nsumin@zephyrus:~$ lspci | grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation AD106M [GeForce RTX 4070 Max-Q / Mobile]
If it’s important: laptop model is ASUSTeK COMPUTER INC. ROG Zephyrus G14 GA403UI_GA403UI
OSs: Fedora 40 and Nobara Linux 40
nsumin@zephyrus:~$ nvidia-smi -q -d POWER
==============NVSMI LOG==============
Timestamp : Mon Dec 9 03:06:39 2024
Driver Version : 565.77
CUDA Version : 12.7
Attached GPUs : 1
GPU 00000000:01:00.0
GPU Power Readings
Power Draw : 11.87 W
Current Power Limit : 80.00 W
Requested Power Limit : N/A
Default Power Limit : 55.00 W
Min Power Limit : 5.00 W
Max Power Limit : 90.00 W
Power Samples
Duration : Not Found
Number of Samples : Not Found
Max : Not Found
Min : Not Found
Avg : Not Found
GPU Memory Power Readings
Power Draw : N/A
Module Power Readings
Power Draw : N/A
Current Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
So base power limit should be 65w not 55w. The video card never reach 90w limits => less performance potential
I also noticed strange behavior that when /sys/devices/system/cpu/cpufreq/boost is 1, then nvidia can use only 60w power, so sometimes performance without cpu frequency boost is better than while it turned on.
On Windows didn’t see the problems
