[580.105.08] [Redhat 9.6] RTX Pro 6000 Workstation - No devices were found
I have installed my RTX Pro 6000 Workstation into my system and installed the NVIDIA-Linux-x86_64-580.105.08.run driver, which includes the open-source kernel modules under the MIT license. However, running nvidia-smi returns: No devices found
nvidia-smi
modinfo nvidia | grep version
version: 580.105.08
rhelversion: 9.6
srcversion: E428CF693F50B6FFC6527A3
vermagic: 5.14.0-570.39.1.el9_6.x86_64 SMP preempt mod_unload modversions
lspci | grep -i nvidia
17:00.0 VGA compatible controller: NVIDIA Corporation Device 2bb1 (rev a1)
17:00.1 Audio device: NVIDIA Corporation Device 22e8 (rev a1)
sudo lshw -C display
*-display
   description: VGA compatible controller
   product: ASPEED Graphics Family
   vendor: ASPEED Technology, Inc.
   physical id: 0
   bus info: pci@0000:05:00.0
   logical name: /dev/fb0
   version: 52
   width: 32 bits
   clock: 33MHz
   capabilities: pm msi vga_controller cap_list fb
   configuration: depth=32 latency=0 resolution=1024,768
   resources: memory:94000000-97ffffff memory:98000000-9803ffff ioport:2000(size=128)
*-display
   product: NVIDIA Corporation
   vendor: NVIDIA Corporation
   physical id: 0
   bus info: pci@0000:17:00.0
   version: a1
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
   configuration: driver=nvidia latency=0
   resources: iomemory:20400-203ff iomemory:20600-205ff irq:16 memory:a0000000-a3ffffff memory:204000000000-205fffffffff memory:206000000000-206001ffffff ioport:6000(size=128) memory:a4000000-a407ffff
uname -r
modinfo nvidia | grep license
license: Dual MIT/GPL
dmesg | grep -i nvidia | tail -n 100
[ 1.324858] Loaded X.509 cert ‘Nvidia GPU OOT signing 001: 55e1cef88193e60419f0b0ec379c49f77545acf0’
[ 1.878274] nvidia: loading out-of-tree module taints kernel.
[ 1.878282] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 1.934857] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[ 2.135233] nvidia 0000:17:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 2.145945] NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 580.105.08 Release Build (dvs-builder@U22-I3-B10-02-5) Wed Oct 29 22:29:53 UTC 2025
[ 2.455184] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 580.105.08 Release Build (dvs-builder@U22-I3-B10-02-5) Wed Oct 29 22:16:05 UTC 2025
[ 2.475613] [drm] [nvidia-drm] [GPU ID 0x00001700] Loading driver
[ 2.475679] [drm] Initialized nvidia-drm 0.0.0 for 0000:17:00.0 on minor 0
cat /proc/driver/nvidia/gpus/0000\:17\:00.0/information
Model: NVIDIA RTX PRO 6000 Blackwell Workstation Edition
IRQ: 119
GPU UUID: GPU-801383be-20e1-a842-5cc3-215ec26f58d3
Video BIOS: ??.??.??.??.??
Bus Type: PCIe
DMA Size: 52 bits
DMA Mask: 0xfffffffffffff
Bus Location: 0000:17:00.0
Device Minor: 0
GPU Firmware: N/A
GPU Excluded: No
nvidia-installer.log (51.6 KB)
nvidia-bug-report.log (525.4 KB)
I’ve tried multiple installation methods, including using the DKMS module via DNF, and verified that the open kernel modules are loaded. Despite this, the GPU is not being recognized.
Can anyone help me resolve this issue?
Thank you for your support.
Update:
I did a complete system upgrade, including a kernel update:
Running scriptlet: kernel-modules-core-5.14.0-611.5.1.el9 7.x86 64
Running scriptlet: kernel-core-5.14.0-611.5.1.el9 7.x86 64
Sign command: /lib/modules/5.14.0-611.5.1.el9_7.x86_64/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK) : /var/lib/dkms/mok.pub
Autoinstall of module nvidia/580.105.08 for kernel 5.14.0-611.5.1.el9 7.x86_64 (x86_64)
Building module (s) ..
Signing module /var/lib/dkms/nvidia/580.105.08/build/nvidia.ko
igning module /var/lib/dkms/nvidia/580.105.08/build/nvidia-uvm.ko
Signing module /var/lib/dkms/nvidia/580.105.08/build/nvidia-modeset.ko
Signing module /var/lib/dkms/nvidia/580.105.08/build/nvidia-drm.ko
Signing module /var/lib/dkms/nvidia/580.105.08/build/nvidia-peermem.ko
Installing /lib/modules/5.14.0-611.5.1.el9 7.x86 64/extra/nvidia.ko.xz
Installing /lib/modules/5.14.0-611.5.1.el9_7.x86_64/extra/nvidia-uvm.ko.xz
Installing /lib/modules/5.14.0-611.5.1.el9 7.x86_64/extra/nvidia-modeset.ko.xz
Installing /lib/modules/5.14.0-611.5.1.el9_7.x86_64/extra/nvidia-drm.ko.xz
Installing /lib/modules/5.14.0-611.5.1.el9 7.x86_64/extra/nvidia-peermem.ko.xz
Running depmod … done.
Autoinstall on 5.14.0-611.5.1.el9 7.x86 64 succeeded for module (s) nvidia.
Running scriptlet: kernel-modules-5.14.0-611.5.1.el9 7.x86 64
It now runs kernel-core-5.14.0-611.5.1
After a reboot, the system still does not detect the graphics card. In dmesg, there is a problem with the GSP firmware initialization:
[ 13.237230] NVRM: GPU at PCI:0000:17:00: GPU-801383be-20e1-a842-5cc3-215ec26f58d3
[ 13.237245] NVRM: Xid (PCI:0000:17:00): 143, Error status 0x65 while polling for FSP boot complete, 0x13, 0x0, 0x0, 0x0, 0x0
[ 13.237263] NVRM: kfspDumpDebugState_GB100: FSP microcode v4.76
[ 13.237267] NVRM: kfspDumpDebugState_GB100: GPU 0000:17:00
[ 13.237272] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(0) = 0x0
[ 13.237278] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(1) = 0x0
[ 13.237283] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(2) = 0x0
[ 13.237288] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(3) = 0x0
[ 13.237296] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110040, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 13.237300] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX0 = 0xbadf4100
[ 13.237307] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110044, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 13.237310] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX1 = 0xbadf4100
[ 13.237317] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110804, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 13.237321] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(0) = 0xbadf4100
[ 13.237328] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110808, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 13.237331] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(1) = 0xbadf4100
[ 13.237338] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x11080c, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 13.237341] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(2) = 0xbadf4100
[ 13.237348] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110810, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 13.237351] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(3) = 0xbadf4100
[ 13.237439] NVRM: _kfspPrintCms2Log_GB100: CMS2 Log:
[ 13.237442] NVRM: nvDbgDumpBufferBytes: x0 x1 x2 x3 x4 x5 x6 x7 x8 x9 xa xb xc xd xe xf
[ 13.237446] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7600 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 13.237450] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7610 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 13.237454] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7620 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 13.237457] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7630 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 13.237460] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7640 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 13.237464] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7650 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 13.237467] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7660 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 13.237470] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7670 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 13.237473] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7680 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 13.237477] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7690 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 13.237480] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B76A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 13.237484] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B76B0 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 00
[ 13.237491] NVRM: nvCheckOkFailedNoLog: Check failed: Call timed out [NV_ERR_TIMEOUT] (0x00000065) returned from kgspWaitForGfwBootOk_HAL(pGpu, pKernelGsp) @ kernel_gsp.c:3874
[ 13.237585] NVRM: RmInitAdapter: Cannot initialize GSP firmware RM
[ 13.238457] NVRM: GPU 0000:17:00.0: RmInitAdapter failed! (0x62:0x65:2015)
[ 13.241841] NVRM: GPU 0000:17:00.0: rm_init_adapter failed, device minor number 0
[ 18.479243] NVRM: GPU at PCI:0000:17:00: GPU-801383be-20e1-a842-5cc3-215ec26f58d3
[ 18.479256] NVRM: Xid (PCI:0000:17:00): 143, Error status 0x65 while polling for FSP boot complete, 0x13, 0x0, 0x0, 0x0, 0x0
[ 18.479280] NVRM: kfspDumpDebugState_GB100: FSP microcode v4.76
[ 18.479284] NVRM: kfspDumpDebugState_GB100: GPU 0000:17:00
[ 18.479289] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(0) = 0x0
[ 18.479294] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(1) = 0x0
[ 18.479299] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(2) = 0x0
[ 18.479304] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(3) = 0x0
[ 18.479312] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110040, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 18.479315] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX0 = 0xbadf4100
[ 18.479321] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110044, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 18.479324] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX1 = 0xbadf4100
[ 18.479331] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110804, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 18.479334] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(0) = 0xbadf4100
[ 18.479341] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110808, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 18.479343] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(1) = 0xbadf4100
