Hi Guys,
I am trying out the 10_camera_recording sample code in Tegra multimedia API.
env: jetson orin nx, jetpack 35.4.1,.
I did not change anything on the 10_argus_camera_recording.
just run below command:
- sudo make
desktop:/usr/src/jetson_multimedia_api/samples/10_argus_camera_recording$ sudo make
Compiling: main.cpp
make[1]: Entering directory '/usr/src/jetson_multimedia_api/samples/common/classes'
Compiling: NvUtils.cpp
Compiling: NvElementProfiler.cpp
Compiling: NvElement.cpp
Compiling: NvApplicationProfiler.cpp
Compiling: NvVideoDecoder.cpp
Compiling: NvJpegEncoder.cpp
Compiling: NvBuffer.cpp
Compiling: NvLogging.cpp
Compiling: NvEglRenderer.cpp
Compiling: NvBufSurface.cpp
Compiling: NvDrmRenderer.cpp
Compiling: NvJpegDecoder.cpp
Compiling: NvVideoEncoder.cpp
Compiling: NvV4l2ElementPlane.cpp
Compiling: NvVulkanRenderer.cpp
Compiling: NvV4l2Element.cpp
make[1]: Leaving directory '/usr/src/jetson_multimedia_api/samples/common/classes'
Compiling: /usr/src/jetson_multimedia_api/argus/samples/utils/Thread.cpp
Compiling: /usr/src/jetson_multimedia_api/argus/samples/utils/NativeBuffer.cpp
Compiling: /usr/src/jetson_multimedia_api/argus/samples/utils/nvmmapi/NvNativeBuffer.cpp
Linking: argus_camera_recording
./argus_camera_recording -v -c -s -d 10
desktop:/usr/src/jetson_multimedia_api/samples/10_argus_camera_recording$ ./argus_camera_recording -v -c -s -d 10
Set governor to performance before enabling profiler
PRODUCER: Creating output stream
PRODUCER: Launching consumer thread
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 4
===== NvVideo: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
875967048
842091865
create video encoder return true
H264: Profile = 100, Level = 50
NVMEDIA: Need to set EMC bandwidth : 126000
PRODUCER: Starting repeat capture requests.
NvVideo: bBlitMode is set to TRUE
CONSUMER: Released frame. 23
CONSUMER: Acquired Frame. 28
Error generated. main.cpp, threadExecute:327 Failed to get NvBufSurface from dmabuf_fd
Error generated. /usr/src/jetson_multimedia_api/argus/samples/utils/Thread.cpp, threadFunction:132 (propagating)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
PRODUCER: Done -- exiting.
[ERROR] (NvV4l2ElementPlane.cpp:178) <enc0> Capture Plane:Error while DQing buffer: Broken pipe
[ERROR] (NvV4l2ElementPlane.cpp:256) <enc0> Capture Plane:Error while Qing buffer: Device or resource busy
Error generated. main.cpp, encoderCapturePlaneDqCallback:505 Failed to enqueue buffer to encoder capture plane
(Argus) Error InvalidState: Argus client is exiting with 3 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
Total Profiling Time = 0 sec
