i’m trying to configure the Jetson Xavier NX to use 30 bit color depth video output from DP (HDMI same behavior).
I tried to define in xorg.conf file DefaultDepth to 30 and tried to use nvidia-xconfig in Jetpack 4.6 & 5.0 according to: https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/SD/WindowingSystems/XWindowSystem.html#setting-color-bit-depth
But i only get black screen with mouse cursor.
I verified that my monitor supports 30 bit with PC NVIDIA RTX3000 using NVIDIA control panel in Windows OS.
So how can i configure the Jetson?
I assume 30 bit is supported according to the nvidia-xconfig example (inside the link) and according to standard DP output from the Jetson.
I tried to configure to 32 bit RGB with:
nvidia-xconfog -depth=32
But i got the following message:
Invalid depth: 32.
I tried to find how to update xorg.conf file mannually and no luck here either.
Can you write me please how can i configure “A2R10G10B10” color format?
