Nvdia 2080 super + nvidia:450.36.06 + steam client + PopOS:20.04
On running steam with the latest drivers, I am getting the following situation.I have Cuda-11 installed as well
With the latest drivers this issue has crept up.
steam
File “/usr/bin/steamdeps”, line 484, in
sys.exit(main())
File “/usr/bin/steamdeps”, line 460, in main
if dep.is_available():
File “/usr/bin/steamdeps”, line 96, in is_available
return is_provided(self.name)
File “/usr/bin/steamdeps”, line 68, in is_provided
(name, version) = provider.split()
ValueError: too many values to unpack (expected 2)
Running Steam on pop 20.04 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Steam client’s requirements are satisfied
/home/abhigyan/.steam/debian-installation/ubuntu12_32/steam
[2020-06-14 15:19:15] Startup - updater built Jun 4 2020 05:50:42
Installing breakpad exception handler for appid(steam)/version(1591251555)
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
SteamUpdateUI: An X Error occurred
X Error of failed request: GLXBadContext
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 151 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 45
xerror_handler: X failed, continuing
Minor opcode of failed request: 6 (X_GLXIsDirect)
Serial number of failed request: 46
Looks like steam didn’t shutdown cleanly, scheduling immediate update check
[2020-06-14 15:19:15] Checking for update on startup
[2020-06-14 15:19:15] Checking for available updates…
[2020-06-14 15:19:15] Downloading manifest: client-download.steampowered.com/client/steam_client_ubuntu12
[2020-06-14 15:19:16] Download skipped: /client/steam_client_ubuntu12 version 1591251555, installed version 1591251555
[2020-06-14 15:19:16] Nothing to do
[2020-06-14 15:19:16] Verifying installation…
[2020-06-14 15:19:16] Performing checksum verification of executable files
[2020-06-14 15:19:16] Verification complete
Loaded SDL version 2.0.13-5893924
Gtk-Message: 15:19:16.876: Failed to load module “gail”
Gtk-Message: 15:19:16.876: Failed to load module “atk-bridge”
Gtk-Message: 15:19:16.876: Failed to load module “appmenu-gtk-module”
(steam:55366): Gtk-WARNING **: 15:19:16.878: Unable to locate theme engine in module_path: “adwaita”,
/usr/share/themes/Pop-dark/gtk-2.0/main.rc:775: error: unexpected identifier ‘direction’, expected character ‘}’
(steam:55366): Gtk-WARNING **: 15:19:16.879: Unable to locate theme engine in module_path: “adwaita”,
/usr/share/themes/Pop-dark/gtk-2.0/hacks.rc:28: error: invalid string constant “normal_entry”, expected valid string constant
Steam: An X Error occurred
Serial number of failed request: 52
Serial number of failed request: 51
X Error of failed request: BadMatch (invalid parameter attributes)
Serial number of failed request: 53
assert_20200614151915_1.dmp[55442]: Uploading dump (out-of-process)
/tmp/dumps/assert_20200614151915_1.dmp
/home/abhigyan/.steam/debian-installation/steam.sh: line 750: 55366 Segmentation fault (core dumped) $STEAM_DEBUGGER “$STEAMROOT/$STEAMEXEPATH” “$@”
Forgot to add with nvdia:440 driver everything seemed to work great.
The cuda bundled driver doesn’t include the 32bit compat libs which are needed to run Steam and 32bit games.
Any user addressable resolution you could recommend boss, I have to learn cuda but need witcher as well 😅😅
Then you should rather downgrade to cuda 10.2. Please remove all nvidia and cuda packages, then install the 440 driver from Ubuntu repo. Afterwards, download and add the cuda 10.2 package/repo but instead of installing ‘cuda’ install just the toolkit:
sudo apt install cuda-toolkit-10-2
