I have an USB camera that I access using v4l2src. The format of the raw camera pixels is I420 and I want to convert it with nvvidconv to BGRx to further process it in opencv.
Nvvidconv seems to work fine as long as the sink or source side uses the ‘video/x-raw(memory:NVMM)’ capabilitiy. If both the sink and source sides use the ‘video/x-raw’ capability, I get an internal data flow error. To illustrate:
The following works where I put a video encoder on the source side of nvvidconv to be able to use ‘video/x-raw(memory:NVMM)’ on the source side and ‘video/x-raw’ on the sink side:
gst-launch-1.0 v4l2src device="/dev/video1" ! 'video/x-raw, format=(string)I420' ! nvvidconv ! 'video/x-raw(memory:NVMM), format=(string)NV12' ! omxh264enc ! video/x-h264, stream-format=byte-stream ! rtph264pay ! udpsink host=10.66.24.128
The following also works where I replace the v4l2src with nvcamerasrc (CSI camera i.s.o USB camera) so the sink side is ‘video/x-raw(memory:NVMM)’ and the source side is ‘video/x-raw’:
gst-launch-1.0 -v nvcamerasrc ! video/x-raw(memory:NVMM), format=I420 ! nvvidconv ! 'video/x-raw, format=(string)BGRx' ! ximagesink
However if I want to use the v4l2src on the input and get a BGRx video stream on the output:
gst-launch-1.0 -v v4l2src device="/dev/video1" ! 'video/x-raw, format=(string)I420' ! nvvidconv ! 'video/x-raw, format=(string)BGRx' ! ximagesink
I get the following error:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)I420\,\ width\=\(int\)1280\,\ height\=\(int\)1024\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)15/2"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)I420\,\ width\=\(int\)1280\,\ height\=\(int\)1024\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)15/2"
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = "video/x-raw\,\ width\=\(int\)1280\,\ height\=\(int\)1024\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)15/2\,\ format\=\(string\)BGRx"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = "video/x-raw\,\ width\=\(int\)1280\,\ height\=\(int\)1024\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)15/2\,\ format\=\(string\)BGRx"
/GstPipeline:pipeline0/GstXImageSink:ximagesink0.GstPad:sink: caps = "video/x-raw\,\ width\=\(int\)1280\,\ height\=\(int\)1024\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)15/2\,\ format\=\(string\)BGRx"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = "video/x-raw\,\ width\=\(int\)1280\,\ height\=\(int\)1024\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)15/2\,\ format\=\(string\)BGRx"
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)I420\,\ width\=\(int\)1280\,\ height\=\(int\)1024\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)15/2"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)I420\,\ width\=\(int\)1280\,\ height\=\(int\)1024\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)15/2"
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data flow error.
Additional debug info:
gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming task paused, reason error (-5)
Execution ended after 0:00:01.495050436
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
I was able to work around it using 2 hardware accelerated conversions but that’s just a waste of resources:
gst-launch-1.0 -v v4l2src device="/dev/video1" ! 'video/x-raw, format=(string)I420' ! nvvidconv ! 'video/x-raw(memory:NVMM)' ! nvvidconv ! 'video/x-raw, format=(string)BGRx' ! ximagesink
Is it possible to fix this or is there a better workaround than using two catenated hardware conversions?
Thanks in advance
