Dear NVIDIA technical support team and experts.
I am developing a DP 1.4 equipment.
The equipment receives the following DP display signals from the PC(Windows 10) which has NVIDIA graphic card.
Resolution : 2920*1900, 60 Hz/120 Hz.
Color : 8 bit. RGB.
Color depth 24 bit.
Computer : i7 with Windows 10 and GeForce GTX 1050 Ti graphic card.
I tried to set the display by using NVIDIA control panel.
I can set the Resolution and 8 bit color, however I can not set the 24 bit color depth.
The only selectable color depth is 32 bit.
I should use 24 bit color depth.
Would you guide me to set 24 bit color depth?
I will really appreciate if I can get the answer or method.
It is very important for me to develop the system.
Thank you very much.
Ick-Sung Choi.