[ 18.479350] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x11080c, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 18.479352] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(2) = 0xbadf4100
[ 18.479359] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110810, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 18.479361] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(3) = 0xbadf4100
[ 18.479443] NVRM: _kfspPrintCms2Log_GB100: CMS2 Log:
[ 18.479445] NVRM: nvDbgDumpBufferBytes: x0 x1 x2 x3 x4 x5 x6 x7 x8 x9 xa xb xc xd xe xf
[ 18.479449] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7450 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 18.479453] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7460 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 18.479456] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7470 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 18.479459] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7480 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 18.479462] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7490 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 18.479465] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B74A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 18.479468] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B74B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 18.479471] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B74C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 18.479474] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B74D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 18.479477] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B74E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 18.479480] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B74F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 18.479483] NVRM: nvDbgDumpBufferBytes: FF4DADCD029B7500 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 00
[ 18.479489] NVRM: nvCheckOkFailedNoLog: Check failed: Call timed out [NV_ERR_TIMEOUT] (0x00000065) returned from kgspWaitForGfwBootOk_HAL(pGpu, pKernelGsp) @ kernel_gsp.c:3874
[ 18.479565] NVRM: RmInitAdapter: Cannot initialize GSP firmware RM
[ 18.480244] NVRM: GPU 0000:17:00.0: RmInitAdapter failed! (0x62:0x65:2015)
[ 18.483696] NVRM: GPU 0000:17:00.0: rm_init_adapter failed, device minor number 0
[ 19.928851] rfkill: input handler disabled
[ 71.810683] NVRM: GPU at PCI:0000:17:00: GPU-801383be-20e1-a842-5cc3-215ec26f58d3
[ 71.810689] NVRM: Xid (PCI:0000:17:00): 143, Error status 0x65 while polling for FSP boot complete, 0x13, 0x56, 0x0, 0x0, 0x2
[ 71.810697] NVRM: kfspDumpDebugState_GB100: FSP microcode v4.76
[ 71.810698] NVRM: kfspDumpDebugState_GB100: GPU 0000:17:00
[ 71.810701] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(0) = 0x56
[ 71.810703] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(1) = 0x0
[ 71.810705] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(2) = 0x0
[ 71.810707] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(3) = 0x2
[ 71.810710] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110040, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 71.810711] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX0 = 0xbadf4100
[ 71.810715] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110044, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 71.810716] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX1 = 0xbadf4100
[ 71.810720] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110804, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 71.810720] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(0) = 0xbadf4100
[ 71.810724] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110808, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 71.810725] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(1) = 0xbadf4100
[ 71.810728] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x11080c, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 71.810729] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(2) = 0xbadf4100
[ 71.810732] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110810, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 71.810733] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(3) = 0xbadf4100
[ 71.810803] NVRM: _kfspPrintCms2Log_GB100: CMS2 Log:
[ 71.810803] NVRM: nvDbgDumpBufferBytes: x0 x1 x2 x3 x4 x5 x6 x7 x8 x9 xa xb xc xd xe xf
[ 71.810804] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B5A0 00 00 14 00 56 00 00 00 02 00 00 00 00 00 00 00
[ 71.810805] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B5B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 71.810805] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B5C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 71.810806] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B5D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 71.810807] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B5E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 71.810807] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B5F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 71.810808] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B600 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 71.810809] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B610 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 71.810809] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B620 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 71.810810] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B630 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 71.810811] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B640 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 71.810811] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B650 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 00
[ 71.810813] NVRM: nvCheckOkFailedNoLog: Check failed: Call timed out [NV_ERR_TIMEOUT] (0x00000065) returned from kgspWaitForGfwBootOk_HAL(pGpu, pKernelGsp) @ kernel_gsp.c:3874
[ 71.810856] NVRM: RmInitAdapter: Cannot initialize GSP firmware RM
[ 71.811706] NVRM: GPU 0000:17:00.0: RmInitAdapter failed! (0x62:0x65:2015)
[ 71.812727] NVRM: GPU 0000:17:00.0: rm_init_adapter failed, device minor number 0
[ 72.805786] block dm-4: the capability attribute has been deprecated.
