[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3531) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Mar 13 00:32:22 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc0fefd2000 s53400 r8192 d32616 u94208
[ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29492(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3576064K/4159488K available (15166K kernel code, 2914K rwdata, 6616K rodata, 8512K init, 605K bss, 108288K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001471] Console: colour dummy device 80x25
[ 0.002323] console [tty0] enabled
[ 0.002349] kmemleak: Kernel memory leak detector disabled
[ 0.002378] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.002407] pid_max: default: 32768 minimum: 301
[ 0.002871] Security Framework initialized
[ 0.003101] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003121] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004315] ftrace: allocating 46802 entries in 183 pages
[ 0.174212] sched-energy: CPU device node has no sched-energy-costs
[ 0.174243] ASID allocator initialised with 65536 entries
[ 0.211398] tegra-id: chipid=22117.
[ 0.211443] tegra-id: opt_subrevision=0.
[ 0.211470] Tegra Speedo/IDDQ fuse revision 4
[ 0.211486] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211502] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.211519] Tegra: CPU Speedo Value 2067, SoC Speedo Value 1975, GPU Speedo Value 2085
[ 0.211540] Tegra: CPU IDDQ Value 2140, SoC IDDQ Value 2572, GPU IDDQ Value 3170
[ 0.211575] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.211601] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.211635] DTB Build time: Mar 15 2019 09:52:07
[ 0.261054] CPU1: Booted secondary processor [411fd071]
[ 0.292946] CPU2: Booted secondary processor [411fd071]
[ 0.324933] CPU3: Booted secondary processor [411fd071]
[ 0.325020] Brought up 4 CPUs
[ 0.325083] SMP: Total of 4 processors activated.
[ 0.325101] CPU features: detected feature: 32-bit EL0 Support
[ 0.325375] CPU: All CPU(s) started at EL2
[ 0.325404] alternatives: patching kernel code
[ 0.333371] devtmpfs: initialized
[ 0.367816] Initilizing CustomIPI irq domain
[ 0.368222] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.368266] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.378764] pinctrl core: initialized pinctrl subsystem
[ 0.379380] OS set in device tree is not L4T.
[ 0.379787] regulator-dummy: no parameters
[ 0.380062] Initializing plugin-manager
[ 0.380224] Plugin module not found
[ 0.380448] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.380986] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.381804] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.385036] NET: Registered protocol family 16
[ 0.386374] pstore: using zlib compression
[ 0.387006] console [pstore-1] enabled
[ 0.387023] pstore: Registered ramoops as persistent store backend
[ 0.387042] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.401073] cpuidle: using governor menu
[ 0.404852] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.406351] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.406399] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.409472] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.410949] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.411899] tegra_powergate_init: DONE
[ 0.411940] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.411978] DTB Build time: Mar 15 2019 09:52:07
[ 0.413635] Tegra reboot handler registered.
[ 0.417956] iommu: Adding device tegra-carveouts to group 0
[ 0.418130] platform tegra-carveouts: domain=ffffffc0f9b9c318 allocates as[0]=ffffffc0f9b940a8
[ 0.418500] iommu: Adding device smmu_test to group 1
[ 0.418569] platform smmu_test: domain=ffffffc0f9b9c558 allocates as[0]=ffffffc0f9b94110
[ 0.419402] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.419475] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.419551] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.419574] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.419608] mc-err: mcerr ops are set to t21x
[ 0.429325] iommu: Adding device 70090000.xusb to group 2
[ 0.429639] iommu: Adding device 70006000.serial to group 3
[ 0.429742] platform 70006000.serial: domain=ffffffc0f946c618 allocates as[0]=ffffffc0f9b94178
[ 0.430189] iommu: Adding device 70006040.serial to group 4
[ 0.430474] iommu: Adding device 70006200.serial to group 5
[ 0.430709] iommu: Adding device sound to group 6
[ 0.430770] platform sound: domain=ffffffc0f946cb58 allocates as[0]=ffffffc0f9b941e0
[ 0.431338] iommu: Adding device 7000d400.spi to group 7
[ 0.431620] iommu: Adding device 7000d600.spi to group 8
[ 0.431911] iommu: Adding device 70410000.spi to group 9
[ 0.432232] iommu: Adding device 50000000.host1x to group 10
[ 0.432526] iommu: Adding device 54080000.vi to group 11
