TL;DR, how do I:
- Upgrade the cuda library versions / downgrade the driver version
- Remove a kernel (6.5.0-35) that is somehow “associated” with the linux hwe image / headers
- Made nvidia-modprobe install modules for only one kernel version (5.15.0) instead of both 6.5.0-35 and 5.15.0?
I’m using Ubuntu 22.04 and a GeForce RTX 3090.
— (Main text below) —
I’ve been having some issues loading CUDA 12.1 on my ubuntu device, and I believe it’s because of some issues with the 6.5.0 kernel, based on some searches (check this search). Hence, I tried to install the 5.15.0 kernel through apt-get install for the associated kernel image, headers and module.
I was able to boot up the 5.15.0 kernel without error (and I stopped the needrestart), but now when installing CUDA 12.1 I receive this following error at the end:
Error info
Setting up nvidia-dkms-530 (530.30.02-0ubuntu1) ...
update-initramfs: deferring update (trigger activated)
update-initramfs: Generating /boot/initrd.img-5.15.0-051500-generic
A modprobe blacklist file has been created at /etc/modprobe.d to prevent Nouveau
from loading. This can be reverted by deleting the following file:
/etc/modprobe.d/nvidia-graphics-drivers.conf
A new initrd image has also been created. To revert, please regenerate your
initrd by running the following command after deleting the modprobe.d file:
`/usr/sbin/initramfs -u`
*** Reboot your computer and verify that the NVIDIA graphics driver can ***
*** be loaded. ***
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
Removing old nvidia-530.30.02 DKMS files...
Module nvidia-530.30.02 for kernel 5.15.0-051500-generic (x86_64).
Before uninstall, this module version was ACTIVE on this kernel.
nvidia.ko:
- Uninstallation
- Deleting from: /lib/modules/5.15.0-051500-generic/updates/dkms/
- Original module
- No original module was found for this module on this kernel.
- Use the dkms install command to reinstall any previous module version.
nvidia-modeset.ko:
- Uninstallation
- Original module
nvidia-drm.ko:
- Uninstallation
- Original module
nvidia-peermem.ko:
- Uninstallation
- Original module
nvidia-uvm.ko:
- Uninstallation
- Original module
depmod...
Deleting module nvidia-530.30.02 completely from the DKMS tree.
Loading new nvidia-530.30.02 DKMS files...
Building for 5.15.0-051500-generic 6.5.0-35-generic
Building for architecture x86_64
Building initial module for 5.15.0-051500-generic
Secure Boot not enabled on this system.
Done.
nvidia.ko:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/5.15.0-051500-generic/updates/dkms/
nvidia-modeset.ko:
- Original module
- Installation
nvidia-drm.ko:
- Original module
- Installation
nvidia-peermem.ko:
- Original module
- Installation
nvidia-uvm.ko:
- Original module
- Installation
depmod...
Building initial module for 6.5.0-35-generic
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/nvidia-kernel-source-530.0.crash'
Error! Bad return status for module build on kernel: 6.5.0-35-generic (x86_64)
Consult /var/lib/dkms/nvidia/530.30.02/build/make.log for more information.
dpkg: error processing package nvidia-dkms-530 (--configure):
installed nvidia-dkms-530 package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of cuda-drivers-530:
cuda-drivers-530 depends on nvidia-dkms-530 (>= 530.30.02); however:
Package nvidia-dkms-530 is not configured yet.
dpkg: error processing package cuda-drivers-530 (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-driver-530:
nvidia-driver-530 depends on nvidia-dkms-530 (= 530.30.02-0ubuntu1); however:
dpkg: error processing package nvidia-driver-530 (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of cuda-drivers:
cuda-drivers depends on cuda-drivers-530 (= 530.30.02-1); however:
Package cuda-drivers-530 is not configured yet.
dpkg: error processing package cuda-drivers (--configure):
dpkg: dependency problems prevent configuration of cuda-runtime-12-1:
cuda-runtime-12-1 depends on cuda-drivers (>= 530.30.02); however:
Package cuda-drivers is not configured yet.
dpkg: error processing package cuda-runtime-12-1 (--configure):
dpkg: dependency problems prevent configuration of cuda-12-1:
cuda-12-1 depends on cuda-runtime-12-1 (>= 12.1.0); however:
Package cuda-runtime-12-1 is not configured yet.
