Description
I have a 10GB 3080RTX GPU, nvidia-smi reports 10014MiB memory, Tensorflow reports:
Created device /job:localhost/replica:0/task:0/device:GPU:0 with 7591 MB memory
After initial research I was convinced that this is related to Windows 10 OS limitations, so I installed Ubuntu 20.04 in dual boot. It didn’t change anything, I tried various versions of Tensorflow, Cuda, Cudnn.
I tried using:
physical_devices = tf.config.list_physical_devices('GPU')
for gpu_instance in physical_devices:
tf.config.experimental.set_memory_growth(gpu_instance, True)
It didn’t fix the problem. Also, I tried:
from tensorflow.compat.v1 import ConfigProto
from tensorflow.compat.v1 import InteractiveSession
config = ConfigProto()
config.gpu_options.per_process_gpu_memory_fraction = 1.0
session = InteractiveSession(config=config)
And indeed, TensorFlow started to report proper full 10GB of memory in ‘Created device’ message, so tf should see the memory properly. With this method I was able to push memory to something like 8GB and it even allowed me to run slightly higher batch size. But, if I specify fraction of more than 0.8 (it may slightly vary from run-to-run) than i have:
2021-09-26 12:48:26.691479: F tensorflow/core/util/cuda_solvers.cc:115] Check failed: cusolverDnCreate(&cusolver_dn_handle) == CUSOLVER_STATUS_SUCCESS Failed to create cuSolverDN instance.
One important thing to note, is that while TensorFlow is reporting a device with ~7.5GB, in nvidia-smi it is reporting more than 9GB by /usr/bin/python3! I am not running any other Python script in parallel.
So, the memory usage in reality is reaching its limits while I am able to use only 7.5GB, which is even less than known 81% limitation for Windows 10 users! Why am I being allocated almost extra 2GB on top which I can’t use?
I was trying to fix it for a long time and really don’t have any idea what to do now. Other people’s problems with missing tf memory that I found on Internet were related to Windows OS, mine is not. Am I missing something? I would really appreciate any idea on what is going on.
Thank you in advance.
Environment
GPU Type: MSI RTX 3080 10GB
Nvidia Driver Version: 470.63.01
CUDA Version: 11.2, 11.4
CUDNN Version: 8.1.0, 8.2.4
Operating System + Version: Ubuntu 20.04, Windows 10
Python Version (if applicable): 3.8.10
TensorFlow Version (if applicable): 2.5.0, 2.5.1, 2.6.0
Steps To Reproduce
The problem arises both for my custom code and for sample tensorflow scripts from official tutorials. So it should be not code-dependent.
