A differential drive robot with casters exhibits significant bouncing while driving
Isaac Sim Version
4.5.0
Operating System
Windows 11
GPU Information
  • Model: NVIDIA GeForce RTX 4070 Laptop GPU
  • Driver Version: 570.124.03
Topic Description
A differential drive robot with casters exhibits significant bouncing while driving.
Detailed Description
image_1
As shown above, a differential drive robot exhibits significant bouncing while driving.
The large central wheels are the drive wheels, and no Drive is applied to the four corner casters.
When the Z-axis rotation of the caster joints is fixed, the issue no longer occurs, suggesting that the Z-axis rotation is likely the cause.
This phenomenon can be somewhat mitigated by:
  • Adjusting the mass values
  • Modifying the size or connection position of the wheels
  • Increasing the resolution (granularity) of the physics simulation
However, even slight changes can cause the issue to reappear. The resulting motion is also physically extreme and appears somewhat unnatural.
We would appreciate any insight as to whether this behavior is an inherent characteristic of Isaac Sim’s physics simulation, or if it can be resolved through parameter tuning or other means.
Hi @ochigc, Thank you for posting your issue. That is a very strange behavior. What you have tried is also what I would suggest. Can you share the script or USD you are using to create this scene?
Hi @michalin
Thank you for your reply.
I’ve attached a sample that reproduces the issue.
You can control the vehicle using the W/A/S/D keys.
sample.zip (8.1 KB)
Hi @ochigc, sorry for the long delay.
I tried out the script and was able to replicate the issue. One thing that made the problem go away for me is to increase the simulation frequency. You can do that by going to Properties of physicsScene prim, then changing the Time Steps Per Second. Anything above 120 worked for me.
Another thing that also worked is to explicitly set the mass of the caster prims. They were Auto-computed which means that using density and volume to calculate it. If the mass ends up being very small, then that rigid body might end up spinning very fast. The simulator is bad at handling high speed motions with a coarse time-stepping. So you want either faster time stepping, or larger inertia to avoid this issue.
Hope that helps!
Hi @michalin
Thank you for your response.
I agree with your point that the simulation step count and mass settings are important, and it aligns with my own findings.
While I’ve confirmed that the issue can be resolved in simple models like the sample, in practice I’m using more complex shapes, and although the jumping can be suppressed, it hasn’t been completely eliminated.
I suspect the issue lies in the imbalance of mass, so I will continue investigating.
I appreciate your support.
Thank you very much.
