.
[  1255.485] (II) This device may have been added with another device file.
[  1255.485] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event10)
[  1255.485] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event11)
[  1255.485] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event12)
[  1255.486] (II) No input driver specified, ignoring this device.
[  1255.486] (II) This device may have been added with another device file.
[  1255.486] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event13)
[  1255.486] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[  1255.486] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[  1255.486] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[  1255.486] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[  1255.486] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 21 paused 0
[  1255.486] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[  1255.486] (**) AT Translated Set 2 keyboard: always reports core events
[  1255.486] (**) Option "Device" "/dev/input/event3"
[  1255.486] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event3 is tagged by udev as: Keyboard
[  1255.486] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event3 is a keyboard
[  1255.486] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[  1255.486] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[  1255.486] (**) Option "xkb_layout" "us,us,at"
[  1255.486] (**) Option "xkb_variant" "intl,,"
[  1255.487] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event4)
[  1255.487] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[  1255.487] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[  1255.487] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Default clickpad buttons"
[  1255.487] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Lenovo TrackPoint top software buttons"
[  1255.487] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[  1255.487] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 22 paused 0
[  1255.487] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[  1255.487] (**) SynPS/2 Synaptics TouchPad: always reports core events
[  1255.487] (**) Option "Device" "/dev/input/event4"
[  1255.487] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event4 is tagged by udev as: Touchpad
[  1255.487] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event4 is a touchpad
[  1255.487] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input5/event4"
[  1255.487] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 11)
[  1255.487] (**) Option "AccelerationScheme" "none"
[  1255.487] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[  1255.487] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[  1255.487] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[  1255.488] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event4 is tagged by udev as: Touchpad
[  1255.488] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event4 is a touchpad
[  1255.488] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[  1255.488] (II) No input driver specified, ignoring this device.
[  1255.488] (II) This device may have been added with another device file.
[  1255.488] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/event7)
[  1255.488] (**) TPPS/2 IBM TrackPoint: Applying InputClass "evdev pointer catchall"
[  1255.488] (**) TPPS/2 IBM TrackPoint: Applying InputClass "libinput pointer catchall"
[  1255.488] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 23 paused 0
[  1255.488] (II) Using input driver 'libinput' for 'TPPS/2 IBM TrackPoint'
[  1255.488] (**) TPPS/2 IBM TrackPoint: always reports core events
[  1255.488] (**) Option "Device" "/dev/input/event7"
[  1255.488] (II) input device 'TPPS/2 IBM TrackPoint', /dev/input/event7 is tagged by udev as: Mouse
[  1255.488] (II) input device 'TPPS/2 IBM TrackPoint', /dev/input/event7 is a pointer caps
[  1255.488] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/serio2/input/input6/event7"
[  1255.488] (II) XINPUT: Adding extended input device "TPPS/2 IBM TrackPoint" (type: MOUSE, id 12)
[  1255.489] (**) Option "AccelerationScheme" "none"
[  1255.489] (**) TPPS/2 IBM TrackPoint: (accel) selected scheme none/0
[  1255.489] (**) TPPS/2 IBM TrackPoint: (accel) acceleration factor: 2.000
[  1255.489] (**) TPPS/2 IBM TrackPoint: (accel) acceleration threshold: 4
[  1255.489] (II) input device 'TPPS/2 IBM TrackPoint', /dev/input/event7 is tagged by udev as: Mouse
[  1255.489] (II) input device 'TPPS/2 IBM TrackPoint', /dev/input/event7 is a pointer caps
[  1255.489] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/mouse1)
[  1255.489] (II) No input driver specified, ignoring this device.
[  1255.489] (II) This device may have been added with another device file.
[  1255.489] (II) config/udev: Adding input device ThinkPad Extra Buttons (/dev/input/event8)
[  1255.489] (**) ThinkPad Extra Buttons: Applying InputClass "evdev keyboard catchall"
[  1255.489] (**) ThinkPad Extra Buttons: Applying InputClass "libinput keyboard catchall"
[  1255.489] (**) ThinkPad Extra Buttons: Applying InputClass "system-keyboard"
[  1255.490] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 24 paused 0
[  1255.490] (II) Using input driver 'libinput' for 'ThinkPad Extra Buttons'
[  1255.490] (**) ThinkPad Extra Buttons: always reports core events
[  1255.490] (**) Option "Device" "/dev/input/event8"
[  1255.490] (II) input device 'ThinkPad Extra Buttons', /dev/input/event8 is tagged by udev as: Keyboard
[  1255.490] (II) input device 'ThinkPad Extra Buttons', /dev/input/event8 is a keyboard
[  1255.490] (**) Option "config_info" "udev:/sys/devices/platform/thinkpad_acpi/input/input9/event8"
[  1255.490] (II) XINPUT: Adding extended input device "ThinkPad Extra Buttons" (type: KEYBOARD, id 13)
[  1255.490] (**) Option "xkb_layout" "us,us,at"
[  1255.490] (**) Option "xkb_variant" "intl,,"
[  1255.590] (II) intel(0): EDID vendor "MEI", prod id 38562
[  1255.590] (II) intel(0):     EDID quirk: Use maximum size instead of detailed timing sizes.
