i have been working with PhysX 3.3.1 (17938824) and VS2013, everything was fine.
When i compiled the recent version 3.3.3 (19456754) from the git repository and used it, the simulation was suddenly very slow. The same code example with 300 stacked boxes runs 10 times faster in 3.3.1 (average of 1.8ms for 2.5ms simulation) compared to 3.3.3 (average of 18.7ms for 2.5ms simulation).
Here is the code:
#include <PxActor.h>
#include <extensions\PxDefaultErrorCallback.h>
#include <extensions/PxExtensionsAPI.h>
#include <foundation\PxMat44.h>
#include <foundation\PxTransform.h>
#include <PxMaterial.h>
#include <PxPhysics.h>
#include <PxRigidDynamic.h>
#include <PxRigidStatic.h>
#include <PxScene.h>
#include <map>
#include <chrono>
#include <iostream>
physx::PxPhysics* _physicsSDK;
physx::PxScene* _scene;
physx::PxMaterial* _material;
typedef std::map<int, physx::PxRigidActor*> ActorMap;
ActorMap _actors;
float width;
int max_i, max_j;
class ErrorCallback : public physx::PxErrorCallback
public:
virtual void reportError(physx::PxErrorCode::Enum code, const char* message, const char* file, int line)
std::cout << "Error " << code << " was found in (" << file << ", " << line << "): " << message << std::endl;
ErrorCallback errorHandler;
physx::PxDefaultAllocator defaultAllocator;
void createBox(int id, physx::PxVec3 dim, double density)
physx::PxBoxGeometry geometry(dim);
physx::PxRigidDynamic* actor = PxCreateDynamic(*_physicsSDK, physx::PxTransform::createIdentity(), geometry, *_material, density);
if (actor)
_scene->addActor(*actor);
_actors[id] = actor;
void setMatrix(int id, physx::PxMat44 matrix)
physx::PxRigidActor* actor = _actors[id];
if (actor) actor->setGlobalPose(physx::PxTransform(matrix));
void resetBoxes()
int i = 0; // rows
int j = 0; // columns
for (int id = 0; id < _actors.size(); id++)
setMatrix(id, physx::PxMat44(physx::PxMat33(1.0), physx::PxVec3(-width*(float)max_j / 2 + width*(float)j, width / 2 + width*(float)i, 0.0f)));
if (j == max_j - 1)
j = 0;
i++;
else
j++;
void main() {
// setup the scene
physx::PxFoundation* foundation = PxCreateFoundation(PX_PHYSICS_VERSION, defaultAllocator, errorHandler);
_physicsSDK = PxCreatePhysics(PX_PHYSICS_VERSION, *foundation, physx::PxTolerancesScale());
if (!PxInitExtensions(*_physicsSDK))
return;
#ifdef _DEBUG
if (_physicsSDK->getPvdConnectionManager())
physx::PxVisualDebuggerExt::createConnection(_physicsSDK->getPvdConnectionManager(), "localhost", 5425, 10000);
else
return;
#endif
physx::PxSceneDesc sceneDesc(_physicsSDK->getTolerancesScale());
sceneDesc.gravity = physx::PxVec3(0.0f, -9.81f, 0.0f);
sceneDesc.filterShader = &physx::PxDefaultSimulationFilterShader;
if (!sceneDesc.cpuDispatcher)
physx::PxDefaultCpuDispatcher* mCpuDispatcher = physx::PxDefaultCpuDispatcherCreate(1);
if (!mCpuDispatcher)
return;
sceneDesc.cpuDispatcher = mCpuDispatcher;
_scene = _physicsSDK->createScene(sceneDesc);
if (!_scene)
return;
// material
_material = _physicsSDK->createMaterial(10.0f, 10.0f, 0.00010f); // restitution - Stosszahl
// Create the ground
physx::PxTransform pose(physx::PxVec3(0.0f, 0.0f, 0.0f), physx::PxQuat(physx::PxPi / 2.0, physx::PxVec3(0.0, 0.0, 1.0)));
physx::PxRigidStatic* actor = _physicsSDK->createRigidStatic(pose);
if (!actor)
return;
physx::PxShape* shape = actor->createShape(physx::PxPlaneGeometry(), *_material);
if (!shape)
return;
// create the boxes
width = 0.04f; // edge length of the boxes
max_i = 30; // rows
max_j = 10; // columns
for (int i = 0; i < max_i; i++)
for (int j = 0; j < max_j; j++)
createBox(i * 10 + j, physx::PxVec3(width / 2, width / 2, width / 2), 0.1f);
// reset the boxes
resetBoxes();
// simulate
int counter = 0;
float counter_limit = 1000.0; // number of steps to compute
float dt = 0.0025f; // time step for simulation
auto t_start = std::chrono::high_resolution_clock::now();
while (counter < counter_limit) {
_scene->simulate(dt);
while (!_scene->fetchResults()) { /* do nothing but wait */ }
counter++;
auto t_end = std::chrono::high_resolution_clock::now();
std::cout << "Time passed: " << std::chrono::duration<double, std::milli>(t_end - t_start).count() << " ms\nAverage time per frame: " << std::chrono::duration<double, std::milli>(t_end - t_start).count() / counter_limit << " ms\n";
// wait for a key press
std::cout << "..." << std::endl;
std::cin.clear();
std::cin.ignore(std::cin.rdbuf()->in_avail());
std::cin.get();
return;
Can anybody reproduce or even bring light into this strange behavior?
