I want to implement yolov4 tensorrt in xavier nx,
I follow this forum and try to build the progeam.
Everything went well when I build the environment and tensorrt oss toolkit.
But when I run ../bin/yolov4
to convert model from .onnx to .engine, the error showed like this,
&&&& RUNNING TensorRT.sample_yolo # ../bin/yolov4 --fp16
There are 0 coco images to process
[12/04/2020-15:59:06] [I] Building and running a GPU inference engine for Yolo
[12/04/2020-15:59:08] [I] Parsing ONNX file: ../data/yolov4.onnx
[12/04/2020-15:59:09] [W] [TRT] onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[12/04/2020-15:59:09] [W] [TRT] onnx2trt_utils.cpp:246: One or more weights outside the range of INT32 was clamped
[12/04/2020-15:59:10] [I] [TRT] ModelImporter.cpp:135: No importer registered for op: BatchedNMS_TRT. Attempting to import as plugin.
[12/04/2020-15:59:10] [I] [TRT] builtin_op_importers.cpp:3659: Searching for plugin: BatchedNMS_TRT, plugin_version: 1, plugin_namespace:
[12/04/2020-15:59:10] [I] [TRT] builtin_op_importers.cpp:3676: Successfully created plugin: BatchedNMS_TRT
[12/04/2020-15:59:10] [E] [TRT] (Unnamed Layer* 3429) [PluginV2Ext]: PluginV2Layer must be V2DynamicExt when there are runtime input dimensions.
[12/04/2020-15:59:10] [I] Building TensorRT engine../data/yolov4.engine
[12/04/2020-15:59:10] [E] [TRT] Layer (Unnamed Layer* 3429) [PluginV2Ext] failed validation
[12/04/2020-15:59:10] [E] [TRT] Network validation failed.
&&&& FAILED TensorRT.sample_yolo # ../bin/yolov4 --fp16
Is anyone know how to solve this problem?
Any suggestion is appreciated, thanks.
