I want to use 3D textures to implement a 3D display LUT. As a test, I wrote a program that operates as follows. I synthesize a 256x256 image that has contains a left-to-right monochrome gradient where each pixel contains the x coordinate in each of the RGB components and load that into a 2D texture. I then create a 3D texture that is a 2x2x2 identity LUT. I draw the pixels, applying the LUT in the fragment shader, then read the pixels back from the framebuffer. I expected to get back the same pixels that I sent up in the image texture, and this is true for the R and B channels. But, very strangely, the G channel does NOT match, and the result is non-linear!
The number of errors varies with the size of the identity LUT, where the larger I make the LUT, the fewer errors there are. When I get to a 9x9x9 identity LUT, the errors disappear. So I guess to get desired precision in this case, I will always use 16x16x16 or larger texture!
Here is the program:
#include <iostream>
#include <iomanip>
#include <GL/glew.h>
#include <GLFW/glfw3.h>
#include "common/checkglerror.hpp"
GLFWwindow* window;
const unsigned int imageWidth = 256;
const unsigned int imageHeight = 256;
GLubyte imageData[imageHeight][imageWidth][3];
const GLchar* vertexSource = R"glsl(
#version 450 core
in vec2 position;
in vec2 texCoord;
out vec2 fragTexCoord;
void main()
fragTexCoord = texCoord;
gl_Position = vec4(position, 0.0, 1.0);
)glsl";
const GLchar* fragmentSource = R"glsl(
#version 450 core
in vec2 fragTexCoord;
out vec4 outColor;
uniform sampler2D imageTextureUnit;
uniform sampler3D lutTextureUnit;
uniform float lutInterpScale;
uniform float lutInterpOffset;
void main()
vec4 srcColor = texture(imageTextureUnit, fragTexCoord);
vec3 lutIn = vec3(srcColor.rgb * lutInterpScale + lutInterpOffset);
outColor = texture(lutTextureUnit, lutIn);
)glsl";
int main(void)
glfwInit();
glfwWindowHint(GLFW_SAMPLES, 4);
glfwWindowHint(GLFW_RESIZABLE, GL_FALSE);
glfwWindowHint(GLFW_CONTEXT_VERSION_MAJOR, 3);
glfwWindowHint(GLFW_CONTEXT_VERSION_MINOR, 3);
glfwWindowHint(GLFW_OPENGL_FORWARD_COMPAT, GL_TRUE); // To make MacOS happy; should not be needed
glfwWindowHint(GLFW_OPENGL_PROFILE, GLFW_OPENGL_CORE_PROFILE);
window = glfwCreateWindow(imageWidth, imageHeight, "3D Lut Test", NULL, NULL);
glfwMakeContextCurrent(window);
glewExperimental = true; // Needed for core profile
glewInit();
GLuint vertexArrayID, vertexBufferID, elementBufferID;
glGenVertexArrays(1, &vertexArrayID);
glBindVertexArray(vertexArrayID);
static GLfloat vertexBufferData[] =
// VERTEX POS TEXTURE COORD
-1.0f, 1.0f, 0.0f, 1.0f, // top left
1.0f, 1.0f, 1.0f, 1.0f, // top right
1.0f, -1.0f, 1.0f, 0.0f, // bottom right
-1.0f, -1.0f, 0.0f, 0.0f, // bottom left
glGenBuffers(1, &vertexBufferID);
glBindBuffer(GL_ARRAY_BUFFER, vertexBufferID);
glBufferData(GL_ARRAY_BUFFER, sizeof(vertexBufferData), vertexBufferData, GL_STATIC_DRAW);
static unsigned int triangleIndices[2][3] =
{0, 1, 2}, // first image triangle
{2, 3, 0}, // second image triangle
glGenBuffers(1, &elementBufferID);
glBindBuffer(GL_ELEMENT_ARRAY_BUFFER, elementBufferID);
glBufferData(GL_ELEMENT_ARRAY_BUFFER, sizeof(triangleIndices), triangleIndices, GL_STATIC_DRAW);
// Create an 8-bit RGB test image - each row is a monochrome 0-256 gradient.