[ 76.895827] NVRM: GPU at PCI:0000:17:00: GPU-801383be-20e1-a842-5cc3-215ec26f58d3
[ 76.895832] NVRM: Xid (PCI:0000:17:00): 143, Error status 0x65 while polling for FSP boot complete, 0x13, 0x56, 0x0, 0x0, 0x2
[ 76.895840] NVRM: kfspDumpDebugState_GB100: FSP microcode v4.76
[ 76.895841] NVRM: kfspDumpDebugState_GB100: GPU 0000:17:00
[ 76.895845] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(0) = 0x56
[ 76.895847] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(1) = 0x0
[ 76.895849] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(2) = 0x0
[ 76.895851] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(3) = 0x2
[ 76.895855] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110040, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 76.895856] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX0 = 0xbadf4100
[ 76.895861] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110044, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 76.895861] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX1 = 0xbadf4100
[ 76.895866] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110804, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 76.895866] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(0) = 0xbadf4100
[ 76.895871] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110808, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 76.895871] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(1) = 0xbadf4100
[ 76.895875] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x11080c, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 76.895876] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(2) = 0xbadf4100
[ 76.895880] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110810, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 76.895880] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(3) = 0xbadf4100
[ 76.895951] NVRM: _kfspPrintCms2Log_GB100: CMS2 Log:
[ 76.895951] NVRM: nvDbgDumpBufferBytes: x0 x1 x2 x3 x4 x5 x6 x7 x8 x9 xa xb xc xd xe xf
[ 76.895953] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B6D0 00 00 14 00 56 00 00 00 02 00 00 00 00 00 00 00
[ 76.895954] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B6E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 76.895954] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B6F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 76.895955] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B700 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 76.895956] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B710 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 76.895957] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B720 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 76.895958] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B730 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 76.895959] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B740 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 76.895960] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B750 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 76.895961] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B760 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 76.895961] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B770 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 76.895962] NVRM: nvDbgDumpBufferBytes: FF4DADCD0366B780 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 00
[ 76.895965] NVRM: nvCheckOkFailedNoLog: Check failed: Call timed out [NV_ERR_TIMEOUT] (0x00000065) returned from kgspWaitForGfwBootOk_HAL(pGpu, pKernelGsp) @ kernel_gsp.c:3874
[ 76.896005] NVRM: RmInitAdapter: Cannot initialize GSP firmware RM
[ 76.896516] NVRM: GPU 0000:17:00.0: RmInitAdapter failed! (0x62:0x65:2015)
[ 76.897461] NVRM: GPU 0000:17:00.0: rm_init_adapter failed, device minor number 0
[ 76.897738] NVRM: nvAssertFailedNoLog: Assertion failed: rmapiLockIsOwner() && rmGpuLockIsOwner() @ conf_compute_api.c:78
[ 82.111977] NVRM: GPU at PCI:0000:17:00: GPU-801383be-20e1-a842-5cc3-215ec26f58d3
[ 82.111991] NVRM: Xid (PCI:0000:17:00): 143, Error status 0x65 while polling for FSP boot complete, 0x13, 0x56, 0x0, 0x0, 0x2
[ 82.112013] NVRM: kfspDumpDebugState_GB100: FSP microcode v4.76
[ 82.112018] NVRM: kfspDumpDebugState_GB100: GPU 0000:17:00
[ 82.112023] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(0) = 0x56
[ 82.112029] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(1) = 0x0
[ 82.112034] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(2) = 0x0
[ 82.112039] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(3) = 0x2
[ 82.112047] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110040, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 82.112050] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX0 = 0xbadf4100
[ 82.112057] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110044, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 82.112060] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX1 = 0xbadf4100
[ 82.112067] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110804, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 82.112071] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(0) = 0xbadf4100
