Brief
Symptom:
32-bit apps get very slow OpenGL rendering. 32-bit glxgears get around 3 fps (SIC!). 64-bit apps work ok.
Nvidia drivers:
Tried 340.46 and 343.22 and both suffered the same symptoms.
System:
New system, Haswell-E CPU, Nvidia GeForce GTX 750 Ti GPU. No prior working configuration.
Operating system
Up to date Debian Sid, kernel 3.16.5 from distro and also tried a self made 3.17.1. NVidia drivers from distro install, but verified that the binaries match the nvidia installer provided ones.
Detail
I was having problems getting 3D to work in Wine, so I narrowed down the problem to using a 32-bit glxgears and got only 3fps with it. It’s displaying the gears moving slowly though…
(and obviously the 64-bit version of glxgears gets a decent 17 kfps :) )
glxgears seems to use nvidia:s .so:s as seen in ldd:
linux-gate.so.1 (0xf7773000)
libGLEW.so.1.10 => /usr/lib/i386-linux-gnu/libGLEW.so.1.10 (0xf76d3000)
libGLU.so.1 => /usr/lib/i386-linux-gnu/libGLU.so.1 (0x4906c000)
libGL.so.1 => /usr/lib/i386-linux-gnu/libGL.so.1 (0xf75b9000)
libm.so.6 => /lib/i386-linux-gnu/i686/cmov/libm.so.6 (0xf7573000)
libX11.so.6 => /usr/lib/i386-linux-gnu/libX11.so.6 (0xf7421000)
libXext.so.6 => /usr/lib/i386-linux-gnu/libXext.so.6 (0xf740c000)
libc.so.6 => /lib/i386-linux-gnu/i686/cmov/libc.so.6 (0xf7261000)
libXmu.so.6 => /usr/lib/i386-linux-gnu/libXmu.so.6 (0x496e6000)
libXi.so.6 => /usr/lib/i386-linux-gnu/libXi.so.6 (0xf724e000)
libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xf715c000)
libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xf713f000)
libnvidia-tls.so.343.22 => /usr/lib/i386-linux-gnu/tls/libnvidia-tls.so.343.22 (0xf713a000)
libnvidia-glcore.so.343.22 => /usr/lib/i386-linux-gnu/libnvidia-glcore.so.343.22 (0xf4b2f000)
libdl.so.2 => /lib/i386-linux-gnu/i686/cmov/libdl.so.2 (0xf4b2a000)
/lib/ld-linux.so.2 (0xf7774000)
libxcb.so.1 => /usr/lib/i386-linux-gnu/libxcb.so.1 (0x44fee000)
libXt.so.6 => /usr/lib/i386-linux-gnu/libXt.so.6 (0x453d3000)
libXau.so.6 => /usr/lib/i386-linux-gnu/libXau.so.6 (0x4501a000)
libXdmcp.so.6 => /usr/lib/i386-linux-gnu/libXdmcp.so.6 (0x45012000)
libSM.so.6 => /usr/lib/i386-linux-gnu/libSM.so.6 (0xf4b1f000)
libICE.so.6 => /usr/lib/i386-linux-gnu/libICE.so.6 (0xf4b01000)
libuuid.so.1 => /lib/i386-linux-gnu/libuuid.so.1 (0xf4afb000)
strace also shows that it’s opening /dev/nvidiactl and /dev/nvidia0 sucessfully. And probably submitting, albeit slowly, data to the gpu (fd 4 == /dev/nvidiactl):
1414512607.989459 time(NULL) = 1414512607
1414512607.989495 ioctl(4, 0xc030464e, 0xffd01820) = 0
1414512607.989568 time(NULL) = 1414512607
1414512607.989603 ioctl(4, 0xc020464f, 0xffd01850) = 0
1414512607.989668 time(NULL) = 1414512607
1414512607.989703 ioctl(4, 0xc030464e, 0xffd01820) = 0
1414512607.989774 time(NULL) = 1414512607
1414512607.989808 ioctl(4, 0xc020464f, 0xffd01850) = 0
.. lots of yielding..
1414512608.000679 time(NULL) = 1414512608
1414512608.000714 ioctl(4, 0xc030464e, 0xffd054d0) = 0
1414512608.000790 time(NULL) = 1414512608
1414512608.000826 ioctl(4, 0xc020464f, 0xffd05500) = 0
1414512608.000887 time(NULL) = 1414512608
1414512608.000923 ioctl(4, 0xc030464e, 0xffd054d0) = 0
1414512608.000993 time(NULL) = 1414512608
1414512608.001028 ioctl(4, 0xc020464f, 0xffd05500) = 0
[UPDATE: thanks tuke81 I can’t seem to locate the attach file button here, so in case the nvidia-bug-report.log.gz is crucial I may have to try harder.]
[UPDATE]
Attached nvidia-bug-report and glxinfo output from 32-bit, which is identical to the 64-bit one (and direct rendering: Yes).
[UPDATE 2014-10-30]
ltrace shows me that glXSwapBuffer is taking >120ms to complete in 32-bit glxgears when the 64-bit version is almost instant (mostly < 1ms). Also the 32-bit glxgears is doing ioctl:s on every glXSwapBuffer when the 64-bit version is doing it seldomly.
Attaching ltrace from both 32-bit and 64-bit glxgears (using no YIELD:ing for cleaner trace).
__GL_YIELD="NOTHING" ltrace -S -T -n 2 -ttt -o glxgears-64-ltrace-out.txt glxgears
__GL_YIELD="NOTHING" ltrace -S -T -n 2 -ttt -o glxgears-32-ltrace-out.txt ./glxgears # 32-bit
nvidia-bug-report.log.gz (139 KB)
glxinfo-32-out.txt (49.2 KB)
glxgears-32-ltrace-out.txt (1.24 MB)
glxgears-64-ltrace-out.txt.gz (661 KB)
