JetPack 4.4 - L4T R32.4.3 issue with darknet yolo
I am trying to compile darknet with GitHub - AlexeyAB/darknet: YOLOv4 / Scaled-YOLOv4 / YOLO - Neural Networks for Object Detection (Windows and Linux version of Darknet )
GPU=1
CUDNN=1
CUDNN_HALF=0
OPENCV=1
AVX=0
OPENMP=0
LIBSO=0
ZED_CAMERA=0
ZED_CAMERA_v2_8=0
When I try to make -j4
./src/convolutional_layer.c: In function ‘cudnn_convolutional_setup’:
./src/convolutional_layer.c:286:24: error: ‘CUDNN_CONVOLUTION_FWD_PREFER_FASTEST’ undeclared (first use in this function); did you mean ‘CUDNN_CONVOLUTION_BWD_FILTER_ALGO_3’?
int forward_algo = CUDNN_CONVOLUTION_FWD_PREFER_FASTEST;
compilation terminated due to -Wfatal-errors.
Makefile:164: recipe for target ‘obj/convolutional_layer.o’ failed
make: *** [obj/convolutional_layer.o] Error 1
My JP 4.4 GA was upgrade from JP 4.4 DP
Hi @samsonli,
Moving this to Jetson Team so that the team can help you better.
There are some API update in our new cuDNN package.
Please check this document for the details.
We are also trying to provide a patch for darknet.
Will update the information with you once the patch is ready.
The patch for darknet + cuDNN v8 is available.
Please check this comment for the detail information:
Hi @AastaLLL,
I tried to apply patch with git am
jetsonnano@jetson:~/darknet$ git am 0001-fix-for-cudnn_v8.patch
fatal: previous rebase directory .git/rebase-apply still exists but mbox given.
jetsonnano@jetson:~/darknet$ git apply 0001-fix-for-cudnn_v8.patch
error: patch failed: src/convolutional_layer.c:145
error: src/convolutional_layer.c: patch does not apply
the source to convolutional_layer.c
were there any i missed?
Thx
It looks like there is other patch applied in your source.
The patch can be used on the top of official darknet source.
By the way, please noticed that there is a updated version to limited the memory usage for Jetson device.
$ git am 0001-fix-for-cudnn_v8-limited-memory-to-default-darknet-s.patch
Hi, Samsonli
Here is the detail steps for darknet on JetPack4.4GA for your reference:
