System: Dell Inspiron 5840
GPU: NVIDIA GeForce MX150 (2GB GDDR5)
OS: Ubuntu 18.04.2 LTS
Kernel: 5.0.5-050005-generic
Nvidia driver: 418.56 from graphic PPA
The problem started after enabling Nvidia driver for X server it will randomly freeze and require a hard restart.
After searching for about 3 days, I found one thing is working for me. I can stop freezing by setting up PowerMizer to be Perfer Maximum Performance after booting to Ubuntu desktop.
It works as a switch to Intel GPU via prime-select for daily use and to Nvidia for GPU intensive application.
After testing, when it enters PowerMizer level 0 it will cause GPU has fallen off the bus and the system will hang.
I dig a bit deeper and found that every PowerMizer profile change it will effect PCI generation config. I have no idea while but what happens is Profile 3 (maximum performance) has PCI-E gen 3, Profile 2 has PCI-E gen 2, and Profile 1 has PCI-E gen 1.
Is there have any solution for this problem? If anyone has the same problem, could you try my method and monitor PowerMize state?
Thank