dpkg: error processing package cuda-12-1 (--configure):
dpkg: dependency problems prevent configuration of cuda:
cuda depends on cuda-12-1 (>= 12.1.0); however:
Package cuda-12-1 is not configured yet.No apport report written because MaxReports is reached already
dpkg: error processing package cuda (--configure):
dpkg: dependency problems prevent configuration of cuda-demo-suite-12-1:
cuda-demo-suite-12-1 depends on cuda-runtime-12-1; however:
dpkg: error processing package cuda-demo-suite-12-1 (--configure):
Processing triggers for initramfs-tools (0.140ubuntu13.4) ...
Errors were encountered while processing:
nvidia-dkms-530
cuda-drivers-530
nvidia-driver-530
cuda-drivers
cuda-runtime-12-1
cuda-12-1
cuda
E: Sub-process /usr/bin/dpkg returned an error code (1)
Mainly, note the info Building for 5.15.0-051500-generic 6.5.0-35-generic. This implies that, even though I’ve booted up 5.15.0-051500-generic, it’s still setting up the nvidia modules for 6.5.0-35-generic as well - and that version is where it fails. The installation works okay, though, for 5.15.0-051500-generic - but I do remember that there was some kind of “needrestart not used” error message.
Regardless, it was working fine for a bit, then Failed to initialize NVML: Driver/library version mismatch. On the day before, checking /var/log/apt/history.log I found:
Log info
Start-Date: 2024-06-08 06:19:43
Commandline: /usr/bin/unattended-upgrade
Install: libnvidia-common-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), libnvidia-fbc1-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), libnvidia-gl-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), libnvidia-extra-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), nvidia-compute-utils-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), nvidia-dkms-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), nvidia-driver-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), libnvidia-encode-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), nvidia-utils-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), xserver-xorg-video-nvidia-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), libnvidia-decode-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), nvidia-kernel-common-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), nvidia-firmware-535-535.171.04:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), libnvidia-cfg1-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), nvidia-kernel-source-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic), libnvidia-compute-535:amd64 (535.171.04-0ubuntu0.22.04.1, automatic)
Upgrade: libnvidia-common-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), libnvidia-fbc1-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), libnvidia-gl-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), libnvidia-extra-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), nvidia-compute-utils-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), nvidia-dkms-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), nvidia-driver-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), libnvidia-encode-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), nvidia-utils-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), xserver-xorg-video-nvidia-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), libnvidia-decode-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), nvidia-kernel-common-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), libnvidia-cfg1-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), nvidia-kernel-source-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1), libnvidia-compute-530:amd64 (530.30.02-0ubuntu1, 535.171.04-0ubuntu0.22.04.1)
Error: Sub-process /usr/bin/dpkg returned an error code (1)
End-Date: 2024-06-08 06:19:48
Note how there’s no user that updated this, and hence I believe that the library version is probably something like 535.182, but not 535.172 which is desired by the driver (I did get an extra message from nvidia-smi about the library version being 535.182 at the beginning as well).
So I think I have a few options:
- Figure out how to downgrade my libraries / upgrade my driver.
- Remove kernel version 6.5.0
- Let nvidia-modprobe only install for kernel version 5.15.0
For 1, it’s not so clear how to do this. 2 seems likely, but when I tried to do so, I receive this info:
Log info
The following packages were automatically installed and are no longer required:
amd64-microcode linux-headers-generic-hwe-22.04 thermald
Use ‘sudo apt autoremove’ to remove them.
The following packages will be REMOVED:
linux-generic-hwe-22.04* linux-image-6.5.0-35-generic* linux-image-generic-hwe-22.04*
0 upgraded, 0 newly installed, 3 to remove and 55 not upgraded.
8 not fully installed or removed.
After this operation, 14.3 MB disk space will be freed.
I probably don’t want to remove the linux hwe kernel - just an instinct. And perhaps this gives some insight for 3 - nvidia-modprobe probably is installing the kernel modules for the “main” version, for which the hwe kernel is associated, or 6.5.0-35-generic. So perhaps I’d like to find a way to “de-main”-ify the 6.5.0 kernel or remove the kernel entirely.
How do I do either one of these 3 things? Thank you very much!
