I am new to GStreamer and try to use it with C++ by inputing 10 -Bit Images into appsrc.
Therefore I am taking Images from my grayscale camera which supports 10/12 bit.
Following this, I do some Image processing and push those Images into appsrc.
What I use:
Jetson TX2
Gstreamer Version 1.83
Input -> 10 bit Images saved in GRAY16_LE
output -> I420_10LE (H265 encoder)
gst_nvvconv_prepare_isurface: invalid in_pxt_fmt
gst_nvvconv_transform: Failed to prepare inter surfaces
Does this mean it does not support the conversion from I420_10LE Video/x-raw, Format=I420_10LE to Video/x-raw(Memory:NVMM), Format=I420_10LE? So no conversion between Video/x-raw and Video/x-raw(Memory:NVMM) are allowed. How to construct the Pipeline correctly?
what video format is actually passed to OMX encoder? Is it planar I420_10LE or semi-planar P010? I mean will nvvidconv actually do any conversion in your example pipeline, or will it just copy P010_10LE input as-is to NVMM memory?
