I got a Tonfang chasis laptop and I installed tuxedo-control-center for having some control over fans and also the power management. Also, I have picked the built-in graphics but right now I cannot go back to the hybrid or nvidia graphics.
When I run nvidia-smi I got;
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver > is installed and running.
For the nvidia-settings command;
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
(nvidia-settings:5547): GLib-GObject-CRITICAL **: 00:58:22.942: g_object_unref: assertion ‘G_IS_OBJECT (object)’ >failed
** Message: 00:58:22.948: PRIME: No offloading required. Abort
** Message: 00:58:22.948: PRIME: is it supported? no
Also I found a cd /lib/modprobe.d/blacklist-nvidia.conf. If I delete this will I be able to switch between my builtin amd gpu and nvidia?
nvidia-bug-report.log.gz (77.0 KB)
