Following instructions provided in Chapter 17. Using the NVIDIA Driver with Optimus Laptops , Chapter 32. Offloading Graphics Display with RandR 1.4 and Chapter 33. Direct Rendering Manager Kernel Modesetting (DRM KMS) I am unable to successfully start a X-Server with NVIDIA Optimus enabled - all I get is a black screen.
I collected data as described here: If you have a problem, PLEASE read this first - Linux - NVIDIA Developer Forums by the NVIDIA team. I Hope I can attach them here eventually.
What am I doing wrong?
Main Components:
- Lenovo T470p
- Nvidia GM108M (GeForce 940MX)
- Linux 4.15.2
- Xorg Server 1.19.5
- Nvidia Drivers 390.25
xorg.conf:
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "us"
Option "XkbModel" "thinkpad"
Option "XkbVariant" "altgr-intl"
EndSection
Section "Files"
ModulePath "/usr/lib64/opengl/nvidia"
ModulePath "/usr/lib64/xorg/modules"
EndSection
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia"
Inactive "intel"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:2:0:0"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
Option "AllowEmptyInitialConfiguration"
EndSection
Section "Device"
Identifier "intel"
Driver "modesetting"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
Xorg.6.log
[ 2993.820]
X.Org X Server 1.19.5
Release Date: 2017-10-12
[ 2993.820] X Protocol Version 11, Revision 0
[ 2993.820] Build Operating System: Linux 4.15.1-gentoo x86_64 Gentoo
[ 2993.820] Current Operating System: Linux ymir 4.15.2-gentoo #1 SMP Fri Feb 9 15:11:01 CET 2018 x86_64
[ 2993.820] Kernel command line: BOOT_IMAGE=/vmlinuz-4.15.2-gentoo root=/dev/nvme0n1p4 ro console=tty1 video=1920x1080
[ 2993.820] Build Date: 09 February 2018 03:23:48PM
[ 2993.820]
[ 2993.820] Current version of pixman: 0.34.0
[ 2993.820] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 2993.820] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 2993.820] (==) Log file: "/var/log/Xorg.6.log", Time: Fri Feb 9 16:55:40 2018
[ 2993.820] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 2993.820] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 2993.820] (==) ServerLayout "layout"
[ 2993.820] (**) |-->Screen "nvidia" (0)
[ 2993.820] (**) | |-->Monitor "<default monitor>"
[ 2993.820] (**) | |-->Device "nvidia"
[ 2993.820] (**) | |-->GPUDevice "intel"
[ 2993.820] (==) No monitor specified for screen "nvidia".
Using a default monitor configuration.
[ 2993.820] (**) |-->Inactive Device "intel"
[ 2993.820] (==) Automatically adding devices
[ 2993.820] (==) Automatically enabling devices
[ 2993.820] (==) Automatically adding GPU devices
[ 2993.820] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 2993.820] (==) FontPath set to:
/usr/share/fonts/misc/,
/usr/share/fonts/TTF/,
/usr/share/fonts/OTF/,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi/,
/usr/share/fonts/75dpi/
[ 2993.820] (**) ModulePath set to "/usr/lib64/opengl/nvidia,/usr/lib64/xorg/modules"
[ 2993.820] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 2993.820] (II) Loader magic: 0x55ef070f5d00
[ 2993.820] (II) Module ABI versions:
[ 2993.820] X.Org ANSI C Emulation: 0.4
[ 2993.820] X.Org Video Driver: 23.0
[ 2993.821] X.Org XInput driver : 24.1
[ 2993.821] X.Org Server Extension : 10.0
[ 2993.821] (--) using VT number 7
[ 2993.821] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 2993.822] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 2993.822] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 2993.841] (--) PCI:*(0:0:2:0) 8086:591b:17aa:505e rev 4, Mem @ 0xf2000000/16777216, 0xc0000000/536870912, I/O @ 0x0000e000/64, BIOS @ 0x????????/131072
[ 2993.841] (--) PCI: (0:2:0:0) 10de:134d:17aa:505e rev 162, Mem @ 0xf3000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000d000/128
[ 2993.841] (II) LoadModule: "glx"
[ 2993.841] (II) Loading /usr/lib64/opengl/nvidia/extensions/libglx.so
[ 2993.843] (II) Module glx: vendor="NVIDIA Corporation"
[ 2993.843] compiled for 4.0.2, module version = 1.0.0
[ 2993.843] Module class: X.Org Server Extension
[ 2993.843] (II) NVIDIA GLX Module 390.25 Wed Jan 24 19:23:51 PST 2018
[ 2993.843] (II) LoadModule: "nvidia"
[ 2993.843] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 2993.843] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 2993.843] Module class: X.Org Video Driver
[ 2993.843] (II) LoadModule: "modesetting"
[ 2993.844] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 2993.844] (II) Module modesetting: vendor="X.Org Foundation"
[ 2993.844] compiled for 1.19.5, module version = 1.19.5
[ 2993.844] Module class: X.Org Video Driver
[ 2993.844] ABI class: X.Org Video Driver, version 23.0
[ 2993.844] (II) NVIDIA dlloader X Driver 390.25 Wed Jan 24 18:57:05 PST 2018
[ 2993.844] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 2993.844] (II) NVIDIA X compatibility module for ABI 23.0 built from xorg-server-1.18.99.902
