2x NVIDIA RTX 2000 Ada 16GB GPU for running 8 monitors (5k res 60hz) - possible?
I know that with the consumer line of RTX cards that it’s not possible to run more than 4 monitors even if you are running dual card setup in a single PC (Windows 10, 64bit).
With this in mind, I’ve been looking at workstation/professional grade GPUs such as the RTX 2000 Ada and wondering if it would be possible to use dual RTX 2000 Ada 16GB to run 8 monitors which are 5k resolution 60hz, is this possible? If it is possible, would the same apply for something a bit more powerful such as the RTX 4000 Ada 20GB?
Thank you.