[ 0.432935] iommu: Adding device 54600000.isp to group 12
[ 0.433264] iommu: Adding device 54680000.isp to group 13
[ 0.433589] iommu: Adding device tegradc.0 to group 14
[ 0.433661] platform tegradc.0: domain=ffffffc0f9479a98 allocates as[0]=ffffffc0f9b94248
[ 0.434196] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.434525] iommu: Adding device tegradc.1 to group 15
[ 0.434589] platform tegradc.1: domain=ffffffc0f9479cd8 allocates as[0]=ffffffc0f9b942b0
[ 0.435122] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.435379] iommu: Adding device 54340000.vic to group 16
[ 0.435608] iommu: Adding device 544c0000.nvenc to group 17
[ 0.435816] iommu: Adding device 54500000.tsec to group 18
[ 0.436028] iommu: Adding device 54100000.tsecb to group 19
[ 0.436242] iommu: Adding device 54480000.nvdec to group 20
[ 0.436480] iommu: Adding device 54380000.nvjpg to group 21
[ 0.437632] iommu: Adding device 546c0000.i2c to group 22
[ 0.437980] iommu: Adding device 57000000.gpu to group 23
[ 0.438050] platform 57000000.gpu: domain=ffffffc0f9484cd8 allocates as[0]=ffffffc0f9b94318
[ 0.438109] platform 57000000.gpu: domain=ffffffc0f9484cd8 allocates as[1]=ffffffc0f9b94380
[ 0.438170] platform 57000000.gpu: domain=ffffffc0f9484cd8 allocates as[2]=ffffffc0f9b943e8
[ 0.438229] platform 57000000.gpu: domain=ffffffc0f9484cd8 allocates as[3]=ffffffc0f9b94450
[ 0.439132] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.439172] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.439200] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.439220] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.439237] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.489122] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.489153] tegra-pmc: Clear bootloader IO dpd settings
[ 0.489188] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.489271] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.489590] iommu: Adding device 70012000.se to group 24
[ 0.490385] iommu: Adding device 7000c000.i2c to group 25
[ 0.490649] iommu: Adding device 7000c400.i2c to group 26
[ 0.490917] iommu: Adding device 7000c500.i2c to group 27
[ 0.491183] iommu: Adding device 7000c700.i2c to group 28
[ 0.491489] iommu: Adding device 7000d000.i2c to group 29
[ 0.491753] iommu: Adding device 7000d100.i2c to group 30
[ 0.492056] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.492122] platform sdhci-tegra.0: domain=ffffffc0f953be58 allocates as[0]=ffffffc0f9b944b8
[ 0.493004] iommu: Adding device 700d0000.xudc to group 32
[ 0.497575] vdd-ac-bat: 5000 mV
[ 0.497939] vdd-5v0-sys: 5000 mV
[ 0.498914] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.498997] vdd-5v0-hdmi: 5000 mV
[ 0.499414] vdd-1v8: 1800 mV
[ 0.499826] vdd-fan: supplied by vdd-5v0-sys
[ 0.499878] vdd-fan: 5000 mV
[ 0.500266] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.500336] vdd-usb-vbus: 5000 mV
[ 0.500892] vdd-usb-vbus2: 5000 mV
[ 0.538398] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.540856] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.541403] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.549170] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.549529] SCSI subsystem initialized
[ 0.549774] libata version 3.00 loaded.
[ 0.550052] usbcore: registered new interface driver usbfs
[ 0.550119] usbcore: registered new interface driver hub
[ 0.550210] usbcore: registered new device driver usb
[ 0.554214] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.555877] random: fast init done
[ 0.561213] vdd-core: 600 <--> 1162 mV at 1075 mV
[ 0.562483] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.565071] vdd-ddr-1v1: 1150 mV
[ 0.569066] vdd-pre-reg-1v35: 1350 mV
[ 0.573068] vdd-1v8: 1800 mV
[ 0.573339] vdd-1v8: Failed to create debugfs directory
[ 0.577066] avdd-sys-1v2: 1200 mV
[ 0.581066] vdd-pex-1v0: 1050 mV
[ 0.581847] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.582519] max77620-ldo3: at 3100 mV
[ 0.585069] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.585708] max77620-ldo5: at 3100 mV
[ 0.586352] max77620-ldo6: at 2800 mV
[ 0.589067] avdd-1v05-pll: 1050 mV
[ 0.593067] avdd-io-hdmi-dp: 1050 mV
[ 0.594602] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.594880] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.596948] max77620 4-003c: max77620 probe successful
[ 0.599187] i2c i2c-6: Unbalanced pm_runtime_enable!
[ 0.599723] media: Linux media interface: v0.10
[ 0.599790] Linux video capture interface: v2.00
[ 0.600682] pps_core: LinuxPPS API ver. 1 registered
[ 0.600711] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.600754] PTP clock support registered
[ 0.603997] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.610315] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.611134] Advanced Linux Sound Architecture Driver Initialized.