[ 2993.844] (II) X log verbosity: 6
[ 2993.844] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 2993.844] (II) Loading sub module "fb"
[ 2993.844] (II) LoadModule: "fb"
[ 2993.844] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 2993.844] (II) Module fb: vendor="X.Org Foundation"
[ 2993.844] compiled for 1.19.5, module version = 1.0.0
[ 2993.844] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2993.844] (II) Loading sub module "wfb"
[ 2993.844] (II) LoadModule: "wfb"
[ 2993.844] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 2993.844] (II) Module wfb: vendor="X.Org Foundation"
[ 2993.844] (II) Loading sub module "ramdac"
[ 2993.844] (II) LoadModule: "ramdac"
[ 2993.844] (II) Module "ramdac" already built-in
[ 2993.858] (II) modeset(G0): using drv /dev/dri/card0
[ 2993.859] (II) NVIDIA(0): Creating default Display subsection in Screen section
"nvidia" for depth/fbbpp 24/32
[ 2993.859] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 2993.859] (==) NVIDIA(0): RGB weight 888
[ 2993.859] (==) NVIDIA(0): Default visual is TrueColor
[ 2993.859] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 2993.859] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 2993.859] (==) NVIDIA(0): Using HW cursor
[ 2993.859] (**) NVIDIA(0): Enabling 2D acceleration
[ 2994.014] (II) NVIDIA(0): NVIDIA GPU GeForce 940MX (GM108-A) at PCI:2:0:0 (GPU-0)
[ 2994.014] (II) NVIDIA(0): GPU UUID: GPU-72de14d3-53fd-3c5d-139d-7205c4e26af7
[ 2994.014] (--) NVIDIA(0): Memory: 2097152 kBytes
[ 2994.014] (II) NVIDIA(0): Board ID: 0xe846
[ 2994.014] (II) NVIDIA(0): Chip SKU: 670
[ 2994.014] (II) NVIDIA(0): Chip SKU Mod: 2
[ 2994.014] (II) NVIDIA(0): Project: 2702
[ 2994.014] (II) NVIDIA(0): Project SKU: 0000
[ 2994.014] (II) NVIDIA(0): GPU RAM Type: GDDR5
[ 2994.014] (--) NVIDIA(0): VideoBIOS: 82.08.6c.00.10
[ 2994.014] (--) NVIDIA(0): Found 0 head on board
[ 2994.014] (II) NVIDIA(0): Supported display device(s):
[ 2994.014] (II) NVIDIA(0): Bus detected as PCI Express
[ 2994.014] (II) NVIDIA(0): Detected PCI Express Link width: 4X
[ 2994.014] (II) NVIDIA(0): SPS : 1
[ 2994.014] (II) NVIDIA(0): User configuration of GPU PowerMizer is supported
[ 2994.014] (II) NVIDIA(0): NoScanout X screen configured with resolution 640x480
[ 2994.014] (II) NVIDIA(0): (default)
[ 2994.014] (II) NVIDIA(0): Validated MetaModes:
[ 2994.014] (II) NVIDIA(0): MetaMode "NULL":
[ 2994.014] (II) NVIDIA(0): Size: 640 x 480
[ 2994.014] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 2994.014] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 2994.014] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 2994.014] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 2994.014] (==) modeset(G0): RGB weight 888
[ 2994.014] (==) modeset(G0): Default visual is TrueColor
[ 2994.014] (II) modeset(G0): No glamor support in the X Server
[ 2994.014] (II) modeset(G0): ShadowFB: preferred YES, enabled YES
[ 2994.014] (II) modeset(G0): Double-buffered shadow updates: off
[ 2994.016] (II) modeset(G0): Output eDP-1-1 has no monitor section
[ 2994.016] (II) modeset(G0): Output DP-1-1 has no monitor section
[ 2994.024] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 2994.024] (II) modeset(G0): Output DP-1-2 has no monitor section
[ 2994.032] (II) modeset(G0): Output HDMI-1-2 has no monitor section
[ 2994.032] (II) modeset(G0): Output DP-1-3 has no monitor section
[ 2994.042] (II) modeset(G0): Output HDMI-1-3 has no monitor section
[ 2994.042] (II) modeset(G0): Up to 7 crtcs needed for screen.
[ 2994.042] (II) modeset(G0): Allocated crtc nr. 0 to this screen.
[ 2994.042] (II) modeset(G0): Allocated crtc nr. 1 to this screen.
[ 2994.042] (II) modeset(G0): Allocated crtc nr. 2 to this screen.
[ 2994.043] (II) modeset(G0): EDID for output eDP-1-1
[ 2994.043] (II) modeset(G0): Manufacturer: AUO Model: 243d Serial#: 0
[ 2994.043] (II) modeset(G0): Year: 2016 Week: 0
[ 2994.043] (II) modeset(G0): EDID Version: 1.4
[ 2994.043] (II) modeset(G0): Digital Display Input
[ 2994.043] (II) modeset(G0): 6 bits per channel
[ 2994.043] (II) modeset(G0): Digital interface is DisplayPort
[ 2994.043] (II) modeset(G0): Max Image Size [cm]: horiz.: 31 vert.: 17
[ 2994.043] (II) modeset(G0): Gamma: 2.20
[ 2994.043] (II) modeset(G0): No DPMS capabilities specified
[ 2994.043] (II) modeset(G0): Supported color encodings: RGB 4:4:4
[ 2994.043] (II) modeset(G0): First detailed timing is preferred mode
[ 2994.043] (II) modeset(G0): Preferred mode is native pixel format and refresh rate
[ 2994.043] (II) modeset(G0): redX: 0.568 redY: 0.342 greenX: 0.344 greenY: 0.580
[ 2994.043] (II) modeset(G0): blueX: 0.158 blueY: 0.112 whiteX: 0.313 whiteY: 0.329
[ 2994.043] (II) modeset(G0): Manufacturer's mask: 0
