The power consumption mode is configured to 120W, and the GPU model is running. The measured power consumption reaches more than 260W(28V, 9.33A).
The GUI shows that the GPU frequency is limited to 1386MHz according to the maximum value of 120W, and an overcurrent warning appears during the test.
The measured peak power consumption reached 260W (28V, 9.33A)
please refer to
120W refers to the situation where the CPU is 50% and the GPU is 50% ?
If the Instantaneous VDD_GPU power is over 120W, then throttling will happen and cpu/gup freq will be only 50%
The instantaneous power consumption exceeds 120W, but the Power GUI shows the GPU frequency remains at the maximum value and unchanged. Is there a problem with the GUI display?
The throttling only happened in a short period. Power GUI may not capture it in time.
