• Hardware Platform (Jetson / GPU) RTX 2060 Super
• DeepStream Version 5.0
• TensorRT Version 7.0.0.11
• NVIDIA GPU Driver Version (valid for GPU only) 455
• Issue Type( questions, new requirements, bugs) bug
You can reproduce issue by running the deepstream_imagedata-multistream.py script using custom yolo on more than one video (more than one stream)
I am trying to run deepstream_imagedata-multistream.py using custom yolo, It works fine and everything on one video/stream but it crashes on more than one, producing the following errors, this is the output log:
/usr/bin/python3.6 /opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/DeepstreamDeploy_AccidentDetection/deepstream_imagedata-multistream.py file:/home/mina-abdelmassih/deepstream/accident_video_1.264 file:/home/mina-abdelmassih/deepstream/accident_video_1.264 frame
Frames will be saved in frame
Creating Pipeline
Creating streamux
Creating source bin
source-bin-00
Creating source bin
source-bin-01
Creating Pgie
Creating nvvidconv1
Creating filter1
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
WARNING: Overriding infer-config batch-size 1 with number of sources 2
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing...
1 : file:/home/mina-abdelmassih/deepstream/accident_video_1.264
2 : file:/home/mina-abdelmassih/deepstream/accident_video_1.264
Starting pipeline
Warn: 'threshold' parameter has been deprecated. Use 'pre-cluster-threshold' instead.
WARNING: ../nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input 3x608x608
1 OUTPUT kFLOAT boxes 22743x1x4
2 OUTPUT kFLOAT confs 22743x12
Exiting app
0:00:01.689575040 2137 0x1205b320 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/DeepstreamDeploy_AccidentDetection/yolov4_finetune.engine
0:00:01.689606509 2137 0x1205b320 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1642> [UID = 1]: Backend has maxBatchSize 1 whereas 2 has been requested
0:00:01.689611238 2137 0x1205b320 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1813> [UID = 1]: deserialized backend context :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/DeepstreamDeploy_AccidentDetection/yolov4_finetune.engine failed to match config params, trying rebuild
0:00:01.691055706 2137 0x1205b320 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
Yolo type is not defined from config file name:
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:797 Failed to create network using custom network creation function
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:862 Failed to get cuda engine from custom library API
0:00:01.691269825 2137 0x1205b320 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1735> [UID = 1]: build engine file failed
0:00:01.691276918 2137 0x1205b320 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1821> [UID = 1]: build backend context failed
0:00:01.691280582 2137 0x1205b320 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1148> [UID = 1]: generate backend failed, check config file settings
0:00:01.691401198 2137 0x1205b320 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<primary-inference> error: Failed to create NvDsInferContext instance
0:00:01.691404461 2137 0x1205b320 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<primary-inference> error: Config file path: dstest_imagedata_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): gstnvinfer.cpp(809): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
Process finished with exit code 0
This is also the configuration file:
# Copyright (c) 2018-2020, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
# Following properties are mandatory when engine files are not specified:
# int8-calib-file(Only in INT8)
# Caffemodel mandatory properties: model-file, proto-file, output-blob-names
# UFF: uff-file, input-dims, uff-input-blob-name, output-blob-names
# ONNX: onnx-file
# Mandatory properties for detectors:
# num-detected-classes
# Optional properties for detectors:
# cluster-mode(Default=Group Rectangles), interval(Primary mode only, Default=0)
# custom-lib-path
# parse-bbox-func-name
# Mandatory properties for classifiers:
# classifier-threshold, is-classifier
# Optional properties for classifiers:
# classifier-async-mode(Secondary mode only, Default=false)
# Optional properties in secondary mode:
# operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
# input-object-min-width, input-object-min-height, input-object-max-width,
# input-object-max-height
# Following properties are always recommended:
# batch-size(Default=1)
# Other optional properties:
# net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
# model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
# mean-file, gie-unique-id(Default=0), offsets, process-mode (Default=1 i.e. primary),
# custom-lib-path, network-mode(Default=0 i.e FP32)
# The values in the config file are overridden by values set through GObject
# properties.
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
# model-file=../../../../samples/models/Primary_Detector/resnet10.caffemodel
# proto-file=../../../../samples/models/Primary_Detector/resnet10.prototxt
model-engine-file=yolov4_finetune.engine
labelfile-path=labels_finetune.txt
# int8-calib-file=../../../../samples/models/Primary_Detector/cal_trt.bin
force-implicit-batch-dim=1
batch-size=1
process-mode=1
model-color-format=0
network-mode=2
num-detected-classes=12
interval=0
gie-unique-id=1
output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
engine-create-func-name=NvDsInferYoloCudaEngineGet
parse-bbox-func-name=NvDsInferParseCustomYoloV4
custom-lib-path=libnvdsinfer_custom_impl_YoloV4_12classes_carTruckBus.so
## 0=Group Rectangles, 1=DBSCAN, 2=NMS, 3 = None(No clustering)
cluster-mode=1
[class-attrs-all]
threshold=0.2
eps=0.7
minBoxes=1
#Use the config params below for dbscan clustering mode
[class-attrs-all]
detected-min-w=4
detected-min-h=4
minBoxes=3
Also, It works fine with multiple streams using the default parameters in the configuration file.
