A question about image quality degradation caused by deepstream streammux scaling of images
• Hardware Platform (Jetson / GPU):Jetson
• DeepStream Version:6.2
I currently have 4 RTSP streams with image sizes of [1920x1080,1920x1080,1280x960,640x320],They are connected to the same streammux, and I have set the width and height of nvstreammux to 640x640 (I know that the DeepStream SDK FAQ states that nvstreammux should be set to the resolution of the RTSP stream, but my RTSP stream resolution is not consistent at this time).
In the probe callback function of fakesink, I use the following code
cv::Mat img_dest;
cv::Mat img_rgba = cv::Mat(pipeline_h, pipeline_w, CV_8UC4, nvbuf_surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0], nvbuf_surface->surfaceList[frame_meta->batch_id].pitch);
cv::cvtColor(img_rgba, img_dest, cv::COLOR_RGBA2RGB);
cv::resize(img_dest, img_dest, cv::Size(frame_meta->source_frame_width, frame_meta->source_frame_height), 0, 0, cv::INTER_CUBIC);
How should I handle restoring the image, but the resulting image quality is very low?
The pipeline structure behind my nvinfer is
GstElement *nvvidconv = NULL;
nvvidconv = gst_element_factory_make("nvvideoconvert", "convert");
g_object_set(G_OBJECT(nvvidconv), "nvbuf-memory-type", 4, NULL);
GstElement *nvvidconv_cap = NULL;
nvvidconv_cap = gst_element_factory_make("capsfilter", "nvvidconv_cap");
GstCaps *caps = NULL;
caps = gst_caps_from_string("video/x-raw(memory:NVMM), format=RGBA");
g_object_set(G_OBJECT(nvvidconv_cap), "caps", caps, NULL);
GstElement *sink = NULL;
sink = gst_element_factory_make("fakesink", NULL);
g_object_set(G_OBJECT(sink), "sync", 0, NULL);
GstElement *queue1 = gst_element_factory_make("queue", "queue1");
GstElement *queue2 = gst_element_factory_make("queue", "queue2");
GstElement *queue3 = gst_element_factory_make("queue", "queue3");
gst_bin_add_many(GST_BIN(bin), pgie, queue1, nvvidconv, queue2, nvvidconv_cap, queue3, sink, NULL);
gst_element_link_many(pgie, queue1, nvvidconv, queue2, nvvidconv_cap, queue3, sink, NULL);
The quality cannot be guaranteed. What you are doing is equivalent to reducing the video resolution to 640x640 first and then enlarging it, there will be data loss in this process.
@yuweiw
If the resolution of my RTSP stream is inconsistent, such as [1920x1080,1920x1080,1280x960,640x320], how should I set the width and height of my streammux?
We suggest that you use the resolution that is in the majority of your RTSP sources. For your scenario, you can use 1920x1080.