[ 82.112078] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110808, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 82.112081] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(1) = 0xbadf4100
[ 82.112087] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x11080c, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 82.112090] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(2) = 0xbadf4100
[ 82.112097] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110810, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 82.112100] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(3) = 0xbadf4100
[ 82.112180] NVRM: _kfspPrintCms2Log_GB100: CMS2 Log:
[ 82.112182] NVRM: nvDbgDumpBufferBytes: x0 x1 x2 x3 x4 x5 x6 x7 x8 x9 xa xb xc xd xe xf
[ 82.112187] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB7B0 00 00 14 00 56 00 00 00 02 00 00 00 00 00 00 00
[ 82.112191] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB7C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 82.112195] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB7D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 82.112198] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB7E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 82.112201] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB7F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 82.112205] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB800 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 82.112208] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB810 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 82.112212] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB820 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 82.112215] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB830 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 82.112218] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB840 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 82.112222] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB850 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 82.112225] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB860 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 00
[ 82.112232] NVRM: nvCheckOkFailedNoLog: Check failed: Call timed out [NV_ERR_TIMEOUT] (0x00000065) returned from kgspWaitForGfwBootOk_HAL(pGpu, pKernelGsp) @ kernel_gsp.c:3874
[ 82.112308] NVRM: RmInitAdapter: Cannot initialize GSP firmware RM
[ 82.113234] NVRM: GPU 0000:17:00.0: RmInitAdapter failed! (0x62:0x65:2015)
[ 82.113967] NVRM: GPU 0000:17:00.0: rm_init_adapter failed, device minor number 0
[ 87.193089] NVRM: GPU at PCI:0000:17:00: GPU-801383be-20e1-a842-5cc3-215ec26f58d3
[ 87.193093] NVRM: Xid (PCI:0000:17:00): 143, Error status 0x65 while polling for FSP boot complete, 0x13, 0x56, 0x0, 0x0, 0x2
[ 87.193100] NVRM: kfspDumpDebugState_GB100: FSP microcode v4.76
[ 87.193101] NVRM: kfspDumpDebugState_GB100: GPU 0000:17:00
[ 87.193104] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(0) = 0x56
[ 87.193106] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(1) = 0x0
[ 87.193108] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(2) = 0x0
[ 87.193109] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(3) = 0x2
[ 87.193113] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110040, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 87.193114] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX0 = 0xbadf4100
[ 87.193118] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110044, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 87.193119] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX1 = 0xbadf4100
[ 87.193123] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110804, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 87.193123] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(0) = 0xbadf4100
[ 87.193127] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110808, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 87.193127] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(1) = 0xbadf4100
[ 87.193131] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x11080c, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 87.193131] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(2) = 0xbadf4100
[ 87.193135] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110810, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 87.193136] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(3) = 0xbadf4100
[ 87.193205] NVRM: _kfspPrintCms2Log_GB100: CMS2 Log:
[ 87.193206] NVRM: nvDbgDumpBufferBytes: x0 x1 x2 x3 x4 x5 x6 x7 x8 x9 xa xb xc xd xe xf
[ 87.193207] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB520 00 00 14 00 56 00 00 00 02 00 00 00 00 00 00 00