[ 2994.043] (II) modeset(G0): Supported detailed timing:
[ 2994.043] (II) modeset(G0): clock: 149.8 MHz Image Size: 309 x 173 mm
[ 2994.043] (II) modeset(G0): h_active: 1920 h_sync: 1968 h_sync_end 2068 h_blank_end 2228 h_border: 0
[ 2994.043] (II) modeset(G0): v_active: 1080 v_sync: 1083 v_sync_end 1084 v_blanking: 1120 v_border: 0
[ 2994.043] (II) modeset(G0): clock: 119.8 MHz Image Size: 309 x 173 mm
[ 2994.043] (II) modeset(G0): AUO
[ 2994.043] (II) modeset(G0): B140HAN02.4
[ 2994.043] (II) modeset(G0): EDID (in hex):
[ 2994.043] (II) modeset(G0): 00ffffffffffff0006af3d2400000000
[ 2994.043] (II) modeset(G0): 001a0104951f117802a2b59157589428
[ 2994.043] (II) modeset(G0): 1c505400000001010101010101010101
[ 2994.043] (II) modeset(G0): 010101010101843a8034713828403064
[ 2994.043] (II) modeset(G0): 310035ad10000018d02e803471382840
[ 2994.043] (II) modeset(G0): 3064310035ad10000018000000fe0041
[ 2994.043] (II) modeset(G0): 554f0a202020202020202020000000fe
[ 2994.044] (II) modeset(G0): 004231343048414e30322e34200a00e4
[ 2994.044] (II) modeset(G0): Printing probed modes for output eDP-1-1
[ 2994.044] (II) modeset(G0): Modeline "1920x1080"x60.0 149.80 1920 1968 2068 2228 1080 1083 1084 1120 -hsync -vsync (67.2 kHz eP)
[ 2994.044] (II) modeset(G0): Modeline "1920x1080"x48.0 119.84 1920 1968 2068 2228 1080 1083 1084 1120 -hsync -vsync (53.8 kHz e)
[ 2994.044] (II) modeset(G0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 2994.044] (II) modeset(G0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 2994.044] (II) modeset(G0): EDID for output DP-1-1
[ 2994.053] (II) modeset(G0): EDID for output HDMI-1-1
[ 2994.053] (II) modeset(G0): EDID for output DP-1-2
[ 2994.062] (II) modeset(G0): EDID for output HDMI-1-2
[ 2994.062] (II) modeset(G0): EDID for output DP-1-3
[ 2994.072] (II) modeset(G0): EDID for output HDMI-1-3
[ 2994.072] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 2994.072] (==) modeset(G0): DPI set to (96, 96)
[ 2994.072] (II) Loading sub module "fb"
[ 2994.072] (II) LoadModule: "fb"
[ 2994.072] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 2994.072] (II) Module fb: vendor="X.Org Foundation"
[ 2994.072] compiled for 1.19.5, module version = 1.0.0
[ 2994.072] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2994.072] (II) Loading sub module "shadow"
[ 2994.072] (II) LoadModule: "shadow"
[ 2994.072] (II) Loading /usr/lib64/xorg/modules/libshadow.so
[ 2994.073] (II) Module shadow: vendor="X.Org Foundation"
[ 2994.073] compiled for 1.19.5, module version = 1.1.0
[ 2994.073] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2994.073] (--) Depth 24 pixmap format is 32 bpp
[ 2994.073] (==) modeset(G0): Backing store enabled
[ 2994.073] (==) modeset(G0): Silken mouse enabled
[ 2994.073] (II) modeset(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 2994.151] (==) modeset(G0): DPMS enabled
[ 2994.151] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[ 2994.152] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 2994.152] (II) NVIDIA: access.
[ 2994.157] (II) NVIDIA(0): kernel module enabled successfully
[ 2994.157] (II) NVIDIA(0): GPU initialized
[ 2994.158] (II) NVIDIA(0): ACPI: AC state file path: /sys/class/power_supply/AC/online
[ 2994.158] (II) NVIDIA(0): ACPI: the system is running on AC power
[ 2994.159] (WW) NVIDIA(0): ACPI: failed to determine the system's docking state: Unable
[ 2994.159] (WW) NVIDIA(0): to find /sys/devices/platform/dock.*/docked file. Kernel
[ 2994.159] (WW) NVIDIA(0): version may be less than 2.6.20 or dock.ko driver may not
[ 2994.159] (WW) NVIDIA(0): be present
[ 2994.162] (==) NVIDIA(0): Using 8388608 bytes for software rendering cache
[ 2994.193] (II) NVIDIA(0): Setting mode "NULL"
[ 2994.193] (II) NVIDIA(0): First mode initialized
[ 2994.198] (II) NVIDIA(0): Initialized OpenGL Acceleration
[ 2994.198] (II) NVIDIA(0): Visuals set up
[ 2994.198] (II) NVIDIA(0): Pixmap depths set up
[ 2994.198] (II) NVIDIA(0): GLX visuals set up
[ 2994.199] (II) NVIDIA(0): Framebuffer set up
[ 2994.199] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 2994.199] (II) NVIDIA(0): Initialized X Rendering Acceleration
[ 2994.199] (==) NVIDIA(0): Backing store enabled
[ 2994.199] (==) NVIDIA(0): Silken mouse enabled
[ 2994.199] (II) NVIDIA(0): Default colormap initialized.
[ 2994.199] (II) NVIDIA(0): Palette loaded
[ 2994.199] (==) NVIDIA(0): DPMS enabled
[ 2994.199] (II) Loading sub module "dri2"
[ 2994.199] (II) LoadModule: "dri2"
[ 2994.199] (II) Module "dri2" already built-in
[ 2994.199] (II) NVIDIA(0): [DRI2] Setup complete
[ 2994.199] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 2994.199] (II) NVIDIA(0): Screen initialization complete
[ 2994.199] (--) RandR disabled
[ 2994.201] (II) Initializing extension GLX
[ 2994.202] (II) Indirect GLX disabled.