[  1255.590] (II) intel(0): Using hsync ranges from config file
[  1255.590] (II) intel(0): Using vrefresh ranges from config file
[  1255.590] (II) intel(0): Printing DDC gathered Modelines:
[  1255.590] (II) intel(0): Modeline "2880x1620"x0.0  302.50  2880 2924 2928 3076  1620 1629 1630 1640 +hsync +vsync (98.3 kHz eP)
[  1255.590] (II) intel(0): Modeline "2880x1620"x0.0  302.50  2880 2924 2928 3076  1620 1629 1630 1967 +hsync +vsync (98.3 kHz e)
[  1256.116] (II) intel(0): switch to mode 864x486@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[  1257.207] (II) intel(0): resizing framebuffer to 864x486
[  1264.962] (**) Option "fd" "15"
[  1264.962] (**) Option "fd" "18"
[  1264.962] (**) Option "fd" "19"
[  1264.962] (**) Option "fd" "20"
[  1264.962] (**) Option "fd" "21"
[  1264.962] (**) Option "fd" "22"
[  1264.962] (**) Option "fd" "23"
[  1264.962] (**) Option "fd" "24"
[  1266.058] (II) systemd-logind: got pause for 226:0
[  1266.058] (II) systemd-logind: got pause for 13:67
[  1266.058] (II) systemd-logind: got pause for 13:69
[  1266.058] (II) systemd-logind: got pause for 13:71
[  1266.058] (II) systemd-logind: got pause for 13:66
[  1266.058] (II) systemd-logind: got pause for 13:72
[  1266.058] (II) systemd-logind: got pause for 13:70
[  1266.058] (II) systemd-logind: got pause for 13:65
[  1266.058] (II) systemd-logind: got pause for 13:68
[  1266.947] (II) UnloadModule: "libinput"
[  1266.947] (II) systemd-logind: releasing fd for 13:72
[  1266.958] (II) UnloadModule: "libinput"
[  1266.958] (II) systemd-logind: releasing fd for 13:71
[  1266.982] (II) UnloadModule: "libinput"
[  1266.982] (II) systemd-logind: releasing fd for 13:68
[  1267.006] (II) UnloadModule: "libinput"
[  1267.006] (II) systemd-logind: releasing fd for 13:67
[  1267.038] (II) UnloadModule: "libinput"
[  1267.038] (II) systemd-logind: releasing fd for 13:65
[  1267.047] (II) UnloadModule: "libinput"
[  1267.047] (II) systemd-logind: releasing fd for 13:70
[  1267.053] (II) UnloadModule: "libinput"
[  1267.053] (II) systemd-logind: releasing fd for 13:69
[  1267.059] (II) UnloadModule: "libinput"
[  1267.059] (II) systemd-logind: releasing fd for 13:66
[  1267.279] (II) Server terminated successfully (0). Closing log file.
  1. Get your laptop running the way you want with intel graphics. This doesn’t have anything to do with NVIDIA GPU, but make sure you have an xorg.conf that correctly selects the intel graphics, perhaps by specifying the PCI bus ID of the intel graphics in the xorg.conf file. The point is that you want the xorg.conf to identify the intel graphics and you don’t want any X auto-selection to be going on.
  2. Install the nvidia driver only, and specify the correct command line switch to not install the opengl libs (use --help on the installer command line to learn about command line switches). If prompted to modify the xorg.conf, select no. You can get the driver only by downloading an installer from www.nvidia.com for your NVIDIA GPU, or else by extracting the driver runfile installer from the cuda toolkit runfile installer, using a command line switch to do so on the cuda runfile installer command line (use --help to learn about command line switches available).
  3. Then install the remainder of CUDA using the runfile installer method, while selecting “no” if prompted to install the driver.
Depending on the current state of your laptop and the history of things you have done to it during previous attempts, it may be easiest/best if you start step 1 with a clean reload of the OS. Also note that there is no mention or use of the package manager/repo method of installing anything above.
CUDA install manual for linux is here:
http://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html#abstract
I would strongly recommend you disable the nouveau driver according to the steps given in that manual, before installing the NVIDIA GPU driver. It’s not sufficient to just blacklist, you need to blacklist and remove the nouveau driver from the initrd image.
This method should put your laptop into a state where the GUI is working on the intel graphics, and the NVIDIA GPU is available for CUDA activities. CUDA/OpenGL interop and the associated sample codes will not work using this method.
Thank you very much. That solved my proglem.
Sorry for not mentioning the package manager. With Fedora 22 its dnf and I installed the driver using the runfile, because that method proved reliable the last few times, and nvidia drivers are not easily available via repos on all distros.
I did the following:
  1. create a file /etx/X11/xorg.conf.d/01-intel.conf
Section "Monitor"
EndSection
Section "Device"
    Identifier             "Intel"
    Driver                 "intel"
    BusID		   "PCI:0:2:0"
EndSection
Section "Screen"
    Device                 "Intel"
    Monitor                "Monitor0"
    DefaultDepth           24 #Choose the depth (16||24)
EndSection
  1. create the file /etc/modprobe.d/blacklist.conf
blacklist nouveau
3a. blacklist nouveau in /etc/default/grub (I have that done already before)
  1. uninstalled nouveau
dnf remove xorg-x11-drv-nouveau.x86_64
  1. generated a new initrd image and set target to multi-user (runlevel 3)
mv /boot/initramfs-$(uname -r).img /boot/initramfs-$(uname -r)-nouveau.img
dracut /boot/intirams-$(uname -r).img $(uname -r)
systemctl set-default multi-user.target
From this tutorial:
https://ask.fedoraproject.org/en/question/66187/how-to-disable-nouveau-and-install-nvidia/
  1. reboot and login in shell
  2. install nvidia driver
./NVIDIA-[version].run -a -e --no-opengl-files
and declined for the xconfig
  1. set runlevel to graphical again
systemctl set-default graphical.target
  1. reboot and i worked
Note: I had already installed the CUDA toolkit before and there were no issues when changing drivers.
I almost had this solution once, except I have not used the option --no-opengl-files and I think I let nvidia mess around with the xconfig.
I still think it is strange that I had this issues with a Quadro card and never experienced such problems with the “cheap” consumer cards. Of course I know that Linux usually has better support for common hardware, but with Quadro cards you especially pay for that support.
Anyway it works fine now. Again thank you.
