0:00:01.286246719 2967031 0x2dbd760 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.1/deepstream_python_apps/apps/deepstream-rtsp-in-rtsp-out/yolo.engine
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input 3x512x512
1 OUTPUT kFLOAT boxes 3840x1x4
2 OUTPUT kFLOAT confs 3840x6
ERROR: [TRT]: 3: Cannot find binding of given name: BatchedNMS
0:00:01.315672932 2967031 0x2dbd760 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1876> [UID = 1]: Could not find output layer ‘BatchedNMS’ in engine
0:00:01.315775074 2967031 0x2dbd760 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.1/deepstream_python_apps/apps/deepstream-rtsp-in-rtsp-out/yolo.engine
0:00:01.321222578 2967031 0x2dbd760 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:yolo_config.txt sucessfully
Decodebin child added: source
Decodebin child added: decodebin0
Decodebin child added: rtph264depay0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
In cb_newpad
gstname= video/x-raw
features= <Gst.CapsFeatures object at 0x7f540dc59820 (GstCapsFeatures at 0x7f5338040fa0)>
I am getting the following error “ERROR: [TRT]: 3: Cannot find binding of given name: BatchedNMS”
How do i solve this?
• DeepStream Version
• TensorRT Version
• The pipeline being used
So when I convert a TAO’s yolo model the output blobs are displayed, but here I have converted a custom yolo model to onnx, and then generated the engine file.
So what should my config file contain?
[class-attrs-all]
pre-cluster-threshold=0.3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
This is my config file, can you tell me what is right, and wrong!
0:00:01.215098373 37 0x2321b60 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.1/yolov4-tiny.engine
ERROR: [TRT]: 3: Cannot find binding of given name: 3840x1x4
0:00:01.240133006 37 0x2321b60 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1876> [UID = 1]: Could not find output layer ‘3840x1x4’ in engine
0:00:01.240149967 37 0x2321b60 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.1/yolov4-tiny.engine
0:00:01.251401287 37 0x2321b60 ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initResource() <nvdsinfer_context_impl.cpp:778> [UID = 1]: Detect-postprocessor failed to init resource because dlsym failed to get func NvDsInferParseCustomYoloV4 pointer
ERROR: nvdsinfer_context_impl.cpp:1074 Infer Context failed to initialize post-processing resource, nvinfer error:NVDSINFER_CUSTOM_LIB_FAILED
ERROR: nvdsinfer_context_impl.cpp:1280 Infer Context prepare postprocessing resource failed., nvinfer error:NVDSINFER_CUSTOM_LIB_FAILED
0:00:01.257605903 37 0x2321b60 WARN nvinfer gstnvinfer.cpp:846:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:01.257627495 37 0x2321b60 WARN nvinfer gstnvinfer.cpp:846:gst_nvinfer_start: error: Config file path: yolo_config.txt, NvDsInfer Error: NVDSINFER_CUSTOM_LIB_FAILED
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): gstnvinfer.cpp(846): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
I am stuck with the above error, solution to this will be of a great help!
Hi @rishika.varshiinirao
These parameters as explained below are all model-related, you need understand what these paramters are from my explaination below or from the DeepStream guide, then check your model and then decide what need to be set. Since I have no idea what your model is, I can’t help you find out what need be set for them.
uff-input-order: the input order (NCHW or NHWC) of your model
uff-input-blob-name : the input name of your network
parse-bbox-func-name: if your model needs custom post-processor
