The Nvidia driver install fails without --no-install-libglvnd. Yes, Fedora does provide libglvnd, so everything works when the Nvidia driver is installed using --no-install-libglvnd. Previous versions of the Nvidia installer offered to replace it.
I did try that, uninstalling 440.82 first, no change. 440.82 installed and updated the libglvnd files. Since than I’ve updated the computer to Fedora 32. 440.82 won’t install with that kernel. 450.57 installed on F32 if i used -no-install-libglvnd.
This computer has been updated with several versions of Fedora, and my installs are done remotely via ssh. Could those have anything to do with this issue?
In any case, the workaround allows it to install and it functions with no issues. I just wanted to post the info here and provide the workaround in case anyone else had a similar issue. A search did not turn up any other similar reports.
Hi colinpauladams,
Could you please share nvidia bug report.
If i understood correctly, you are able to install driver successfully but getting trouble with starting X.
