Full TFRecords log
2020-08-25 15:00:51.094852: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
Using TensorFlow backend.
2020-08-25 15:00:54,357 - iva.detectnet_v2.dataio.build_converter - INFO - Instantiating a kitti converter
2020-08-25 15:00:54,358 - iva.detectnet_v2.dataio.kitti_converter_lib - INFO - Num images in
Train: 81 Val: 8
2020-08-25 15:00:54,358 - iva.detectnet_v2.dataio.kitti_converter_lib - INFO - Validation data in partition 0. Hence, while choosing the validationset during training choose validation_fold 0.
2020-08-25 15:00:54,358 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 0
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/dataset_converter_lib.py:142: The name tf.python_io.TFRecordWriter is deprecated. Please use tf.io.TFRecordWriter instead.
2020-08-25 15:00:54,358 - tensorflow - WARNING - From /home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/dataset_converter_lib.py:142: The name tf.python_io.TFRecordWriter is deprecated. Please use tf.io.TFRecordWriter instead.
2020-08-25 15:00:54,359 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 1
2020-08-25 15:00:54,359 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 2
2020-08-25 15:00:54,359 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 3
2020-08-25 15:00:54,359 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 4
2020-08-25 15:00:54,359 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 5
2020-08-25 15:00:54,359 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 6
2020-08-25 15:00:54,359 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 7
2020-08-25 15:00:54,359 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 8
2020-08-25 15:00:54,359 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 9
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: VisibleDeprecationWarning: Reading unicode strings without specifying the encoding argument is deprecated. Set the encoding, use None for the system default.
2020-08-25 15:00:54,378 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO -
Wrote the following numbers of objects:
b’person’: 26
2020-08-25 15:00:54,378 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 0
2020-08-25 15:00:54,388 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 1
2020-08-25 15:00:54,398 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 2
2020-08-25 15:00:54,409 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 3
2020-08-25 15:00:54,420 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 4
2020-08-25 15:00:54,433 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 5
2020-08-25 15:00:54,443 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 6
2020-08-25 15:00:54,454 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 7
2020-08-25 15:00:54,464 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 8
2020-08-25 15:00:54,472 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 9
2020-08-25 15:00:54,483 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO -
b’person’: 268
2020-08-25 15:00:54,483 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Cumulative object statistics
b’person’: 294
2020-08-25 15:00:54,483 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Class map.
Label in GT: Label in tfrecords file
b’person’: b’person’
For the dataset_config in the experiment_spec, please use labels in the tfrecords file, while writing the classmap.
2020-08-25 15:00:54,483 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Tfrecords generation complete.
Conversion Spec file
kitti_config {
root_directory_path: “/workspace/tlt-experiments/data”
image_dir_name: “images”
label_dir_name: “labels”
image_extension: “.jpg”
partition_mode: “random”
num_partitions: 2
val_split: 10
num_shards: 10 }
image_directory_path: “/workspace/tlt-experiments/data/images”
Command
!tlt-dataset-convert -d $SPECS_DIR/conversion.txt -o $SPECS_DIR/tfrecords/peopletrain/peopletrain
Training Config file
config_peoplenet (1).txt (1.3 KB)