for (auto row = 0; row < imageHeight; ++row)
for (auto col = 0; col < imageWidth; ++col)
imageData[row][col][0] = col; // r
imageData[row][col][1] = col; // g
imageData[row][col][2] = col; // b
// Image texture
GLuint imageTextureID;
glGenTextures(1, &imageTextureID);
glActiveTexture(GL_TEXTURE0);
glBindTexture(GL_TEXTURE_2D, imageTextureID);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_BORDER);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_BORDER);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
glPixelStorei(GL_UNPACK_ALIGNMENT, 1);
glPixelStorei(GL_UNPACK_ROW_LENGTH, imageWidth);
check_gl_error();
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGB, imageWidth, imageHeight, 0, GL_RGB, GL_UNSIGNED_BYTE, nullptr);
check_gl_error();
// Set up NxNxN identity LUT 3D texture
const int lutSize = 2;
static GLfloat lutValues[lutSize*lutSize*lutSize][3];
for (int b = 0; b < lutSize; ++b)
for (int g = 0; g < lutSize; ++g)
for (int r = 0; r < lutSize; ++r)
int position = b * lutSize * lutSize + g * lutSize + r;
lutValues[position][0] = r / GLfloat(lutSize - 1);
lutValues[position][1] = g / GLfloat(lutSize - 1);
lutValues[position][2] = b / GLfloat(lutSize - 1);
GLuint lutTextureId;
glGenTextures(1, &lutTextureId);
glActiveTexture(GL_TEXTURE1);
glBindTexture(GL_TEXTURE_3D, lutTextureId);
glTexParameterf(GL_TEXTURE_3D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
glTexParameterf(GL_TEXTURE_3D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
glTexParameterf(GL_TEXTURE_3D, GL_TEXTURE_WRAP_R, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_3D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_3D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
glPixelStorei(GL_UNPACK_ALIGNMENT, 4);
glPixelStorei(GL_UNPACK_ROW_LENGTH, lutSize);
glTexImage3D(GL_TEXTURE_3D, 0, GL_RGB, lutSize, lutSize, lutSize, 0, GL_RGB, GL_FLOAT, lutValues);
// Create the shader program
GLuint vertexShader = glCreateShader(GL_VERTEX_SHADER);
glShaderSource(vertexShader, 1, &vertexSource, NULL);
glCompileShader(vertexShader);
GLuint fragmentShader = glCreateShader(GL_FRAGMENT_SHADER);
glShaderSource(fragmentShader, 1, &fragmentSource, NULL);
glCompileShader(fragmentShader);
GLuint shaderProgram = glCreateProgram();
glAttachShader(shaderProgram, vertexShader);
glAttachShader(shaderProgram, fragmentShader);
glLinkProgram(shaderProgram);
glUseProgram(shaderProgram);
// Set up attributes, uniforms, and fragment output.
GLint posAttrib = glGetAttribLocation(shaderProgram, "position");
glEnableVertexAttribArray(posAttrib);
glVertexAttribPointer(posAttrib, 2, GL_FLOAT, GL_FALSE, 4 * sizeof(GLfloat), 0);
GLint texAttrib = glGetAttribLocation(shaderProgram, "texCoord");
glEnableVertexAttribArray(texAttrib);
glVertexAttribPointer(texAttrib, 2, GL_FLOAT, GL_FALSE, 4 * sizeof(GLfloat), (void*)(2 * sizeof(GLfloat)));
GLuint imageTextureUniform = glGetUniformLocation(shaderProgram, "imageTextureUnit");
glUniform1i(imageTextureUniform, 0); // image --> texture unit 0
GLuint lutTextureUniform = glGetUniformLocation(shaderProgram, "lutTextureUnit");
glUniform1i(lutTextureUniform, 1); // lut --> texture unit 1
GLuint lutInterpScaleUniform = glGetUniformLocation(shaderProgram, "lutInterpScale");
glUniform1f(lutInterpScaleUniform, (lutSize - 1.0F) / lutSize);
GLuint lutInterpOffsetUniform = glGetUniformLocation(shaderProgram, "lutInterpOffset");
glUniform1f(lutInterpOffsetUniform, 1.0F / (2.0F * lutSize));
glBindFragDataLocation(shaderProgram, 0, "outColor");