[ 87.193208] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB530 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 87.193208] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB540 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 87.193209] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB550 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 87.193210] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB560 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 87.193210] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB570 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 87.193211] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB580 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 87.193212] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB590 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 87.193212] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB5A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 87.193213] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB5B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 87.193214] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB5C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 87.193214] NVRM: nvDbgDumpBufferBytes: FF4DADCD0E1FB5D0 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 00
[ 87.193216] NVRM: nvCheckOkFailedNoLog: Check failed: Call timed out [NV_ERR_TIMEOUT] (0x00000065) returned from kgspWaitForGfwBootOk_HAL(pGpu, pKernelGsp) @ kernel_gsp.c:3874
[ 87.193249] NVRM: RmInitAdapter: Cannot initialize GSP firmware RM
[ 87.193609] NVRM: GPU 0000:17:00.0: RmInitAdapter failed! (0x62:0x65:2015)
[ 87.194404] NVRM: GPU 0000:17:00.0: rm_init_adapter failed, device minor number 0
[ 87.194728] NVRM: nvAssertFailedNoLog: Assertion failed: rmapiLockIsOwner() && rmGpuLockIsOwner() @ conf_compute_api.c:78
[ 171.287386] NVRM: GPU at PCI:0000:17:00: GPU-801383be-20e1-a842-5cc3-215ec26f58d3
[ 171.287390] NVRM: Xid (PCI:0000:17:00): 143, Error status 0x65 while polling for FSP boot complete, 0x13, 0x56, 0x0, 0x0, 0x2
[ 171.287398] NVRM: kfspDumpDebugState_GB100: FSP microcode v4.76
[ 171.287399] NVRM: kfspDumpDebugState_GB100: GPU 0000:17:00
[ 171.287402] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(0) = 0x56
[ 171.287404] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(1) = 0x0
[ 171.287406] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(2) = 0x0
[ 171.287407] NVRM: kfspDumpDebugState_GB100: NV_PFSP_FALCON_COMMON_SCRATCH_GROUP_2(3) = 0x2
[ 171.287411] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110040, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 171.287412] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX0 = 0xbadf4100
[ 171.287416] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110044, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 171.287416] NVRM: kfspDumpDebugState_GB100: NV_PGSP_FALCON_MAILBOX1 = 0xbadf4100
[ 171.287420] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110804, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 171.287420] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(0) = 0xbadf4100
[ 171.287424] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110808, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 171.287424] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(1) = 0xbadf4100
[ 171.287428] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x11080c, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 171.287428] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(2) = 0xbadf4100
[ 171.287432] NVRM: gpuHandleSanityCheckRegReadError_GH100: Possible bad register read: addr: 0x110810, regvalue: 0xbadf4100, error code: Unknown SYS_PRI_ERROR_CODE
[ 171.287433] NVRM: kfspDumpDebugState_GB100: NV_PGSP_MAILBOX(3) = 0xbadf4100
[ 171.287501] NVRM: _kfspPrintCms2Log_GB100: CMS2 Log:
[ 171.287501] NVRM: nvDbgDumpBufferBytes: x0 x1 x2 x3 x4 x5 x6 x7 x8 x9 xa xb xc xd xe xf
[ 171.287502] NVRM: nvDbgDumpBufferBytes: FF4DADCD00F37A58 00 00 14 00 56 00 00 00 02 00 00 00 00 00 00 00
[ 171.287503] NVRM: nvDbgDumpBufferBytes: FF4DADCD00F37A68 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 171.287503] NVRM: nvDbgDumpBufferBytes: FF4DADCD00F37A78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 171.287504] NVRM: nvDbgDumpBufferBytes: FF4DADCD00F37A88 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 171.287505] NVRM: nvDbgDumpBufferBytes: FF4DADCD00F37A98 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 171.287505] NVRM: nvDbgDumpBufferBytes: FF4DADCD00F37AA8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 171.287506] NVRM: nvDbgDumpBufferBytes: FF4DADCD00F37AB8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 171.287507] NVRM: nvDbgDumpBufferBytes: FF4DADCD00F37AC8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 171.287507] NVRM: nvDbgDumpBufferBytes: FF4DADCD00F37AD8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 171.287508] NVRM: nvDbgDumpBufferBytes: FF4DADCD00F37AE8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 171.287509] NVRM: nvDbgDumpBufferBytes: FF4DADCD00F37AF8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 171.287509] NVRM: nvDbgDumpBufferBytes: FF4DADCD00F37B08 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 00
[ 171.287511] NVRM: nvCheckOkFailedNoLog: Check failed: Call timed out [NV_ERR_TIMEOUT] (0x00000065) returned from kgspWaitForGfwBootOk_HAL(pGpu, pKernelGsp) @ kernel_gsp.c:3874
[ 171.287552] NVRM: RmInitAdapter: Cannot initialize GSP firmware RM
[ 171.287949] NVRM: GPU 0000:17:00.0: RmInitAdapter failed! (0x62:0x65:2015)
[ 171.289450] NVRM: GPU 0000:17:00.0: rm_init_adapter failed, device minor number 0
Does anyone have an idea how to solve this problem? Any help welcome…
did you solve this, i’m facing a similar issue
Hello hrushirajg23,
No, I haven’t resolved this issue yet. I attempted to compile the kernel module from scratch, but unfortunately, that approach didn’t work for me.
