I am still experiencing the log flood of messages as I did with 390.25. Also, “mapping multiple BARs”.
Nvidia Persistenced is enabled.Attached is log file.
ryan@xmg:~$ dmesg | grep -i nvidia
[ 1.643815] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 390.42 Sat Mar 3 04:10:22 PST 2018 (using threaded interrupts)
[ 1.645558] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 390.42 Sat Mar 3 03:30:48 PST 2018
[ 1.655087] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 242
[ 1.656240] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 2.440637] caller _nv029941rm+0x57/0x90 [nvidia] mapping multiple BARs
[ 2.664018] nvidia-modeset: Allocated GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
[ 2.664180] nvidia-modeset: Freed GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
[ 2.664212] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 4.187715] nvidia-modeset: Allocated GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
[ 4.188185] nvidia-modeset: Freed GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
[ 4.188550] nvidia-modeset: Allocated GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
[ 4.188971] nvidia-modeset: Freed GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
[ 4.730498] nvidia-modeset: Allocated GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
[ 4.730983] nvidia-modeset: Freed GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
[ 5.271571] nvidia-modeset: Allocated GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
[ 5.272035] nvidia-modeset: Freed GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
[ 6.248159] nvidia-modeset: Allocated GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
[ 6.248600] nvidia-modeset: Freed GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
[ 11.348642] nvidia-modeset: Allocated GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
[ 11.348806] nvidia-modeset: Freed GPU:0 (GPU-b909bbcf-2700-dce3-c390-11d51818c438) @ PCI:0000:01:00.0
nvidia-bug-report.log.gz (111 KB)