[ 2994.537] (II) modeset(G0): Damage tracking initialized
[ 2994.582] (II) XKB: Reusing cached keymap
[ 2994.588] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 2994.588] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 2994.588] (**) Power Button: Applying InputClass "joystick-all"
[ 2994.588] (**) Power Button: Applying InputClass "system-keyboard"
[ 2994.588] (II) LoadModule: "evdev"
[ 2994.589] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[ 2994.589] (II) Module evdev: vendor="X.Org Foundation"
[ 2994.589] compiled for 1.19.5, module version = 2.10.5
[ 2994.589] Module class: X.Org XInput Driver
[ 2994.589] ABI class: X.Org XInput driver, version 24.1
[ 2994.589] (II) Using input driver 'evdev' for 'Power Button'
[ 2994.589] Option "_source" "server/udev"
[ 2994.589] Option "name" "Power Button"
[ 2994.589] Option "path" "/dev/input/event2"
[ 2994.589] Option "device" "/dev/input/event2"
[ 2994.589] Option "major" "13"
[ 2994.589] Option "minor" "66"
[ 2994.589] Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 2994.589] Option "driver" "evdev"
[ 2994.589] Option "MapButton1" "button=1"
[ 2994.589] Option "MapButton2" "button=2"
[ 2994.589] Option "MapButton3" "button=3"
[ 2994.589] Option "MapAxis1" "mode=relative axis=+1x deadzone=5000"
[ 2994.589] Option "MapAxis2" "mode=relative axis=+1y deadzone=5000"
[ 2994.589] Option "MapAxis3" "mode=relative axis=+1zx deadzone=5000"
[ 2994.589] Option "MapAxis4" "mode=relative axis=+1zy deadzone=5000"
[ 2994.589] Option "MapAxis5" "mode=accelerated axis=+1x deadzone=5000"
[ 2994.589] Option "MapAxis6" "mode=accelerated axis=+1y deadzone=5000"
[ 2994.589] Option "XkbLayout" "us"
[ 2994.589] Option "XkbModel" "thinkpad"
[ 2994.589] Option "XkbVariant" "altgr-intl"
[ 2994.589] (**) Power Button: always reports core events
[ 2994.589] (**) evdev: Power Button: Device: "/dev/input/event2"
[ 2994.589] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 2994.589] (--) evdev: Power Button: Found keys
[ 2994.589] (II) evdev: Power Button: Configuring as keyboard
[ 2994.589] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 2994.589] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 2994.589] (**) Option "xkb_rules" "evdev"
[ 2994.589] (**) Option "xkb_model" "thinkpad"
[ 2994.589] (**) Option "xkb_layout" "us"
[ 2994.589] (**) Option "xkb_variant" "altgr-intl"
[ 2994.600] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[ 2994.600] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 2994.600] (**) Video Bus: Applying InputClass "joystick-all"
[ 2994.600] (**) Video Bus: Applying InputClass "system-keyboard"
[ 2994.600] (II) Using input driver 'evdev' for 'Video Bus'
[ 2994.600] Option "_source" "server/udev"
[ 2994.600] Option "name" "Video Bus"
[ 2994.600] Option "path" "/dev/input/event7"
[ 2994.600] Option "device" "/dev/input/event7"
[ 2994.600] Option "major" "13"
[ 2994.600] Option "minor" "71"
[ 2994.600] Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input9/event7"
[ 2994.600] Option "driver" "evdev"
[ 2994.600] Option "MapButton1" "button=1"
[ 2994.600] Option "MapButton2" "button=2"
[ 2994.600] Option "MapButton3" "button=3"
[ 2994.600] Option "MapAxis1" "mode=relative axis=+1x deadzone=5000"
[ 2994.600] Option "MapAxis2" "mode=relative axis=+1y deadzone=5000"
[ 2994.600] Option "MapAxis3" "mode=relative axis=+1zx deadzone=5000"
[ 2994.600] Option "MapAxis4" "mode=relative axis=+1zy deadzone=5000"
[ 2994.600] Option "MapAxis5" "mode=accelerated axis=+1x deadzone=5000"
[ 2994.600] Option "MapAxis6" "mode=accelerated axis=+1y deadzone=5000"
[ 2994.600] Option "XkbLayout" "us"
[ 2994.600] Option "XkbModel" "thinkpad"
[ 2994.600] Option "XkbVariant" "altgr-intl"
[ 2994.600] (**) Video Bus: always reports core events
[ 2994.600] (**) evdev: Video Bus: Device: "/dev/input/event7"
[ 2994.600] (--) evdev: Video Bus: Vendor 0 Product 0x6
[ 2994.600] (--) evdev: Video Bus: Found keys
[ 2994.600] (II) evdev: Video Bus: Configuring as keyboard
[ 2994.600] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input9/event7"
[ 2994.600] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 2994.600] (**) Option "xkb_rules" "evdev"
[ 2994.600] (**) Option "xkb_model" "thinkpad"
[ 2994.600] (**) Option "xkb_layout" "us"
[ 2994.600] (**) Option "xkb_variant" "altgr-intl"
[ 2994.600] (II) XKB: Reusing cached keymap
[ 2994.600] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[ 2994.600] Option "path" "/dev/input/event6"
[ 2994.600] Option "device" "/dev/input/event6"
[ 2994.600] Option "minor" "70"
[ 2994.600] Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:04/LNXVIDEO:00/input/input8/event6"
[ 2994.600] (**) evdev: Video Bus: Device: "/dev/input/event6"
[ 2994.600] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:04/LNXVIDEO:00/input/input8/event6"
[ 2994.600] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 2994.601] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 2994.601] (**) Lid Switch: Applying InputClass "joystick-all"
[ 2994.601] (II) No input driver specified, ignoring this device.
[ 2994.601] (II) This device may have been added with another device file.
[ 2994.601] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 2994.601] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 2994.601] (**) Sleep Button: Applying InputClass "joystick-all"
[ 2994.601] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 2994.601] (II) Using input driver 'evdev' for 'Sleep Button'
[ 2994.601] Option "_source" "server/udev"
[ 2994.601] Option "name" "Sleep Button"
[ 2994.601] Option "path" "/dev/input/event0"
[ 2994.601] Option "device" "/dev/input/event0"
[ 2994.601] Option "major" "13"
[ 2994.601] Option "minor" "64"
[ 2994.601] Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 2994.601] Option "driver" "evdev"
[ 2994.601] Option "MapButton1" "button=1"
[ 2994.601] Option "MapButton2" "button=2"
[ 2994.601] Option "MapButton3" "button=3"
[ 2994.601] Option "MapAxis1" "mode=relative axis=+1x deadzone=5000"
[ 2994.601] Option "MapAxis2" "mode=relative axis=+1y deadzone=5000"
[ 2994.601] Option "MapAxis3" "mode=relative axis=+1zx deadzone=5000"
[ 2994.601] Option "MapAxis4" "mode=relative axis=+1zy deadzone=5000"
[ 2994.601] Option "MapAxis5" "mode=accelerated axis=+1x deadzone=5000"
[ 2994.601] Option "MapAxis6" "mode=accelerated axis=+1y deadzone=5000"
[ 2994.601] Option "XkbLayout" "us"
[ 2994.601] Option "XkbModel" "thinkpad"
[ 2994.601] Option "XkbVariant" "altgr-intl"
[ 2994.601] (**) Sleep Button: always reports core events
[ 2994.601] (**) evdev: Sleep Button: Device: "/dev/input/event0"
[ 2994.601] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[ 2994.601] (--) evdev: Sleep Button: Found keys
[ 2994.601] (II) evdev: Sleep Button: Configuring as keyboard
[ 2994.601] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 2994.601] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 2994.601] (**) Option "xkb_rules" "evdev"
[ 2994.601] (**) Option "xkb_model" "thinkpad"
[ 2994.601] (**) Option "xkb_layout" "us"
[ 2994.601] (**) Option "xkb_variant" "altgr-intl"
[ 2994.601] (II) XKB: Reusing cached keymap
[ 2994.602] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event9)
[ 2994.602] (**) HDA Digital PCBeep: Applying InputClass "joystick-all"
[ 2994.602] (II) No input driver specified, ignoring this device.