glTexSubImage2D(GL_TEXTURE_2D, 0, 0, 0, imageWidth, imageHeight, GL_RGB, GL_UNSIGNED_BYTE, imageData);
check_gl_error();
// Draw
glDrawElements(GL_TRIANGLES, 6, GL_UNSIGNED_INT, 0);
glfwSwapBuffers(window);
// Read back one row of the frame buffer image and compare with orig image
unsigned char readBuffer[256][3];
glReadPixels(0, 0, 256, 1, GL_RGB, GL_UNSIGNED_BYTE, readBuffer);
std::cout << std::endl << " IN dR dG dB";
for (auto i = 0; i < 256; ++i)
std::cout << std::endl << std::setw(3) << i << ":";
for (auto j = 0; j < 3; ++j)
int diff = int(readBuffer[i][j]) - int(imageData[0][i][j]);
std::cout << " " << std::setw(2) << diff;
std::cout << std::endl;
while (glfwWindowShouldClose(window) == 0)
glfwWaitEvents();
glfwTerminate();
return 0;
And here is the output:
IN dR dG dB
0: 0 0 0
1: 0 0 0
2: 0 0 0
3: 0 0 0
4: 0 0 0
5: 0 0 0
6: 0 0 0
7: 0 0 0
8: 0 -1 0
9: 0 -1 0
10: 0 -1 0
11: 0 -1 0
12: 0 1 0
13: 0 1 0
14: 0 1 0
15: 0 0 0
16: 0 0 0
17: 0 0 0
18: 0 0 0
19: 0 -1 0
20: 0 -1 0
21: 0 1 0
22: 0 0 0
23: 0 0 0
24: 0 0 0
25: 0 -1 0
26: 0 -1 0
27: 0 1 0
28: 0 0 0
29: 0 0 0
30: 0 -1 0
31: 0 -1 0
32: 0 0 0
33: 0 1 0
34: 0 1 0
35: 0 0 0
36: 0 0 0
37: 0 1 0
38: 0 1 0
39: 0 0 0
40: 0 -1 0
41: 0 -1 0
42: 0 0 0
43: 0 0 0
44: 0 -1 0
45: 0 1 0
46: 0 0 0
47: 0 0 0
48: 0 0 0
49: 0 1 0
50: 0 0 0
51: 0 0 0
52: 0 -1 0
53: 0 0 0
54: 0 0 0
55: 0 0 0
56: 0 1 0
57: 0 1 0
58: 0 0 0
59: 0 -1 0
60: 0 0 0
61: 0 1 0
62: 0 0 0
63: 0 1 0
64: 0 0 0
65: 0 -1 0
66: 0 0 0
67: 0 1 0
68: 0 0 0
69: 0 -1 0
70: 0 0 0
71: 0 0 0
72: 0 1 0
73: 0 0 0
74: 0 -1 0
75: 0 0 0
76: 0 1 0
77: 0 0 0
78: 0 -1 0
79: 0 0 0
80: 0 0 0
81: 0 -1 0
82: 0 0 0
83: 0 0 0
84: 0 -1 0
85: 0 0 0
86: 0 0 0
87: 0 -1 0
88: 0 0 0
89: 0 0 0
90: 0 -1 0
91: 0 0 0
92: 0 0 0
93: 0 -1 0
94: 0 1 0
95: 0 -1 0
96: 0 0 0
97: 0 1 0
98: 0 1 0
99: 0 1 0
100: 0 0 0
101: 0 0 0
102: 0 -1 0
103: 0 0 0
104: 0 0 0
105: 0 0 0
106: 0 0 0
107: 0 0 0
108: 0 -1 0
109: 0 1 0
110: 0 0 0
111: 0 0 0
112: 0 0 0
113: 0 0 0
114: 0 0 0
115: 0 -1 0
116: 0 1 0
117: 0 -1 0
118: 0 0 0
119: 0 1 0
120: 0 0 0
121: 0 0 0
122: 0 0 0
123: 0 0 0
124: 0 0 0
125: 0 0 0
126: 0 0 0
127: 0 0 0
128: 0 0 0
129: 0 0 0
130: 0 0 0
131: 0 0 0
132: 0 0 0
133: 0 0 0
134: 0 0 0
135: 0 0 0
136: 0 -1 0
137: 0 0 0
138: 0 1 0
139: 0 -1 0
140: 0 1 0
141: 0 0 0
142: 0 0 0
143: 0 0 0
144: 0 0 0
145: 0 0 0
146: 0 -1 0
147: 0 1 0
148: 0 0 0
149: 0 0 0
150: 0 0 0
151: 0 0 0
152: 0 0 0
153: 0 1 0
154: 0 0 0
155: 0 0 0
156: 0 -1 0
157: 0 -1 0
158: 0 -1 0
159: 0 0 0
160: 0 1 0
161: 0 -1 0
162: 0 1 0
163: 0 0 0
164: 0 0 0
165: 0 1 0
166: 0 0 0
167: 0 0 0
168: 0 1 0
169: 0 0 0
170: 0 0 0
171: 0 1 0
172: 0 0 0
173: 0 0 0
174: 0 1 0
175: 0 0 0
176: 0 0 0
177: 0 1 0
178: 0 0 0
179: 0 -1 0
180: 0 0 0
181: 0 1 0
182: 0 0 0
183: 0 -1 0
184: 0 0 0
185: 0 0 0
186: 0 1 0
187: 0 0 0
188: 0 -1 0
189: 0 0 0
190: 0 1 0
191: 0 0 0
192: 0 -1 0
193: 0 0 0
194: 0 -1 0
195: 0 0 0
196: 0 1 0
197: 0 0 0
198: 0 -1 0
199: 0 -1 0
200: 0 0 0
201: 0 0 0
202: 0 0 0
203: 0 1 0
204: 0 0 0
205: 0 0 0
206: 0 -1 0
207: 0 0 0
208: 0 0 0
209: 0 0 0
210: 0 -1 0
211: 0 1 0
212: 0 0 0
213: 0 0 0
214: 0 1 0
215: 0 1 0
216: 0 0 0
217: 0 -1 0
218: 0 -1 0
219: 0 0 0
220: 0 0 0
221: 0 -1 0
222: 0 -1 0
223: 0 0 0
224: 0 1 0
225: 0 1 0
226: 0 0 0
227: 0 0 0
228: 0 -1 0
229: 0 1 0
230: 0 1 0
231: 0 0 0
232: 0 0 0
233: 0 0 0
234: 0 -1 0
235: 0 1 0
236: 0 1 0
237: 0 0 0
238: 0 0 0
239: 0 0 0
240: 0 0 0
241: 0 -1 0
242: 0 -1 0
243: 0 -1 0
244: 0 1 0
245: 0 1 0
246: 0 1 0
247: 0 1 0
248: 0 0 0
249: 0 0 0
250: 0 0 0
251: 0 0 0
252: 0 0 0
253: 0 0 0
254: 0 0 0
255: 0 0 0
