240fps from arducam imx477 jetson nano 2gb
I just bought the 2GB nano with Arducam imx477, I’m running it with JetPack 4.5 (4.9.201 L4T-32.5.1) and I can see the camera sensor and even take some videos and store it as .mp4.
When checking for available formats with v4l2-ctl --list-formats-ext
I get:
$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
	Index       : 0
	Type        : Video Capture
	Pixel Format: 'RG10'
	Name        : 10-bit Bayer RGRG/GBGB
		Size: Discrete 4032x3040
			Interval: Discrete 0.033s (30.000 fps)
		Size: Discrete 1920x1080
			Interval: Discrete 0.017s (60.000 fps)
		Size: Discrete 2592x1944
		Size: Discrete 2560x1440
			Interval: Discrete 0.025s (40.000 fps)
I was wondering if it is possible to work with 240fps at 1080p with my setup?
maybe go over the ISP and save it as raw(no real-time application needed)?
Thanks in advance,
Iftach.
Need to get the 240fps sensor mode from Sony and integrate it to the driver for it.
Thanks for the answer.
Are there any tutorials or examples of doing the integration?
You may start from here.
that mean,there are no maded patches,so i should make the patch by myself?
Have you solved the problem? I also need to use imx477 in high framerate up to 240fps , and my platform is jetson nx.
I did not solve the problem, if you manage to solve it please share your solution.