[ 0.611803] Bluetooth: Core ver 2.22
[ 0.611873] NET: Registered protocol family 31
[ 0.611892] Bluetooth: HCI device and connection manager initialized
[ 0.611919] Bluetooth: HCI socket layer initialized
[ 0.611940] Bluetooth: L2CAP socket layer initialized
[ 0.611980] Bluetooth: SCO socket layer initialized
[ 0.613728] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.613768] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.613832] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.613859] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.616592] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.617961] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.618073] vdd-3v3-sys: 3300 mV
[ 0.618359] vdd-1v8: supplied by vdd-3v3-sys
[ 0.621137] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.621610] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.621663] vdd-3v3-sd: 3300 mV
[ 0.622836] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.622893] avdd-io-edp-1v05: 1050 mV
[ 0.623383] vdd-usb-hub-en: supplied by vdd-1v8
[ 0.623434] vdd-usb-hub-en: 5000 mV
[ 0.624830] camchar: rtcpu character device driver loaded
[ 0.625607] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.626938] clocksource: Switched to clocksource arch_sys_counter
[ 0.667435] VFS: Disk quotas dquot_6.6.0
[ 0.667595] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.668094] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.668522] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.668575] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.668791] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.668818] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.668852] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.668904] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.668930] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.668962] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.668984] nvmap_page_pool_init: Total RAM pages: 1012800
[ 0.669002] nvmap_page_pool_init: nvmap page pool size: 126600 pages (494 MB)
[ 0.669116] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.669528] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.670479] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.678572] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.679011] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.679287] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.679518] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.679722] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.680026] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.680046] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.680486] NET: Registered protocol family 2
[ 0.681450] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.681687] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.682197] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.682357] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.682456] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.682883] NET: Registered protocol family 1
[ 0.683742] RPC: Registered named UNIX socket transport module.
[ 0.683771] RPC: Registered udp transport module.
[ 0.683788] RPC: Registered tcp transport module.
[ 0.683805] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.683831] PCI: CLS 0 bytes, default 64
[ 0.684060] Trying to unpack rootfs image as initramfs...
[ 0.693509] host1x 50000000.host1x: initialized
[ 0.695355] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.698459] audit: initializing netlink subsys (disabled)
[ 0.698568] audit: type=2000 audit(0.547:1): initialized
[ 0.699420] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.709558] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.711155] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.711973] 9p: Installing v9fs 9p2000 file system support
[ 0.715296] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.715495] io scheduler noop registered
[ 0.715802] io scheduler cfq registered (default)
[ 0.718415] gic 702f9000.agic: GIC IRQ controller registered
[ 0.721227] iommu: Adding device 702ef000.adsp to group 33
[ 0.728137] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.728329] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.728949] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x7a08c0f
[ 0.728980] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.730583] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.730713] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.730840] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.731097] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.731214] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.731343] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.731451] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.731559] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.731663] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.731769] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.738277] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.739629] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.741481] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.742772] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 0.743209] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 0.744413] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.744668] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.744931] Adding domain tsec-pd to PM domain host1x-pd
[ 0.746987] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 0.747883] tsec 54500000.tsec: initialized
[ 0.749514] tsec 54100000.tsecb: initialized
[ 0.750238] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.753357] nvdec 54480000.nvdec: initialized
[ 0.754427] Adding domain vic03-pd to PM domain host1x-pd
[ 0.754626] Adding domain msenc-pd to PM domain host1x-pd
[ 0.754807] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.758624] falcon 54340000.vic: initialized
[ 0.759886] falcon 544c0000.nvenc: initialized
[ 0.761227] falcon 54380000.nvjpg: initialized
[ 0.765774] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 0.765896] display board info: id 0x0, fab 0x0
[ 0.765971] generic_infoframe_type: 0x87
[ 0.766107] tegradc tegradc.0: DT parsed successfully
[ 0.766167] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 0.772795] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.775957] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.776557] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.776839] kfuse 7000fc00.kfuse: initialized
[ 0.777756] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 0.778627] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.779610] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.779641] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 0.780022] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.780790] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 0.780827] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.780848] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 0.780869] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 0.780894] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.780949] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 0.781075] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.781325] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 0.781417] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.781602] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.781641] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.781839] pci 0000:01:00.0: [8086:24fd] type 00 class 0x028000
[ 0.781899] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[ 0.782190] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.783504] vdd-gpu: applied init 1000000uV constraint
[ 0.783532] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 0.783904] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.787667] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.787834] No Device Node present for smmu client: serial8250 !!