[ 2994.602] (II) This device may have been added with another device file.
[ 2994.602] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event10)
[ 2994.602] (**) HDA Intel PCH Mic: Applying InputClass "joystick-all"
[ 2994.602] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event11)
[ 2994.602] (**) HDA Intel PCH Headphone: Applying InputClass "joystick-all"
[ 2994.602] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event12)
[ 2994.602] (**) HDA Intel PCH HDMI/DP,pcm=3: Applying InputClass "joystick-all"
[ 2994.602] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event13)
[ 2994.602] (**) HDA Intel PCH HDMI/DP,pcm=7: Applying InputClass "joystick-all"
[ 2994.603] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event14)
[ 2994.603] (**) HDA Intel PCH HDMI/DP,pcm=8: Applying InputClass "joystick-all"
[ 2994.603] (II) No input driver specified, ignoring this device.
[ 2994.603] (II) This device may have been added with another device file.
[ 2994.603] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event15)
[ 2994.603] (**) HDA Intel PCH HDMI/DP,pcm=9: Applying InputClass "joystick-all"
[ 2994.603] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event16)
[ 2994.603] (**) HDA Intel PCH HDMI/DP,pcm=10: Applying InputClass "joystick-all"
[ 2994.603] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 2994.603] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 2994.603] (**) AT Translated Set 2 keyboard: Applying InputClass "joystick-all"
[ 2994.603] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 2994.603] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 2994.603] Option "_source" "server/udev"
[ 2994.603] Option "name" "AT Translated Set 2 keyboard"
[ 2994.603] Option "path" "/dev/input/event4"
[ 2994.603] Option "device" "/dev/input/event4"
[ 2994.603] Option "major" "13"
[ 2994.603] Option "minor" "68"
[ 2994.603] Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event4"
[ 2994.603] Option "driver" "evdev"
[ 2994.603] Option "MapButton1" "button=1"
[ 2994.603] Option "MapButton2" "button=2"
[ 2994.603] Option "MapButton3" "button=3"
[ 2994.603] Option "MapAxis1" "mode=relative axis=+1x deadzone=5000"
[ 2994.603] Option "MapAxis2" "mode=relative axis=+1y deadzone=5000"
[ 2994.603] Option "MapAxis3" "mode=relative axis=+1zx deadzone=5000"
[ 2994.603] Option "MapAxis4" "mode=relative axis=+1zy deadzone=5000"
[ 2994.603] Option "MapAxis5" "mode=accelerated axis=+1x deadzone=5000"
[ 2994.603] Option "MapAxis6" "mode=accelerated axis=+1y deadzone=5000"
[ 2994.603] Option "XkbLayout" "us"
[ 2994.603] Option "XkbModel" "thinkpad"
[ 2994.603] Option "XkbVariant" "altgr-intl"
[ 2994.603] (**) AT Translated Set 2 keyboard: always reports core events
[ 2994.603] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event4"
[ 2994.603] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 2994.603] (--) evdev: AT Translated Set 2 keyboard: Found keys
[ 2994.603] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 2994.603] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event4"
[ 2994.603] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[ 2994.603] (**) Option "xkb_rules" "evdev"
[ 2994.603] (**) Option "xkb_model" "thinkpad"
[ 2994.603] (**) Option "xkb_layout" "us"
[ 2994.603] (**) Option "xkb_variant" "altgr-intl"
[ 2994.603] (II) XKB: Reusing cached keymap
[ 2994.604] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event8)
[ 2994.604] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 2994.604] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "joystick-all"
[ 2994.604] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[ 2994.604] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Default clickpad buttons"
[ 2994.604] (II) LoadModule: "synaptics"
[ 2994.604] (II) Loading /usr/lib64/xorg/modules/input/synaptics_drv.so
[ 2994.604] (II) Module synaptics: vendor="X.Org Foundation"
[ 2994.604] compiled for 1.19.5, module version = 1.9.0
[ 2994.604] Module class: X.Org XInput Driver
[ 2994.604] ABI class: X.Org XInput driver, version 24.1
[ 2994.604] (II) Using input driver 'synaptics' for 'SynPS/2 Synaptics TouchPad'
[ 2994.604] Option "_source" "server/udev"
[ 2994.604] Option "name" "SynPS/2 Synaptics TouchPad"
[ 2994.604] Option "path" "/dev/input/event8"
[ 2994.604] Option "device" "/dev/input/event8"
[ 2994.604] Option "major" "13"
[ 2994.604] Option "minor" "72"
[ 2994.604] Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input6/event8"
[ 2994.604] Option "driver" "synaptics"
[ 2994.604] Option "MapButton1" "button=1"
[ 2994.604] Option "MapButton2" "button=2"
[ 2994.604] Option "MapButton3" "button=3"
[ 2994.604] Option "MapAxis1" "mode=relative axis=+1x deadzone=5000"
[ 2994.604] Option "MapAxis2" "mode=relative axis=+1y deadzone=5000"
[ 2994.604] Option "MapAxis3" "mode=relative axis=+1zx deadzone=5000"
[ 2994.604] Option "MapAxis4" "mode=relative axis=+1zy deadzone=5000"
[ 2994.604] Option "MapAxis5" "mode=accelerated axis=+1x deadzone=5000"
