3.0 build samples problem
Hi everybody! I’m using Mac OS X Snow Leopard 10.6.3, i’ve just installed version 3.0 driver + toolkit + sdk, and found that i can’t build OpenCL samples, here are the symptoms:
Last login: Mon Apr  5 03:23:54 on ttys000
Lu4-2:~ Lu4$ cd /Developer/GPU\ Computing/OpenCL/
Lu4-2:OpenCL Lu4$ make
src/oclUtils.cpp: In function ‘void oclPrintDevInfo(int, _cl_device_id*)’:
src/oclUtils.cpp:282: error: ‘CL_DEVICE_COMPUTE_CAPABILITY_MAJOR_NV’ was not declared in this scope
src/oclUtils.cpp:283: error: ‘CL_DEVICE_COMPUTE_CAPABILITY_MINOR_NV’ was not declared in this scope
src/oclUtils.cpp:290: error: ‘CL_DEVICE_REGISTERS_PER_BLOCK_NV’ was not declared in this scope
src/oclUtils.cpp:294: error: ‘CL_DEVICE_WARP_SIZE_NV’ was not declared in this scope
src/oclUtils.cpp:298: error: ‘CL_DEVICE_GPU_OVERLAP_NV’ was not declared in this scope
src/oclUtils.cpp:302: error: ‘CL_DEVICE_KERNEL_EXEC_TIMEOUT_NV’ was not declared in this scope
src/oclUtils.cpp:306: error: ‘CL_DEVICE_INTEGRATED_MEMORY_NV’ was not declared in this scope
make[1]: *** [obj/release/oclUtils.cpp.o] Error 1
make: *** [common/liboclUtil.so] Error 2
Lu4-2:OpenCL Lu4$
any thoughts?
Are you installed xcode ? what is the version ?
Actually, i download the version 3.2.2 and the iphone sdk 3.2 .
The link for xcode : Mac Dev Center - Apple Developer.
Regards.
Same problem here. Probably not the best solution but I pasted the define statements in the oclUtils.cpp file (at the top) and it compiled fine…
define CL_DEVICE_COMPUTE_CAPABILITY_MAJOR_NV 0x4000
define CL_DEVICE_COMPUTE_CAPABILITY_MINOR_NV 0x4001
define CL_DEVICE_REGISTERS_PER_BLOCK_NV 0x4002
define CL_DEVICE_WARP_SIZE_NV 0x4003
define CL_DEVICE_GPU_OVERLAP_NV 0x4004
define CL_DEVICE_KERNEL_EXEC_TIMEOUT_NV 0x4005
define CL_DEVICE_INTEGRATED_MEMORY_NV 0x4006
This is not the best solution but it is one.
Where to find the values for different variables?
I use the integrated 9400 and the 9600. How to avoid having to change the value each time I change cards?
Deeply real solution made by Nvidia as well as integration with Xcode.
Well, I think I found a solution.
The OpenCL example has messy headers re OpenCL, e.g.:
amadeus[2075]:/Developer/GPU Computing/OpenCL/common% grep -r “OpenCL/cl” *
inc/CL/cl.h:#include <OpenCL/cl_platform.h>
inc/CL/cl_gl.h:#include <OpenCL/cl.h>
inc/CL/opencl.h:#include <OpenCL/cl.h>
inc/CL/opencl.h:#include <OpenCL/cl_gl.h>
inc/CL/opencl.h:#include <OpenCL/cl_gl_ext.h>
inc/CL/opencl.h:#include <OpenCL/cl_ext.h>
looking at /Developer/GPU Computing/OpenCL/common/inc/oclUtils.h:
// All OpenCL headers
#if defined (APPLE) || defined(MACOSX)
#include <OpenCL/opencl.h>
#else
#include <CL/opencl.h>
#endif
and at “/Developer/GPU Computing/OpenCL/common/inc” we have only “CL” folder and not “OpenCL”
So, we will never have “obj/release/oclUtils.cpp.o” because make will never find the right header.
Well, the solution I found was:
/Developer/GPU Computing/OpenCL/common% cp -a inc/CL inc/OpenCL
/Developer/GPU Computing/OpenCL/common% make
/Developer/GPU Computing/OpenCL/common% mv common/inc/OpenCL common/inc/OpenCL_ #or delete
then go to /Developer/GPU Computing/OpenCL/ and do:
make
This works but I had to boot OS X in 32bit mode by holding down 3 and 2 until the Apple screen shows during startup. (I also followed the release instructions explicitly.)