[ 0.787863] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.787927] iommu: Adding device serial8250 to group 35
[ 0.790392] console [ttyS0] disabled
[ 0.790489] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 0.795107] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.795316] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.795352] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 0.795396] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 0.795425] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 0.795648] pci 0000:02:00.0: supports D1 D2
[ 0.795651] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.801043] tegradc tegradc.0: probed
[ 0.811152] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 0.811301] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 0.811308] pci 0000:00:02.0: BAR 14: assigned [mem 0x13100000-0x131fffff]
[ 0.811313] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.811331] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13001fff 64bit]
[ 0.811368] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.811382] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 0.811399] pci 0000:02:00.0: BAR 4: assigned [mem 0x13100000-0x13103fff 64bit]
[ 0.811425] pci 0000:02:00.0: BAR 2: assigned [mem 0x13104000-0x13104fff 64bit]
[ 0.811448] pci 0000:02:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 0.811458] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 0.811462] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 0.811469] pci 0000:00:02.0: bridge window [mem 0x13100000-0x131fffff]
[ 0.813261] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 0.813268] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.813278] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 0.813514] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 0.813818] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 0.813823] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 0.813830] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 0.813940] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 3.161362] console [ttyS0] enabled
[ 3.162132] Console: switching to colour frame buffer device 320x90
[ 3.163085] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.163470] serial-tegra 70006200.serial: RX in PIO mode
[ 3.163578] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.164744] [drm] Initialized
[ 3.180819] brd: module loaded
[ 3.186086] loop: module loaded
[ 3.186180] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.186295] tegra_profiler: auth: init
[ 3.187742] THERMAL EST: found 2 subdevs
[ 3.187748] THERMAL EST num_resources: 0
[ 3.187753] [THERMAL EST subdev 0]
[ 3.187760] [THERMAL EST subdev 1]
[ 3.188207] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.188209] THERMAL EST: thz register success.
[ 3.188379] THERMAL EST: end of probe, return err: 0
[ 3.189431] hisi_sas: driver version v1.6
[ 3.193343] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.194527] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.194536] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.197776] libphy: Fixed MDIO Bus: probed
[ 3.198340] tun: Universal TUN/TAP device driver, 1.6
[ 3.198342] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.199816] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.199819] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.199877] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.199879] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.199932] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.199935] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.199987] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.199990] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.200901] r8168 0000:02:00.0: enabling device (0000 -> 0003)
[ 3.200931] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.215737] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.215778] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 3.216431] PPP generic driver version 2.4.2
[ 3.216641] PPP BSD Compression module registered
[ 3.216647] PPP Deflate Compression module registered
[ 3.216688] PPP MPPE Compression module registered
[ 3.216695] NET: Registered protocol family 24
[ 3.216768] usbcore: registered new interface driver r8152
[ 3.216815] usbcore: registered new interface driver asix
[ 3.216887] usbcore: registered new interface driver ax88179_178a
[ 3.216926] usbcore: registered new interface driver cdc_ether
[ 3.216963] usbcore: registered new interface driver net1080
[ 3.217004] usbcore: registered new interface driver cdc_subset
[ 3.217043] usbcore: registered new interface driver zaurus
[ 3.217102] usbcore: registered new interface driver cdc_ncm
[ 3.217270] VFIO - User Level meta-driver version: 0.3
[ 3.218520] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.218544] ehci-pci: EHCI PCI platform driver
[ 3.218591] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.218602] ohci-pci: OHCI PCI platform driver
[ 3.218651] ohci-platform: OHCI generic platform driver
[ 3.221401] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.224522] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.225733] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9738400 id
[ 3.225840] tegra-xusb 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 3.225844] tegra-xusb 70090000.xusb: Falling back to user helper
[ 3.227230] usbcore: registered new interface driver uas
[ 3.227285] usbcore: registered new interface driver usb-storage
[ 3.227393] usbcore: registered new interface driver usbserial
[ 3.231521] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.232782] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.232795] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 3.232810] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 3.232830] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 3.232851] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 3.233519] mousedev: PS/2 mouse device common for all mice
[ 3.233608] usbcore: registered new interface driver xpad
[ 3.365964] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.368600] rtc rtc1: alarm rtc device
[ 3.368624] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.368653] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.369208] i2c /dev entries driver
[ 3.370997] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.394317] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.394382] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.394409] imx219 6-0010: board setup failed
[ 3.394506] imx219: probe of 6-0010 failed with error -121
[ 3.395572] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.398765] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.398769] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.399253] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.399269] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.399278] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.399409] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.399418] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.399424] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.399572] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.399582] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.399586] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.399762] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.400534] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.400592] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.400616] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.400633] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.400642] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.401683] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.401703] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 3.401933] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.401966] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 3.402508] parse_throttle_dt_data: Num cap clks = 6
[ 3.402514] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.402528] parse_throttle_dt_data: clk=gpu type=4
[ 3.402557] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.402578] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.402601] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.402603] parse_throttle_dt_data: clk=emc type=3
[ 3.403156] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.403300] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.403498] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.404395] FAN dev name: pwm-fan
[ 3.404451] FAN:gpio request success.