@emanuel.bierschneider thanks for the reply, I have approached nvidia people in around 7,10 threads and also created an issue regarding this on open-gpu-kernel-modules github.
I don’t know why they’re not looking into it
Hi @emanuel.bierschneider , thanks for reporting this issue. This issue is being tracked internally. I think a fix has been identified for this issue and should be released soon. I will provide an update once I have more information.
Hi @hrushirajg23 , I think the issue that you are seeing is different than the one above. We are tracking it internally by Bug 5053788.
Hello @vanditd,
That’s great news! Thanks for the update!
Looking forward to the fix being released.
Same issue here, xid 143. Looking forward to a fix
Is there any workaround? Do older drivers function?
Hello @nvidia1606
I tried several older versions, but none of them worked for me. Do you have xid 143 with a RTX PRO 6000 Workstation card?
I should have added that I have RTX Pro 6000 Max-Q, in case that’s helpful
Yes. A Max-Q
EDIT: The issue is resolved..
I realize that the answer is of course “it will be ready when it’s ready” - but is this days, weeks or months?
I need to determine if I need to purchase different hardware very soon
Thanks, sorry for being a pest 😃
EDIT: Issue is resolved, nevermind me..
I am encountering the same issue with the RTX 5090 on Red Hat 8.8 through 9.6. I have tried numerous approaches to resolve it, including different CUDA drivers, various OS versions, and multiple kernel configurations.
[ 16.497524] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
[ 16.517449] nvidia 0000:23:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 16.532461] nvidia 0000:24:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 16.558820] nvidia 0000:25:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 16.583772] nvidia 0000:27:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 16.610391] nvidia 0000:84:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 16.651527] nvidia 0000:85:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 16.683586] nvidia 0000:86:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 16.709955] nvidia 0000:87:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 16.744789] NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 580.105.08 Release Build (dvs-builder@U22-I3-B10-02-5) Wed Oct 29 22:29:53 UTC 2025
[ 16.988133] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:04.0/0000:27:00.1/sound/card3/input11
[ 17.005614] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:01.0/0000:84:00.1/sound/card4/input15
[ 17.007886] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:01.0/0000:84:00.1/sound/card4/input16
[ 17.013968] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:01.0/0000:84:00.1/sound/card4/input17
[ 17.019722] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:04.0/0000:27:00.1/sound/card3/input12
[ 17.032265] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:01.0/0000:84:00.1/sound/card4/input18
[ 17.038536] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:04.0/0000:27:00.1/sound/card3/input13
[ 17.088124] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:04.0/0000:27:00.1/sound/card3/input14
[ 17.088130] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:04.0/0000:87:00.1/sound/card7/input23
[ 17.104884] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:04.0/0000:87:00.1/sound/card7/input24
[ 17.111238] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:04.0/0000:87:00.1/sound/card7/input25
[ 17.113695] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:04.0/0000:87:00.1/sound/card7/input26
[ 17.180218] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:02.0/0000:85:00.1/sound/card5/input19
[ 17.192714] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:02.0/0000:25:00.1/sound/card2/input7
[ 17.192997] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:02.0/0000:85:00.1/sound/card5/input20
[ 17.194197] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:02.0/0000:25:00.1/sound/card2/input8
[ 17.194201] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:03.0/0000:86:00.1/sound/card6/input27
[ 17.195199] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:02.0/0000:85:00.1/sound/card5/input21
[ 17.195221] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:00.0/0000:23:00.1/sound/card0/input31
[ 17.196359] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:02.0/0000:25:00.1/sound/card2/input9
[ 17.197660] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:01.0/0000:24:00.1/sound/card1/input3
