A100 KVM passtrough
I need to change the GPU mode from compute to graphics so I can passtrough it to a KVM VM.
As you can see the GPU is recognized as: 3D Controller, which won’t allow the driver to be installed on the VM.
65:00.0 3D controller [0302]: NVIDIA Corporation GA100 [A100 SXM4 80GB] [10de:20b2] (rev a1)
The GPU should be set as: VGA compatible adapter.
I usually use NVIDIA Display Mode Selector Tool to change the mode but the tool doesn’t not support A100 models.
Would you be so kind as to tell me a way/tool/command to change the GPU mode to graphics?