[ 2994.604] Option "MapAxis6" "mode=accelerated axis=+1y deadzone=5000"
[ 2994.604] Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
[ 2994.604] Option "SecondarySoftButtonAreas" "58% 0 0 15% 42% 58% 0 15%"
[ 2994.604] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 2994.604] (**) Option "Device" "/dev/input/event8"
[ 2994.621] (**) Option "Device" "/dev/input/event8"
[ 2994.621] port opened successfully
[ 2994.621] (II) synaptics: SynPS/2 Synaptics TouchPad: found clickpad property
[ 2994.621] (--) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1266 - 5676 (res 45)
[ 2994.621] (--) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1096 - 4758 (res 68)
[ 2994.621] (--) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[ 2994.621] (--) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[ 2994.621] (--) synaptics: SynPS/2 Synaptics TouchPad: buttons: left double triple
[ 2994.621] (--) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[ 2994.621] (**) Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
[ 2994.621] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 2994.621] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 2994.637] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input6/event8"
[ 2994.637] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 11)
[ 2994.637] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[ 2994.637] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MaxSpeed is now 1.75
[ 2994.637] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) AccelFactor is now 0.035
[ 2994.637] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[ 2994.637] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[ 2994.637] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 2994.637] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 2994.637] (**) Option "Device" "/dev/input/event8"
[ 2994.637] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 2994.637] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[ 2994.637] (**) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass "touchpad ignore duplicates"
[ 2994.638] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/event17)
[ 2994.638] (**) TPPS/2 IBM TrackPoint: Applying InputClass "evdev pointer catchall"
[ 2994.638] (**) TPPS/2 IBM TrackPoint: Applying InputClass "joystick-all"
[ 2994.638] (II) Using input driver 'evdev' for 'TPPS/2 IBM TrackPoint'
[ 2994.638] Option "_source" "server/udev"
[ 2994.638] Option "name" "TPPS/2 IBM TrackPoint"
[ 2994.638] Option "path" "/dev/input/event17"
[ 2994.638] Option "device" "/dev/input/event17"
[ 2994.638] Option "major" "13"
[ 2994.638] Option "minor" "81"
[ 2994.638] Option "config_info" "udev:/sys/devices/platform/i8042/serio1/serio2/input/input10/event17"
[ 2994.638] Option "driver" "evdev"
[ 2994.638] Option "MapButton1" "button=1"
[ 2994.638] Option "MapButton2" "button=2"
[ 2994.638] Option "MapButton3" "button=3"
[ 2994.638] Option "MapAxis1" "mode=relative axis=+1x deadzone=5000"
[ 2994.638] Option "MapAxis2" "mode=relative axis=+1y deadzone=5000"
[ 2994.638] Option "MapAxis3" "mode=relative axis=+1zx deadzone=5000"
[ 2994.638] Option "MapAxis4" "mode=relative axis=+1zy deadzone=5000"
[ 2994.638] Option "MapAxis5" "mode=accelerated axis=+1x deadzone=5000"
[ 2994.638] Option "MapAxis6" "mode=accelerated axis=+1y deadzone=5000"
[ 2994.638] (**) TPPS/2 IBM TrackPoint: always reports core events
[ 2994.638] (**) evdev: TPPS/2 IBM TrackPoint: Device: "/dev/input/event17"
[ 2994.638] (--) evdev: TPPS/2 IBM TrackPoint: Vendor 0x2 Product 0xa
[ 2994.638] (--) evdev: TPPS/2 IBM TrackPoint: Found 3 mouse buttons
[ 2994.638] (--) evdev: TPPS/2 IBM TrackPoint: Found relative axes
[ 2994.638] (--) evdev: TPPS/2 IBM TrackPoint: Found x and y relative axes
[ 2994.638] (II) evdev: TPPS/2 IBM TrackPoint: Configuring as mouse
[ 2994.638] (**) evdev: TPPS/2 IBM TrackPoint: YAxisMapping: buttons 4 and 5
[ 2994.638] (**) evdev: TPPS/2 IBM TrackPoint: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 2994.638] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/serio2/input/input10/event17"
[ 2994.638] (II) XINPUT: Adding extended input device "TPPS/2 IBM TrackPoint" (type: MOUSE, id 12)
[ 2994.638] (II) evdev: TPPS/2 IBM TrackPoint: initialized for relative axes.
[ 2994.638] (**) TPPS/2 IBM TrackPoint: (accel) keeping acceleration scheme 1
[ 2994.638] (**) TPPS/2 IBM TrackPoint: (accel) acceleration profile 0
[ 2994.638] (**) TPPS/2 IBM TrackPoint: (accel) acceleration factor: 2.000
[ 2994.638] (**) TPPS/2 IBM TrackPoint: (accel) acceleration threshold: 4
[ 2994.638] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/mouse1)
[ 2994.638] (II) No input driver specified, ignoring this device.
[ 2994.638] (II) This device may have been added with another device file.
[ 2994.639] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[ 2994.639] (**) PC Speaker: Applying InputClass "joystick-all"
[ 2994.639] (II) No input driver specified, ignoring this device.
[ 2994.639] (II) This device may have been added with another device file.
