I have successfully upgraded my AGX from 4.4 DP to 4.4 production release. But one of my programs fails to run on this. So I have tried to build again from the source code and it has failed with the following error messages:
- CUDNN_CONVOLUTION_FWD_PREFER_FASTEST was not declared in this scope
- cudnnGetConvolutionForwardAlgorithm was not declared in this scope.
The source code was built without any problems on 4.4 DP.
Any helps will be appreciated. Thanks in advance!
Running ‘make’ in cudnn_samples_v8/mnistCUDNN also gives the same error.
In our new cuDNN package this week, there are some API update so it may require changes to use it.
Please check our document for the details:
You can also follow the implementation in our cudnn_samples_v8 samples.
Just try mnistCUDNN with JetPack4.4 GA and it can run correctly without issue.
$ cd /usr/src/cudnn_samples_v8/mnistCUDNN/
$ sudo make
$ ./mnistCUDNN
$ ./mnistCUDNN
Executing: mnistCUDNN
cudnnGetVersion() : 8000 , CUDNN_VERSION from cudnn.h : 8000 (8.0.0)
Host compiler version : GCC 7.5.0
There are 1 CUDA capable devices on your machine :
device 0 : sms 6 Capabilities 7.2, SmClock 905.0 Mhz, MemSize (Mb) 7762, MemClock 905.0 Mhz, Ecc=0, boardGroupID=0
Using device 0
Testing single precision
Loading binary file data/conv1.bin
Loading binary file data/conv1.bias.bin
Loading binary file data/conv2.bin
Loading binary file data/conv2.bias.bin
Loading binary file data/ip1.bin
Loading binary file data/ip1.bias.bin
Loading binary file data/ip2.bin
Loading binary file data/ip2.bias.bin
Loading image data/one_28x28.pgm
Performing forward propagation ...
Testing cudnnGetConvolutionForwardAlgorithm_v7 ...
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: -1.000000 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: -1.000000 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: -1.000000 time requiring 178432 memory
^^^^ CUDNN_STATUS_NOT_SUPPORTED for Algo 6: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_NOT_SUPPORTED for Algo 3: -1.000000 time requiring 0 memory
Testing cudnnFindConvolutionForwardAlgorithm ...
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.043040 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.045120 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.052160 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.251616 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.330464 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.421440 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: -1.000000 time requiring 1433120 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: -1.000000 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: -1.000000 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.171680 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.174976 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.180192 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.231936 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.391872 time requiring 1433120 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.437248 time requiring 4656640 memory
Resulting weights from Softmax:
0.0000000 0.9999399 0.0000000 0.0000000 0.0000561 0.0000000 0.0000012 0.0000017 0.0000010 0.0000000
Loading image data/three_28x28.pgm
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.051264 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.059488 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.060704 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.231456 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.235200 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.307488 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.142048 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.144960 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.201760 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.253824 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.392320 time requiring 1433120 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.505568 time requiring 4656640 memory
0.0000000 0.0000000 0.0000000 0.9999288 0.0000000 0.0000711 0.0000000 0.0000000 0.0000000 0.0000000
Loading image data/five_28x28.pgm
0.0000000 0.0000008 0.0000000 0.0000002 0.0000000 0.9999820 0.0000154 0.0000000 0.0000012 0.0000006
Result of classification: 1 3 5
Test passed!
Testing half precision (math in single precision)
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.051168 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.052256 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.069888 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.220064 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.231232 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.301888 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.147712 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.172768 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.214016 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.222368 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.394976 time requiring 1433120 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.533152 time requiring 4656640 memory
0.0000001 1.0000000 0.0000001 0.0000000 0.0000563 0.0000001 0.0000012 0.0000017 0.0000010 0.0000001
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.046080 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.049952 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.050208 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.188416 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.235808 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.345152 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.144288 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.146272 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.210944 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.275456 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.447456 time requiring 1433120 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.500352 time requiring 4656640 memory
0.0000000 0.0000000 0.0000000 1.0000000 0.0000000 0.0000714 0.0000000 0.0000000 0.0000000 0.0000000
0.0000000 0.0000008 0.0000000 0.0000002 0.0000000 1.0000000 0.0000154 0.0000000 0.0000012 0.0000006
Test passed!
Please let us know your result and following.
Here is a patch that we provide for darknet with cuDNNv8.
You can follow it to update your implementation:
https://raw.githubusercontent.com/AastaNV/JEP/master/script/topics/0001-fix-for-cudnn_v8.patch
Hi ,
I’ve met the same issue when building opencv 4.3. Could you share the soulution?
What the moderator, AastaLLL, posted above is the solution. Check out the differences in the source code of the cuDNN sample, mnistCUDNN. Apply those changes in your code and it will work.
