ZMQ files not linked with TensorRT sample
• Hardware Platform (Jetson / GPU) NVIDIA Jetson Xavier AGX
• DeepStream Version 5.1
• JetPack Version (valid for Jetson only) 4.5.1
• TensorRT Version 7.1.3
• Issue Type( questions, new requirements, bugs) questions
I installed zmq on my Xavier as follows:
sudo apt-get install libzmq3-dev
I created a simple ZMQ server that uses PUSH/PULL architecture in a C++ program. I am able to compile it using CLI as follows:
$ gcc -Wall -g server.cpp -lstdc++ -lzmq -o out
Then I integrate this code in my sampleUffMaskRCNN. As this is compiled using the makefile (makefile.config). To compile the updated application, I need to add the -lzmq flag to the original makefile. This is what I do:
-COMMON_FLAGS += -Wall -Wno-deprecated-declarations -std=c++11 $(INCPATHS)
+COMMON_FLAGS += -Wall -g -lstdc++ -lzmq -Wno-deprecated-declarations -std=c++11 $(INCPATHS)
On running sudo make clean && sudo make, I get
Linking: ../../bin/sample_uff_mask_rcnn_debug
../../bin/dchobj/sampleUffMaskRCNN.o: In function `main':
/home/virus/Desktop/optimisation/custom-inference-mrcnn/maskRCNN/sampleUffMaskRCNN.cpp:717: undefined reference to `zmq_ctx_new'
/home/virus/Desktop/optimisation/custom-inference-mrcnn/maskRCNN/sampleUffMaskRCNN.cpp:718: undefined reference to `zmq_socket'
/home/virus/Desktop/optimisation/custom-inference-mrcnn/maskRCNN/sampleUffMaskRCNN.cpp:724: undefined reference to `zmq_ctx_new'
/home/virus/Desktop/optimisation/custom-inference-mrcnn/maskRCNN/sampleUffMaskRCNN.cpp:725: undefined reference to `zmq_socket'
/home/virus/Desktop/optimisation/custom-inference-mrcnn/maskRCNN/sampleUffMaskRCNN.cpp:726: undefined reference to `zmq_connect'
/home/virus/Desktop/optimisation/custom-inference-mrcnn/maskRCNN/sampleUffMaskRCNN.cpp:737: undefined reference to `zmq_recv'
collect2: error: ld returned 1 exit status
../Makefile.config:301: recipe for target '../../bin/sample_uff_mask_rcnn_debug' failed
make: *** [../../bin/sample_uff_mask_rcnn_debug] Error 1
I feel that I am messing up with the makefile because zmq works when compiling using gcc.
I have cloned the sampleUffMaskRCNN sample provided in the pre-installed TensorRT and then added the ZMQ part. On compiling this modified sample using modified makefile.config,
Do you want to add the zmq library into sampleUffMaskRCNN but it is not working?
If yes, could you share the error you met with us first?
Sorry for leaving that part. Just added it to the question. Please look
Ok so I was wrongly adding the linker flag -lzmq to the compiler line, which was meant to only contain compilation flags and not linker flags.
This is the change I made:
 COMMON_LIBS += $(CUDART_LIB)
+COMMON_LIBS += -lzmq
and undid the change to
