It appears as if I currently have a choice of running either CUDA or Steam on my machine, because CUDA 11 requires a version of the driver that is only available from your site, and Steam requires the 32-bit libraries, which you’re not currently hosting, as far as I can see.
nvidia-smi
Fri Jan 1 13:37:24 2021
| NVIDIA-SMI 460.27.04 Driver Version: 460.27.04 CUDA Version: 11.2 |
apt install libnvidia-gl-460:i386
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package libnvidia-gl-460:i386 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
libnvidia-common-460
E: Package 'libnvidia-gl-460:i386' has no installation candidate
steam
Running Steam on ubuntu 20.10 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Can't find 'steam-runtime-check-requirements', continuing anyway
/home/james/.local/share/Steam/ubuntu12_32/steam -nominidumps -nobreakpad
[2021-01-01 13:40:51] Startup - updater built Oct 28 2020 23:34:22
ILocalize::AddFile() failed to load file "public/steambootstrapper_english.txt".
SteamUpdateUI: An X Error occurred
X Error of failed request: BadValue (integer parameter out of range for operation)
^C
Do you have plans to release the 32 bit versions at any time?