[ 3.404525] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.404835] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.405038] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.405050] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.405149] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.405154] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.405157] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.405161] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.405164] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.405168] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.405171] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.405174] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.405178] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.405181] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.405869] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 3.406207] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 3.407138] device-mapper: uevent: version 1.0.3
[ 3.407605] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.413059] tegra210-cpufreq cpufreq: probe()...completed
[ 3.413804] sdhci: Secure Digital Host Controller Interface driver
[ 3.413805] sdhci: Copyright(c) Pierre Ossman
[ 3.413806] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.414296] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.414650] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.414771] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.418234] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.418867] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.420330] usbcore: registered new interface driver usbhid
[ 3.420331] usbhid: USB HID core driver
[ 3.422477] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 3.422643] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.424533] nvpmodel: initialized successfully
[ 3.425515] usbcore: registered new interface driver snd-usb-audio
[ 3.425574] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.425578] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.425595] iommu: Adding device snd-soc-dummy to group 36
[ 3.437470] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 3.448665] OPE platform probe
[ 3.448753] OPE platform probe successful
[ 3.449138] OPE platform probe
[ 3.449224] OPE platform probe successful
[ 3.463141] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.475696] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.475829] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.475953] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.476078] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.476198] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.476322] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.476448] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.476569] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.476697] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.476820] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.489189] u32 classifier
[ 3.489190] Actions configured
[ 3.489263] Initializing XFRM netlink socket
[ 3.490004] NET: Registered protocol family 10
[ 3.490738] NET: Registered protocol family 17
[ 3.490749] NET: Registered protocol family 15
[ 3.490822] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.490867] Bluetooth: RFCOMM socket layer initialized
[ 3.490875] Bluetooth: RFCOMM ver 1.11
[ 3.490879] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.490883] Bluetooth: HIDP socket layer initialized
[ 3.490901] 9pnet: Installing 9P2000 support
[ 3.491000] Key type dns_resolver registered
[ 3.492194] Registered cp15_barrier emulation handler
[ 3.492203] Registered setend emulation handler
[ 3.493262] registered taskstats version 1
[ 3.493908] Adding domain ve2-pd to PM domain host1x-pd
[ 3.494150] Adding domain ve-pd to PM domain host1x-pd
[ 3.807634] mmc0: hw tuning done ...
[ 3.807673] mmc0: new ultra high speed SDR104 SDXC card at address 0007
[ 3.807979] mmcblk0: mmc0:0007 SD64G 57.9 GiB
[ 3.812200] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 4.323155] tegradc tegradc.0: fb registered
[ 4.359458] tegradc tegradc.0: nominal-pclk:241699200 parent:241696875 div:1.0 pclk:241696875 239282208~263452128
[ 4.369772] tegradc tegradc.0: hdmi: tmds rate:241699K prod-setting:prod_c_hdmi_150m_300m
[ 4.378934] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 4.384684] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 4.393655] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 4.399750] Extcon AUX1(HDMI) enable
[ 4.403748] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 4.410157] tegradc tegradc.1: No lt-data, using default setting
[ 4.416175] tegradc tegradc.1: No hpd-gpio in DT
[ 4.420809] tegradc tegradc.1: DT parsed successfully
[ 4.425880] tegradc tegradc.1: Display dc.ffffff800f4c0000 registered with id=1
[ 4.433870] tegradc tegradc.1: dpd enable lookup fail:-19
[ 4.443196] tegradc tegradc.1: probed
[ 4.461189] tegradc tegradc.1: fb registered
[ 4.468595] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 4.472075] isp 54600000.isp: initialized
[ 4.472866] isp 54680000.isp: initialized
[ 4.483781] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 4.484457] clk_cbus_recalc_rate: no gbus parent
[ 4.484461] clk_cbus_round_rate: no gbus parent
[ 4.484462] clk_cbus_round_rate: no gbus parent
[ 4.484468] clk_cbus_recalc_rate: no gbus parent
[ 4.484570] clk_cbus_recalc_rate: no gbus parent
[ 4.484572] clk_cbus_round_rate: no gbus parent
[ 4.484574] clk_cbus_round_rate: no gbus parent
[ 4.484577] clk_cbus_recalc_rate: no gbus parent
[ 4.484590] tegra_dvfs: GPU-cap: registered
[ 4.484646] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.484648] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.484650] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000uV, scaling enabled
[ 4.486747] tegra_dvfs: vdd-gpu-vts: registered
[ 4.487786] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 4.488409] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 4.488892] input: gpio-keys as /devices/gpio-keys/input/input1
[ 4.523862] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:27 UTC (946688427)
[ 4.524785] vi 54080000.vi: vi_probe: ++
[ 4.528623] vi 54080000.vi: initialized
[ 4.531025] vi 54080000.vi: subdev nvcsi--1 bound
[ 4.531240] mmcblk mmc0:0007: Card claimed for testing.
