I’m wondering, maybe I’m doing something wrong… after installation of packages I do not run nvidia-xconfig tool, because this is Optimus-based… Please advise, thank you so much.
Did you installed the drivers directly? Optimus-based laptops can’t do that… I know, I own one. You’ll either have to choose whether to use Nvidia-Prime, Ubuntu’s homegrown support for Optimus powered laptops or Bumblebee, a community supported software which is intended to provide support for Optimus laptops.
nvidia-prime
Perfect performance
Log-in & log-out to switch between GPUs
Screen tearing when using Nvidia GPU (a lot)
High temperature when using Nvidia GPU (Nvidia GPU is use completely to render graphics)
First I tried to use nvidia-prime because I heard that nvidia-prime made some progress lately and it’s worth to give it a shot. But I was not able to run it (as you can see from logs in the first post).
I’m using Bumblebee right now and I’m pretty satisfied, it’s a pitty that it doesn’t recognize automatically when the switch to NVIDIA is needed. But still sounds better than log off/log on to switch.
I’ve tested out both previously. After a number of times using nvidia-prime, I’ve really appreciate Bumblebee. That amount of screen tearing in nvidia-prime started to be a PITA. Luckily, with the recent mainline kernels, bumblebee’s performance starts to improve.