[ 2994.639] (II) config/udev: Adding input device ThinkPad Extra Buttons (/dev/input/event5)
[ 2994.639] (**) ThinkPad Extra Buttons: Applying InputClass "evdev keyboard catchall"
[ 2994.639] (**) ThinkPad Extra Buttons: Applying InputClass "joystick-all"
[ 2994.639] (**) ThinkPad Extra Buttons: Applying InputClass "system-keyboard"
[ 2994.639] (II) Using input driver 'evdev' for 'ThinkPad Extra Buttons'
[ 2994.639] Option "_source" "server/udev"
[ 2994.639] Option "name" "ThinkPad Extra Buttons"
[ 2994.639] Option "path" "/dev/input/event5"
[ 2994.639] Option "device" "/dev/input/event5"
[ 2994.639] Option "major" "13"
[ 2994.639] Option "minor" "69"
[ 2994.639] Option "config_info" "udev:/sys/devices/platform/thinkpad_acpi/input/input7/event5"
[ 2994.639] Option "driver" "evdev"
[ 2994.639] Option "MapButton1" "button=1"
[ 2994.639] Option "MapButton2" "button=2"
[ 2994.639] Option "MapButton3" "button=3"
[ 2994.639] Option "MapAxis1" "mode=relative axis=+1x deadzone=5000"
[ 2994.639] Option "MapAxis2" "mode=relative axis=+1y deadzone=5000"
[ 2994.639] Option "MapAxis3" "mode=relative axis=+1zx deadzone=5000"
[ 2994.639] Option "MapAxis4" "mode=relative axis=+1zy deadzone=5000"
[ 2994.639] Option "MapAxis5" "mode=accelerated axis=+1x deadzone=5000"
[ 2994.639] Option "MapAxis6" "mode=accelerated axis=+1y deadzone=5000"
[ 2994.639] Option "XkbLayout" "us"
[ 2994.639] Option "XkbModel" "thinkpad"
[ 2994.639] Option "XkbVariant" "altgr-intl"
[ 2994.639] (**) ThinkPad Extra Buttons: always reports core events
[ 2994.639] (**) evdev: ThinkPad Extra Buttons: Device: "/dev/input/event5"
[ 2994.639] (--) evdev: ThinkPad Extra Buttons: Vendor 0x17aa Product 0x5054
[ 2994.639] (--) evdev: ThinkPad Extra Buttons: Found keys
[ 2994.639] (II) evdev: ThinkPad Extra Buttons: Configuring as keyboard
[ 2994.639] (**) Option "config_info" "udev:/sys/devices/platform/thinkpad_acpi/input/input7/event5"
[ 2994.639] (II) XINPUT: Adding extended input device "ThinkPad Extra Buttons" (type: KEYBOARD, id 13)
[ 2994.639] (**) Option "xkb_rules" "evdev"
[ 2994.639] (**) Option "xkb_model" "thinkpad"
[ 2994.639] (**) Option "xkb_layout" "us"
[ 2994.639] (**) Option "xkb_variant" "altgr-intl"
[ 2994.639] (II) XKB: Reusing cached keymap
[ 2994.651] (II) NVIDIA(0): XRRSetScreenSize(screen:0 size:1920x1080 sizeMM:652x366)
[ 2994.651] (II) NVIDIA(0): NoScanout X screen configured with resolution 1920x1080 (from
[ 2994.651] (II) NVIDIA(0): the Resize and Rotate extension)
[ 2994.655] (EE) modeset(G0): failed to set mode: No space left on device
[ 2994.655] (II) NVIDIA(0): XRRSetScreenSize(screen:0 size:640x480 sizeMM:217x163)
[ 2994.655] (II) NVIDIA(0): NoScanout X screen configured with resolution 640x480 (from
[ 2994.655] (II) NVIDIA(0): the Resize and Rotate extension)
[ 3044.626] (II) NVIDIA(0): Setting mode "NULL"
[ 3044.626] (II) NVIDIA(0): ACPI: AC state file path: /sys/class/power_supply/AC/online
[ 3044.626] (II) NVIDIA(0): ACPI: the system is running on AC power
[ 3044.627] (WW) NVIDIA(0): ACPI: failed to determine the system's docking state: Unable
[ 3044.627] (WW) NVIDIA(0): to find /sys/devices/platform/dock.*/docked file. Kernel
[ 3044.627] (WW) NVIDIA(0): version may be less than 2.6.20 or dock.ko driver may not
[ 3044.627] (WW) NVIDIA(0): be present
[ 3045.845] (**) Option "Device" "/dev/input/event8"
[ 3045.845] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 3152.783] (II) NVIDIA(0): Setting mode "NULL"
[ 3152.783] (II) NVIDIA(0): ACPI: AC state file path: /sys/class/power_supply/AC/online
[ 3152.783] (II) NVIDIA(0): ACPI: the system is running on AC power
[ 3152.784] (WW) NVIDIA(0): ACPI: failed to determine the system's docking state: Unable
[ 3152.784] (WW) NVIDIA(0): to find /sys/devices/platform/dock.*/docked file. Kernel
[ 3152.784] (WW) NVIDIA(0): version may be less than 2.6.20 or dock.ko driver may not
[ 3152.784] (WW) NVIDIA(0): be present
[ 3154.003] (**) Option "Device" "/dev/input/event8"
[ 3154.003] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
Commands run during startup of X. I intentionally dumped It down to the bare minimum Xserver with only twm starting and the commands Nvidia wants to be run:
2018-02-09T16:55:41,380716080+01:00 X-Server Start (using /home/mageta/.xinitrc)
+ export LANG=en_US
+ LANG=en_US
+ export LC_ALL=en_US
+ LC_ALL=en_US
+ export LANGUAGE=en_US
+ LANGUAGE=en_US
+ export LC_CTYPE=en_US
+ LC_CTYPE=en_US
+ xrandr --setprovideroutputsource modesetting NVIDIA-0
+ xrandr --auto
xrandr: Configure crtc 0 failed
+ xrandr --verbose
Screen 0: minimum 8 x 8, current 640 x 480, maximum 16384 x 16384
eDP-1-1 connected (normal left inverted right x axis y axis)
Identifier: 0x42
Timestamp: 2994656
Subpixel: unknown
Clones:
CRTCs: 0 1 2
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
PRIME Synchronization: 1
supported: 0, 1
scaling mode: Full aspect
supported: Full, Center, Full aspect
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
audio: auto
supported: force-dvi, off, auto, on
non-desktop: 0
range: (0, 1)
link-status: Good
supported: Good, Bad
1920x1080 (0x4a) 149.800MHz -HSync -VSync +preferred
h: width 1920 start 1968 end 2068 total 2228 skew 0 clock 67.24KHz