[ 4.532402] Disable partitions left on by BL
[ 4.532404] disb
[ 4.532449] bwmgr: missing cdev-type property
[ 4.532542] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.532548] DRAM derating cdev registered.
[ 4.533515] vdd-1v8: disabling
[ 4.533518] vdd-fan: disabling
[ 4.533519] vdd-usb-vbus: disabling
[ 4.533521] vdd-usb-vbus2: disabling
[ 4.533530] avdd-io-edp-1v05: disabling
[ 4.533531] vdd-usb-hub-en: disabling
[ 4.533691] ALSA device list:
[ 4.533693] #0: tegra-hda at 0x70038000 irq 83
[ 4.533694] #1: tegra-snd-t210ref-mobile-rt565x
[ 4.673588] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 4.679092] tegradc tegradc.1: blank - powerdown
[ 4.683729] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 4.694030] Extcon DP: HPD disabled
[ 4.697524] hpd: hpd_switch 0
[ 4.700492] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 4.707234] tegradc tegradc.0: blank - powerdown
[ 4.740593] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 4.740597] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 4.757464] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 4.757466] Extcon AUX1(HDMI) disable
[ 4.791860] tegradc tegradc.0: unblank
[ 4.830311] tegradc tegradc.0: nominal-pclk:241500000 parent:241500000 div:1.0 pclk:241500000 239085000~263235000
[ 4.830360] tegradc tegradc.0: hdmi: tmds rate:241500K prod-setting:prod_c_hdmi_150m_300m
[ 4.831455] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 4.831461] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 4.834728] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 4.834729] Extcon AUX1(HDMI) enable
[ 4.835066] tegradc tegradc.0: sync windows ret = 250
[ 4.964704] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 4.973808] Extcon HDMI: HPD enabled
[ 4.980324] tegradc tegradc.0: hdmi: plugged
[ 5.708690] EXT4-fs (mmcblk0p1): 27 orphan inodes deleted
[ 5.716908] EXT4-fs (mmcblk0p1): recovery complete
[ 5.772721] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.783615] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.796922] devtmpfs: mounted
[ 5.805784] Freeing unused kernel memory: 8512K
[ 6.018497] systemd[1]: System time before build time, advancing clock.
[ 6.063270] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.085048] cgroup: cgroup2: unknown option "nsdelegate"
[ 6.107573] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 6.132664] systemd[1]: Detected architecture arm64.
[ 6.174617] systemd[1]: Set hostname to <ai-desktop>.
[ 6.273507] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 6.293603] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.436610] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.448001] systemd[1]: Created slice User and Session Slice.
[ 6.460443] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.471625] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.487529] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.498246] systemd[1]: Created slice System Slice.
[ 6.509991] systemd[1]: Listening on Journal Socket.