[ 17.198147] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:03.0/0000:86:00.1/sound/card6/input28
[ 17.198892] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:02.0/0000:25:00.1/sound/card2/input10
[ 17.199065] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:02.0/0000:85:00.1/sound/card5/input22
[ 17.199068] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:00.0/0000:23:00.1/sound/card0/input32
[ 17.199959] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:01.0/0000:24:00.1/sound/card1/input4
[ 17.200220] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:03.0/0000:86:00.1/sound/card6/input29
[ 17.200639] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:00.0/0000:23:00.1/sound/card0/input33
[ 17.201280] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:01.0/0000:24:00.1/sound/card1/input5
[ 17.201518] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:80/0000:80:01.1/0000:81:00.0/0000:82:03.0/0000:86:00.1/sound/card6/input30
[ 17.201778] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:00.0/0000:23:00.1/sound/card0/input34
[ 17.201938] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:20/0000:20:01.1/0000:21:00.0/0000:22:01.0/0000:24:00.1/sound/card1/input6
[ 17.407585] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 580.105.08 Release Build (dvs-builder@U22-I3-B10-02-5) Wed Oct 29 22:16:05 UTC 2025
[ 17.444558] [drm] [nvidia-drm] [GPU ID 0x00002300] Loading driver
[ 17.449749] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:23:00.0 on minor 1
[ 17.449755] [drm] [nvidia-drm] [GPU ID 0x00002400] Loading driver
[ 17.455840] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:24:00.0 on minor 2
[ 17.455845] [drm] [nvidia-drm] [GPU ID 0x00002500] Loading driver
[ 17.481631] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:25:00.0 on minor 3
[ 17.481641] [drm] [nvidia-drm] [GPU ID 0x00002700] Loading driver
[ 17.482543] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:27:00.0 on minor 4
[ 17.482565] [drm] [nvidia-drm] [GPU ID 0x00008400] Loading driver
[ 17.483621] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:84:00.0 on minor 5
[ 17.483626] [drm] [nvidia-drm] [GPU ID 0x00008500] Loading driver
[ 17.485993] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:85:00.0 on minor 6
[ 17.485999] [drm] [nvidia-drm] [GPU ID 0x00008600] Loading driver
[ 17.486981] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:86:00.0 on minor 7
[ 17.486987] [drm] [nvidia-drm] [GPU ID 0x00008700] Loading driver
[ 17.487640] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:87:00.0 on minor 8
[ 176.730124] [drm] [nvidia-drm] [GPU ID 0x00008700] Unloading driver
[ 176.730200] [drm] [nvidia-drm] [GPU ID 0x00008600] Unloading driver
[ 176.730258] [drm] [nvidia-drm] [GPU ID 0x00008500] Unloading driver
[ 176.730315] [drm] [nvidia-drm] [GPU ID 0x00008400] Unloading driver
[ 176.730371] [drm] [nvidia-drm] [GPU ID 0x00002700] Unloading driver
[ 176.730425] [drm] [nvidia-drm] [GPU ID 0x00002500] Unloading driver
[ 176.730479] [drm] [nvidia-drm] [GPU ID 0x00002400] Unloading driver
[ 176.730532] [drm] [nvidia-drm] [GPU ID 0x00002300] Unloading driver
[ 176.747129] nvidia-modeset: Unloading
[ 176.760060] nvidia-nvlink: Unregistered Nvlink Core, major device number 238
[root@gnode28 ~]# nvidia-smi
-bash: nvidia-smi: command not found
My issue has resolved.
a combination of:
  • Purging all of the driver/userland software
  • Power cycling
  • Booting into a Linux live CD and using the displaymodeselector tool, to force the GPU into compute-only mode (which disables the display - I don’t need display)
  • Reinstalling the userland and open kernel delivers
Now all is well. 🤷‍♂️
You’re not encountering the same issue - you appear to be missing the userland tools (or have them in an unusual location that isn’t in your PATH)
The error says can’t find the nvidia-smi application, that’s very different than nvidia-smi not finding any devices
I also don’t see any xid error codes in your dmesg output (unless I missed it - try dmesg | grep -i xid)
$ sudo find / -name nvidia-smi 2>/dev/null
If you don’t get any output from that, you don’t have the software installed.
If you do get output, you need to set your PATH variable. And/or, reboot, if you’re certain you did install the userland software
But how can you run the the displaymodeselector tool in Linux live CD? (I use Alma linux 8)
Thank you for your time and your solution
Hello @vanditd,
Are there any updates? Is the fix / workaround already included in datacenter driver version: 580.126.09 ?