v: height 1080 start 1083 end 1084 total 1120 clock 60.03Hz
1920x1080 (0x4b) 119.840MHz -HSync -VSync
h: width 1920 start 1968 end 2068 total 2228 skew 0 clock 53.79KHz
v: height 1080 start 1083 end 1084 total 1120 clock 48.03Hz
1400x1050 (0x4c) 122.000MHz +HSync +VSync
h: width 1400 start 1488 end 1640 total 1880 skew 0 clock 64.89KHz
v: height 1050 start 1052 end 1064 total 1082 clock 59.98Hz
1280x1024 (0x4d) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x960 (0x4e) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1024x768 (0x4f) 133.475MHz -HSync +VSync DoubleScan
h: width 1024 start 1100 end 1212 total 1400 skew 0 clock 95.34KHz
v: height 768 start 768 end 770 total 794 clock 60.04Hz
1024x768 (0x50) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
960x720 (0x51) 117.000MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1128 total 1300 skew 0 clock 90.00KHz
v: height 720 start 720 end 722 total 750 clock 60.00Hz
928x696 (0x52) 109.150MHz -HSync +VSync DoubleScan
h: width 928 start 976 end 1088 total 1264 skew 0 clock 86.35KHz
v: height 696 start 696 end 698 total 719 clock 60.05Hz
896x672 (0x53) 102.400MHz -HSync +VSync DoubleScan
h: width 896 start 960 end 1060 total 1224 skew 0 clock 83.66KHz
v: height 672 start 672 end 674 total 697 clock 60.01Hz
800x600 (0x54) 81.000MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 75.00KHz
v: height 600 start 600 end 602 total 625 clock 60.00Hz
800x600 (0x55) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x56) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
700x525 (0x57) 61.000MHz +HSync +VSync DoubleScan
h: width 700 start 744 end 820 total 940 skew 0 clock 64.89KHz
v: height 525 start 526 end 532 total 541 clock 59.98Hz
640x512 (0x58) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 664 end 720 total 844 skew 0 clock 63.98KHz
v: height 512 start 512 end 514 total 533 clock 60.02Hz
640x480 (0x59) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 688 end 744 total 900 skew 0 clock 60.00KHz
v: height 480 start 480 end 482 total 500 clock 60.00Hz
640x480 (0x5a) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
512x384 (0x5b) 32.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 672 skew 0 clock 48.36KHz
v: height 384 start 385 end 388 total 403 clock 60.00Hz
400x300 (0x5c) 20.000MHz +HSync +VSync DoubleScan
h: width 400 start 420 end 484 total 528 skew 0 clock 37.88KHz
v: height 300 start 300 end 302 total 314 clock 60.32Hz
400x300 (0x5d) 18.000MHz +HSync +VSync DoubleScan
h: width 400 start 412 end 448 total 512 skew 0 clock 35.16KHz
v: height 300 start 300 end 301 total 312 clock 56.34Hz
320x240 (0x5e) 12.587MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 376 total 400 skew 0 clock 31.47KHz
v: height 240 start 245 end 246 total 262 clock 60.05Hz
DP-1-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x43
Timestamp: 2994656
Subpixel: unknown
Clones: HDMI-1-1
CRTCs: 0 1 2
filter:
supported: 0, 1
audio: auto
non-desktop: 0
range: (0, 1)
link-status: Good
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x44
Timestamp: 2994656
Subpixel: unknown
Clones: DP-1-1
CRTCs: 0 1 2
filter:
supported: 0, 1
aspect ratio: Automatic
supported: Automatic, 4:3, 16:9
audio: auto
non-desktop: 0
range: (0, 1)
link-status: Good
DP-1-2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x45
Timestamp: 2994656
Subpixel: unknown
Clones: HDMI-1-2
CRTCs: 0 1 2
filter:
supported: 0, 1
audio: auto
non-desktop: 0
range: (0, 1)
link-status: Good
HDMI-1-2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x46
Timestamp: 2994656
Subpixel: unknown
Clones: DP-1-2
CRTCs: 0 1 2
filter:
supported: 0, 1
audio: auto
non-desktop: 0
range: (0, 1)
link-status: Good
DP-1-3 disconnected (normal left inverted right x axis y axis)
Identifier: 0x47
Timestamp: 2994656
Subpixel: unknown
Clones:
CRTCs: 0 1 2
filter:
supported: 0, 1
audio: auto
non-desktop: 0
range: (0, 1)
link-status: Good
HDMI-1-3 disconnected (normal left inverted right x axis y axis)
Identifier: 0x48
Timestamp: 2994656
Subpixel: unknown
Clones:
CRTCs: 0 1 2
filter:
supported: 0, 1
audio: auto
non-desktop: 0
range: (0, 1)
link-status: Good
+ xrandr --listmonitors
Monitors: 0
+ xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x1f8 cap: 0x1, Source Output crtcs: 0 outputs: 0 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x49 cap: 0x2, Sink Output crtcs: 3 outputs: 7 associated providers: 1 name:modesetting
+ sysresources=/etc/X11/xinit/Xresources
+ sysmodmap=/etc/X11/xinit/Xmodmap
+ userresources=/home/mageta/.Xresources
+ twm
+ usermodmap=/home/mageta/.Xmodmap
+ '[' -f /etc/X11/xinit/Xresources ']'
+ '[' -f /etc/X11/xinit/Xmodmap ']'
+ '[' -f /home/mageta/.Xresources ']'
+ xrdb -merge /home/mageta/.Xresources
+ '[' -f /home/mageta/.Xmodmap ']'
+ xmodmap /home/mageta/.Xmodmap
+ xsetroot -solid black
+ xclock -geometry 50x50-1+1
+ exec xterm -geometry 80x66+0+0 -name login
+ xterm -geometry 80x20+494-0
+ xterm -geometry 80x50+494+51
XIO: fatal IO error 0 (Success) on X server ":6"
after 587 requests (587 known processed) with 0 events remaining.
xterm: fatal IO error 11 (Resource temporarily unavailable) or KillClient on X server ":6"
Here is the debug-file: http://mageta.org/download/nvidia-bug-report.log.gz