[ 6.524054] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 6.646783] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.695236] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 7.004962] systemd-journald[1959]: Received request to flush runtime journal from PID 1
[ 7.769059] tegra-xusb 70090000.xusb: cannot find firmware....retry after 1 second
[ 7.883445] using random self ethernet address
[ 7.883447] using random host ethernet address
[ 7.973760] Mass Storage Function, version: 2009/09/11
[ 7.973763] LUN: removable file: (no medium)
[ 7.975192] nvs_dsm nvs_dsm: dsm_probe
[ 7.975217] nvs_dsm nvs_dsm: dsm_remove
[ 7.975220] nvs_dsm nvs_dsm: dsm_probe done
[ 7.985095] using random self ethernet address
[ 7.992048] using random host ethernet address
[ 8.007398] rndis0: HOST MAC a6:9e:c3:c4:23:84
[ 8.007720] rndis0: MAC a6:9e:c3:c4:23:85
[ 8.009935] usb0: HOST MAC a6:9e:c3:c4:23:86
[ 8.009962] usb0: MAC a6:9e:c3:c4:23:87
[ 8.009989] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.019835] random: crng init done
[ 8.025364] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.075878] Intel(R) Wireless WiFi driver for Linux
[ 8.075882] Copyright(c) 2003- 2015 Intel Corporation
[ 8.076109] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[ 8.103987] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 8.130957] iwlwifi 0000:01:00.0: Falling back to user helper
[ 8.574615] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 8.574619] iwlwifi 0000:01:00.0: Falling back to user helper
[ 8.638043] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 8.650119] iwlwifi 0000:01:00.0: Falling back to user helper
[ 8.662571] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 8.662574] iwlwifi 0000:01:00.0: Falling back to user helper
[ 8.713027] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 8.817455] tegra-xusb 70090000.xusb: Firmware timestamp: 2017-11-03 13:36:19 UTC, Version: 50.20 release
[ 8.817500] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 8.817516] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 8.818457] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 8.818491] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 8.818722] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.818727] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.818731] usb usb1: Product: xHCI Host Controller
[ 8.818734] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 8.818737] usb usb1: SerialNumber: 70090000.xusb
[ 8.819209] hub 1-0:1.0: USB hub found
[ 8.819240] hub 1-0:1.0: 5 ports detected
[ 8.819649] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 8.819659] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 8.819730] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 8.819804] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.819807] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.819810] usb usb2: Product: xHCI Host Controller
[ 8.819813] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 8.819816] usb usb2: SerialNumber: 70090000.xusb
[ 8.820222] hub 2-0:1.0: USB hub found
[ 8.820285] hub 2-0:1.0: 4 ports detected
[ 8.827750] l4tbr0: port 1(rndis0) entered blocking state
[ 8.827755] l4tbr0: port 1(rndis0) entered disabled state
[ 8.828362] device rndis0 entered promiscuous mode
[ 8.834550] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 8.839588] l4tbr0: port 2(usb0) entered blocking state
[ 8.839594] l4tbr0: port 2(usb0) entered disabled state
[ 8.839791] device usb0 entered promiscuous mode
[ 8.845101] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.845108] l4tbr0: port 2(usb0) entered blocking state
[ 8.845111] l4tbr0: port 2(usb0) entered forwarding state
[ 8.918611] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 8.921843] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 8.922858] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 8.927068] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 8.927145] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 8.927353] usb usb2: usb_suspend_both: status 0
[ 9.011014] l4tbr0: port 2(usb0) entered disabled state
[ 9.043514] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 9.044382] thermal thermal_zone6: failed to read out thermal zone (-5)
[ 9.053803] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi
[ 9.154968] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 9.192169] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 9.192175] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.192178] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 9.192181] usb 1-2: Manufacturer: Generic
[ 9.193506] hub 1-2:1.0: USB hub found
[ 9.194612] hub 1-2:1.0: 4 ports detected
[ 9.300030] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 9.334205] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 9.334211] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.334215] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 9.334218] usb 2-1: Manufacturer: Generic
[ 9.340184] hub 2-1:1.0: USB hub found
[ 9.341610] hub 2-1:1.0: 4 ports detected
[ 9.451002] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 9.475754] usb 1-3: New USB device found, idVendor=8087, idProduct=0a2b
[ 9.475761] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 9.502989] usb 2-1: usb_suspend_both: status 0
[ 9.503274] usb usb2: usb_suspend_both: status 0
[ 9.550986] usb 1-2.3: new full-speed USB device number 4 using tegra-xusb
[ 9.580443] usb 1-2.3: New USB device found, idVendor=046d, idProduct=c52b
