Hi! I made a pretty nice setup with my laptop and only thing that i couldnt find the answer to is that my gpu is stuck at 80W when passed through to VM.
neofetch
OS: Arch Linux x86_64
Host: 82RF Legion 5 Pro 16IAH7H
Kernel: 6.4.7-arch1-2
Uptime: 4 hours, 46 mins
Packages: 1372 (pacman)
Shell: bash 5.1.16
Resolution: 2560x1600
DE: Plasma 5.27.7
WM: KWin
Theme: [Plasma], Breeze [GTK2/3]
Icons: [Plasma], breeze-dark [GTK2/3]
Terminal: konsole
CPU: 12th Gen Intel i7-12700H (20) @ 4.600GHz
GPU: NVIDIA GeForce RTX 3060 Mobile / Max-Q
GPU: Intel Alder Lake-P
Memory: 6959MiB / 15719MiB
Laptop is in performance mode.
In arch, everything works flawlessly, i installed both intel and nvidia drivers.
When i start nvidia-powerd.service nvidia card is working as expected (140W max)
I enabled all virtualization options in UEFI, setup the kvm and passed the gpu to the VM and installed looking glass.
For it to work when laptop boots up, the nvidia gpu is controlled by vfio-pci driver.
To reattach it to linux i used these commands
sudo virsh nodedev-reattach pci_0000_01_00_0
sudo rmmod vfio_pci vfio_pci_core vfio_iommu_type1
sudo modprobe -i nvidia_modeset nvidia_uvm nvidia
To detach it, for use in VM
sudo rmmod nvidia_modeset nvidia_uvm nvidia
sudo modprobe -i vfio_pci vfio_pci_core vfio_iommu_type1
sudo virsh nodedev-detach pci_0000_01_00_0
In a VM i tried installing drivers from Lenovo website, i tried latest nvidia drivers, and i tried default driver that windows installs automatically, and all of them are stuck at 80W under load.
Is it possible to achieve maximum performance without custom Vbios?
Is there something like nvidia-powerd but in windows that i can activate?
