[Gstreamer] nvvidconv, BGR as INPUT
according to:
https://developer.download.nvidia.com/embedded/L4T/r32_Release_v1.0/Docs/Accelerated_GStreamer_User_Guide.pdf
nvvidconv allows BGRx as input but not BGR, have you considered to add this format?
In this way is not required to use videoconvert and use CPU.
I request this info why my application:
  1. capture frame from RTSP and convert it to BGR
  2. detect objects
  3. edit frame with OpenCV
  4. write frame to nvdrmvideosink
In step 4 I use this code (python):
send_gst = "appsrc ! video/x-raw, format=(string)BGR ! videoconvert ! video/x-raw,format=BGRx ! nvvidconv ! video/x-raw(memory:NVMM), format=(string)I420 ! nvdrmvideosink -e"
out_send = cv2.VideoWriter(send_gst, 0, int(stream_fps), (opt.width, opt.height))
and I need to use videoconvert instead of to use directly nvvidconv to convert frame to I420.
It is limitation of hardware VIC engine. You have to use videoconvert plugin in the usecase.
We have DS4.0.1 for deep learning usecases. You may also check it and may be able to apply to your usease.
GStreamer pipeline feed to OpenCV with GPU acceleration
Jetson Nano with gstreamer and opencv - High overhead
OpenCV/Gstreamer Streaming Optimisation
Any hardware acceleration possible in gstreamer pipeline for usb camera?
Higher CPU usage irresepective of Gstreamer Jetson Nano
Gstreamer use MJPEG codec
Use OpenCV or Deepstream SDK on Jetson Nano for big project
Is there any way other than usb capture to get video stream from camera(hdmi/sdi) for use with CV libraries?
NvBufSurfTransform interface error:“Failed to configure VIC Target Surface”
Leopard Imaging CSI Cameras and Aruco detection through OpenCV not using CUDA
OpenCV frame writing too slow
NVIDIA Gstreamer nvvidconv question
Avoid use of videoconvert
How to Filesink and Appsink simultaneously in OpenCV Gstreamer. (Gstreamer pipeline included)
GStreamer: How to use v4l2convert instead of videoconvert
Repeated frames using gstreamer with multiple cameras in OpenCV
Hardware accelerated gstreamer/nvvidconv convert from YUV* to RGB*?
Rotation + apply mask to video in real time
Encoding and decoding 4k videos on jetson xavier using opencv
Extremely high latency when feeding camera to cv2
Add Gaussian Noise to CSI-2 Camera Stream with CUDA OpenCV leads to Low/Lagging FPS
Frame writing delay after creating cv2.VideoWriter() object
Performance of nvargus-daemon
Gstreamer convert to RGB on Nano
Streaming video from IM477 sensor on Nano is slow?
Issue with multi-camera gstreamer capture using OpenCV
Problem merging two camera streams using nvcompositor and forwarding merged video to the Darknet
Can I use ABGR32 as an output fixel format?
About 02_video_dec_cuda
I’m trying to find a solution, unfortunately deepstream is not an option. I need to work in python.
I’m using this pipeline:
rtspsrc location=rtsp://admin:Password@192.168.0.202:554/ latency=500 ! queue ! rtph264depay ! queue ! h264parse ! omxh264dec !   nvvidconv ! video/x-raw,format=BGRx ! videoconvert ! video/x-raw,format=BGR ! queue max-size-buffers=0 max-size-time=0 max-size-bytes=0 min-threshold-time=200000000 ! appsink sync=true
It works but I would like to avoid to use videoconvert cause it uses CPU instead of GPU.
In theory is possible to manage RGBA frames using python, but if I change my pipeline in this way:
rtspsrc location=rtsp://admin:Password@192.168.0.202:554/ latency=500 ! queue ! rtph264depay ! queue ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw,format=RGBA ! queue max-size-buffers=0 max-size-time=0 max-size-bytes=0 min-threshold-time=200000000 ! appsink sync=true
I get an error:
Trying to dispose element capsfilter21, but it is in PLAYING instead of the NULL state.
You need to explicitly set elements to the NULL state before
dropping the final reference, to allow them to clean up.
This problem may also be caused by a refcounting bug in the
application or some element.
We have tried the following python code on TX2/r32.1/OpenCV3.4.1
import sys
import cv2
def read_cam():
    cap = cv2.VideoCapture("nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)30/1 ! nvvidconv ! video/x-raw, format=(string)I420 ! appsink")
    if cap.isOpened():
        cv2.namedWindow("demo", cv2.WINDOW_AUTOSIZE)
        while True:
            ret_val, img = cap.read();
            img2 = cv2.cvtColor(img, cv2.COLOR_YUV2BGR_I420);
            cv2.imshow('demo',img2)
            cv2.waitKey(10)
    else:
     print "camera open failed"
    cv2.destroyAllWindows()
if __name__ == '__main__':
    read_cam()
It may help your usecase. FYR.
But in this way…
is not done by CPU and not from GPU?
Am I wrong?
It is don on CPU. Since nvvidconv plugin does not support BGR.
Another way is to run
cap = cv2.VideoCapture("nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)30/1 ! nvvidconv ! video/x-raw, format=(string)RGBA ! appsink")
And do
img2 = cv2.cvtColor(img, CV_RGBA2BGR);
However, cv2.cvtColor(img, CV_RGBA2BGR) is still done on CPU.
hi all,
thanks for this discussion and information to see how i get gstreamer on the jetson nano into opencv.
but i am stuck with the right pipeline from a rtsp stream. may anybody can kindly give me a hint?
i adopt DaneLLL last suggestion for my rtsp stream , but this fails to grab:
cap = cv2.VideoCapture('rtspsrc location=rtspt://user.pwd@192.168.14.83/Streaming/Channels/101 ! decodebin ! nvvidconv ! video/x-raw,format=RGBA ! appsink sync=0' )
i got this both variants working (with same python code):
cap = cv2.VideoCapture('rtspsrc location=rtspt://usr:pwd@192.168.14.83/Streaming/Channels/101 ! decodebin ! nvvidconv ! video/x-raw,format=I420,width=1061,height=600 ! videoconvert ! appsink sync=0' )
cap = cv2.VideoCapture('rtspsrc location=rtspt://usr:pwd@192.168.14.83/Streaming/Channels/101 ! decodebin ! nvvidconv ! video/x-raw,format=BGRx,width=1061,height=600 ! videoconvert ! video/x-raw,format=BGR ! queue! appsink sync=0'
i simply want to achive to grab the rtsp-stream (working good with gestreamer in opencv) and feed the frames into TensorRT (wich i installed from dusty-nv github and its working fine).
on first try with some pipes i had grayscale images, and with rtsp both of DaneLLL suggested conversions above dont ome into play with the rtsp pipeline and nvidconv-format=RGBA failing on the rtsp-stream.
cv2.cvtColor(img, cv2.COLOR_YUV2BGR_I420);cv2.cvtColor(img, CV_RGBA2BGR);
maybe a little hint to get a lean/smallest and/or fasted gstreamer accelerated pipeline for a RTSP-source into opencv ?
thx, all suggestions greatly appreciated
Opencv application is only able to grab 1 or 3 channels frames from videoCapture.
1st working case is getting I420 frames, you may have to convert into BGR with:
In second case, you use nvvidconv HW ISP for converting into RGBx and then videoconvert for removing the extra 4th byte and pack into BGR, ready for most opencv algorithms.
You would probably not bother with RGBA conversion for this case.
Note that conversion from YUV to BGR in opencv may not be better than nvvidconv+videoconvert in gstreamer. You may benchmark your case for being sure.