[ 9.580449] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.580452] usb 1-2.3: Product: USB Receiver
[ 9.580455] usb 1-2.3: Manufacturer: Logitech
[ 9.611236] usbcore: registered new interface driver btusb
[ 9.613916] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 9.614911] Bluetooth: hci0: Device revision is 16
[ 9.614914] Bluetooth: hci0: Secure boot is enabled
[ 9.614916] Bluetooth: hci0: OTP lock is enabled
[ 9.614918] Bluetooth: hci0: API lock is enabled
[ 9.614979] Bluetooth: hci0: Debug lock is disabled
[ 9.614982] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 9.625065] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 9.689245] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.689255] Bluetooth: BNEP socket layer initialized
[ 9.702730] logitech-djreceiver 0003:046D:C52B.0003: hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-70090000.xusb-2.3/input2
[ 10.032454] input: Logitech MK700 as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.2/0003:046D:C52B.0003/0003:046D:2008.0004/input/input2
[ 10.037722] logitech-hidpp-device 0003:046D:2008.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech MK700] on usb-70090000.xusb-2.3:1
[ 10.042211] input: Logitech as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.2/0003:046D:C52B.0003/0003:046D:4055.0005/input/input3
[ 10.042560] logitech-hidpp-device 0003:046D:4055.0005: input,hidraw2: USB HID v1.11 Mouse [Logitech ] on usb-70090000.xusb-2.3:2
[ 10.402238] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.403780] eth0: 0xffffff800a35c000, 00:e0:4c:68:02:a8, IRQ 404
[ 10.453855] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.582584] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.585034] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 10.585484] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 10.701101] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 10.701566] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 10.763182] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.897492] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.112192] Bluetooth: hci0: Waiting for firmware download to complete
[ 11.112881] Bluetooth: hci0: Firmware loaded in 1466772 usecs
[ 11.113033] Bluetooth: hci0: Waiting for device to boot
[ 11.124886] Bluetooth: hci0: Device booted in 11620 usecs
[ 11.133151] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 11.135930] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 11.579282] tegradc tegradc.0: blank - powerdown
[ 11.637358] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 11.637360] Extcon AUX1(HDMI) disable
[ 11.657789] tegradc tegradc.0: unblank
[ 11.669857] tegradc tegradc.0: nominal-pclk:241500000 parent:241500000 div:1.0 pclk:241500000 239085000~263235000
[ 11.669934] tegradc tegradc.0: hdmi: tmds rate:241500K prod-setting:prod_c_hdmi_150m_300m
[ 11.671007] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 11.671014] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 11.674268] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 11.674270] Extcon AUX1(HDMI) enable
[ 11.684274] tegradc tegradc.0: unblank
[ 11.684283] tegradc tegradc.1: blank - powerdown
[ 41.023499] wlan0: authenticate with 3a:56:ee:a0:78:e3
[ 41.034685] wlan0: send auth to 3a:56:ee:a0:78:e3 (try 1/3)
[ 41.040003] wlan0: authenticated
[ 41.042985] wlan0: associate with 3a:56:ee:a0:78:e3 (try 1/3)
[ 41.044798] wlan0: RX AssocResp from 3a:56:ee:a0:78:e3 (capab=0x1011 status=0 aid=4)
[ 41.046301] wlan0: associated
[ 41.058546] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 41.098130] wlan0: Limiting TX power to 23 (23 - 0) dBm as advertised by 3a:56:ee:a0:78:e3
[ 41.493780] tegradc tegradc.0: blank - powerdown
[ 41.545832] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 41.545833] Extcon AUX1(HDMI) disable
[ 41.566389] tegradc tegradc.1: blank - powerdown
[ 41.720904] tegradc tegradc.0: blank - powerdown
[ 41.720926] tegradc tegradc.0: unblank
[ 41.727232] tegradc tegradc.0: nominal-pclk:241500000 parent:241500000 div:1.0 pclk:241500000 239085000~263235000
[ 41.727332] tegradc tegradc.0: hdmi: tmds rate:241500K prod-setting:prod_c_hdmi_150m_300m
[ 41.728386] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 41.728393] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 41.731704] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 41.731706] Extcon AUX1(HDMI) enable
[ 41.744240] tegradc tegradc.0: unblank
[ 41.744616] tegradc tegradc.1: blank - powerdown
[ 45.422987] fuse init (API version 7.26)
[ 45.578054] tegradc tegradc.0: unblank
[ 45.578066] tegradc tegradc.1: blank - powerdown
[ 73.767813] wlan0: deauthenticating from 3a:56:ee:a0:78:e3 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 99.160768] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 99.173276] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 101.292001] wlan0: authenticate with 3a:56:ee:a0:78:e3
[ 101.300197] wlan0: send auth to 3a:56:ee:a0:78:e3 (try 1/3)
[ 101.301121] wlan0: authenticated
[ 101.302984] wlan0: associate with 3a:56:ee:a0:78:e3 (try 1/3)
[ 101.304736] wlan0: RX AssocResp from 3a:56:ee:a0:78:e3 (capab=0x1011 status=0 aid=4)
[ 101.308883] wlan0: associated
[ 101.308948] wlan0: Limiting TX power to 23 (23 - 0) dBm as advertised by 3a:56:ee:a0:78:e3
[ 101.324430] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
When the Nano boots, it connects to the WiFi router (this works fine). I then up the adhoc hotspot, after a while it fails with the previously mentioned timeout error message, and then it connects to the wifi router again.
