HP Omen 15t
Intel i7-4710HQ Haswell
16 GB of 1600 DDR3
Nvidia 860M 4GB GDDR5
512GB PCIe SSD
nvidia-bug-report.log.gz
I think the issue I am having is that there aren’t any detected display devices, but according to the nvidia readme notes the Option “UseDisplayDevice” “none” should help; however, I still get a blank screen (backlight does work)
xorg.conf
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia"
Inactive "intel"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "keyboard"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Section "Device"
Identifier "intel"
Driver "intel"
BusID "PCI:00:02:0"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
Section "Device"
Option "UseDisplayDevice" "none"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:01:00:0"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
Option "AllowEmptyInitialConfiguration"
SubSection "Display"
Modes "nvidia-auto-select"
EndSubSection
EndSection
Looking through my logs, I see the following:
[ 7.290763] nvidia 0000:01:00.0: irq 38 for MSI/MSI-X
[ 7.293776] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20140926/nsarguments-95)
[ 7.293811] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20140926/nsarguments-95)
[ 7.293829] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20140926/nsarguments-95)
[ 7.293856] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20140926/nsarguments-95)
[ 7.293873] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20140926/nsarguments-95)
[ 7.293889] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20140926/nsarguments-95)
[ 7.293922] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20140926/nsarguments-95)
[ 7.293939] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20140926/nsarguments-95)
[ 8.087476] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20140926/nsarguments-95)
[ 8.556924] vgaarb: this pci device is not a vga device
Could this be causing some issue?
Since this is an Optimus configuration, it’s up to the other driver to handle lighting up the displays. Does the “modesetting” driver work by itself if you don’t run it in a “PRIME” configuration with the NVIDIA driver? The Intel kernel driver seems to have trouble with the backlight on some laptops. You could try using the “intel” X driver rather than the “modesetting” driver, though you may run into a bug that prevents that from working with PRIME.
Finally, are you running a desktop environment that’s configured to make the appropriate RandR calls to turn on the screen? The X server doesn’t do it automatically for PRIME displays.
@aplattner, thanks for responding!
Jan 30 16:16:15 hpomen gdm-Xorg-:0[1323]: (EE) intel(G0): [drm] failed to set drm interface version: Permission denied [13].
Jan 30 16:16:15 hpomen gdm-Xorg-:0[1323]: (II) intel(G0): [drm] Contents of '/sys/kernel/debug/dri/0/clients':
Jan 30 16:16:15 hpomen gdm-Xorg-:0[1323]: (II) intel(G0): [drm] command pid dev master a uid magic
Jan 30 16:16:15 hpomen gdm-Xorg-:0[1323]: (II) intel(G0): [drm] plymouthd 350 0 n y 0 0
Jan 30 16:16:15 hpomen gdm-Xorg-:0[1323]: (II) intel(G0): [drm] Xorg.bin 1323 0 y y 0 0
Jan 30 16:16:15 hpomen gdm-Xorg-:0[1323]: (II) intel(G0): [drm] Xorg.bin 1323 0 n y 0 0
Jan 30 16:16:15 hpomen gdm-Xorg-:0[1323]: (EE) intel(G0): Failed to claim DRM device.
Jan 30 16:16:15 hpomen gdm-Xorg-:0[1323]: (II) UnloadModule: "intel"
#!/bin/sh
# Get the xrandr providers
output="$(xrandr --listproviders)"
src=$(echo -e "$output" | grep " Source" | head -n1 | awk '{print $NF}' | cut -d: -f 2)
sink=$(echo -e "$output" | grep " Sink" | head -n1 | awk '{print $NF}' | cut -d: -f 2)
# Pass provider sink and source
xrandr --setprovideroutputsource "$sink" "$src"
edp=$(xrandr | grep -i "edp" | head -n1 | cut -d " " -f 1)
xrandr --output "$edp" --off
xrandr --output "$edp" --auto
#xrandr --auto
DISPLAY=:0.0 sudo xrandr --listproviders
Provider 0: id: 0x1f6 cap: 0x1, Source Output crtcs: 0 outputs: 0 associated providers: 0 name:NVIDIA-0
Provider 1: id: 0x47 cap: 0x2, Sink Output crtcs: 3 outputs: 5 associated providers: 0 name:modesetting
Screen 0: minimum 8 x 8, current 640 x 480, maximum 16384 x 16384
eDP-1-0 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 40.00
1400x1050 59.98
1280x1024 60.02
1280x960 60.00
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
800x600 60.00 60.32 56.25
700x525 59.98
640x512 60.02
640x480 60.00 59.94
512x384 60.00
400x300 60.32 56.34
320x240 60.05
VGA-1-0 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-1-0 disconnected (normal left inverted right x axis y axis)
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
@aplattner: I didn’t see this before, but the nvidia bug report log shows the xorg server is crashing:
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) Backtrace:
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 0: /usr/libexec/Xorg.bin (OsLookupColor+0x119) [0x59c5f9]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 1: /lib64/libc.so.6 (__restore_rt+0x0) [0x7fa42887794f]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 2: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (nvidiaAddDrawableHandler+0x30e2e) [0x7fa42209f88e]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) unw_get_proc_name failed: no unwind info found [-10]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 3: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (?+0x30e2e) [0x7fa4220453ce]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 4: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (nvidiaAddDrawableHandler+0x9d4a) [0x7fa42205162a]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 5: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (nvidiaAddDrawableHandler+0x5098d6) [0x7fa422a50db6]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 6: /usr/libexec/Xorg.bin (RRCrtcDetachScanoutPixmap+0x6a) [0x4fb4fa]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 7: /usr/libexec/Xorg.bin (xf86PruneDuplicateModes+0x1a78) [0x4bced8]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 8: /usr/libexec/Xorg.bin (xf86PruneDuplicateModes+0x1b4f) [0x4bd04f]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 9: /usr/libexec/Xorg.bin (ProcRRGetOutputProperty+0x4f2) [0x502b32]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 10: /usr/libexec/Xorg.bin (RegisterResourceName+0x232) [0x45c2f2]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 11: /usr/libexec/Xorg.bin (FreeClientResources+0x6c) [0x45d1ec]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 12: /usr/libexec/Xorg.bin (FreeAllResources+0x47) [0x45d297]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 13: /usr/libexec/Xorg.bin (remove_fs_handlers+0x449) [0x43d339]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 14: /lib64/libc.so.6 (__libc_start_main+0xf0) [0x7fa428862fe0]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 15: /usr/libexec/Xorg.bin (_start+0x29) [0x4276ee]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) 16: ? (?+0x29) [0x29]
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) Segmentation fault at address 0x30
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: Fatal server error:
Jan 30 08:59:31 hpomen gdm-Xorg-:0[1323]: (EE) Caught signal 11 (Segmentation fault). Server aborting
Any thoughts as to what is happening?
Hi, I am having the same problem, have you managed to solve this?
