Under WIN10 enviroment:
Cuda :cuda_9.0.176_win10
cudnn : cudnn-9.0-windows10-x64-v7.5.0.56
I got the .onnx model from python3.5 ,pytorch1.0(make some modify about export becuase upsample operation will cause fault, link :GitHub - NVIDIA/retinanet-examples: Fast and accurate object detection with end-to-end GPU optimization).
I run the this onnx molde on VS2015 tensorRT 5.0.4.3, and get the right result, it works well.
ONNX IR version: 0.0.3
Opset version: 9
Producer name: pytorch
Producer version: 0.4
Domain:
Model version: 0
Doc string:
But ,when i try save the model as follow:
void onnxToTRTModel(const std::string& modelFile,
unsigned int maxBatchSize,
IHostMemory*& trtModelStream)
int verbosity = (int) nvinfer1::ILogger::Severity::kWARNING;
IBuilder* builder = createInferBuilder(gLogger);
nvinfer1::INetworkDefinition* network = builder->createNetwork();
auto parser = nvonnxparser::createParser(*network, gLogger);
if (!parser->parseFromFile(locateFile(modelFile, directories).c_str(), verbosity))
string msg(“failed to parse onnx file”);
gLogger.log(nvinfer1::ILogger::Severity::kERROR, msg.c_str());
exit(EXIT_FAILURE);
builder->setMaxBatchSize(maxBatchSize);
builder->setMaxWorkspaceSize(1 << 20);
samplesCommon::enableDLA(builder, gUseDLACore);
ICudaEngine* engine = builder->buildCudaEngine(*network);
assert(engine);
parser->destroy();
trtModelStream = engine->serialize();
engine->destroy();
network->destroy();
builder->destroy();
/* save trtModelStream as .engine */
std::fstream file;
file.open("./serialize_engine_output.engine", ios::binary | ios::out);
file.write((const char*)trtModelStream->data(), trtModelStream->size());
file.close();
and try load this model as follow:
IRuntime* runtime = createInferRuntime(gLogger);
std::fstream file;
file.open(“./serialize_engine_output.engine”, ios::binary | ios::in);
file.seekg(0, ios::end);
int length_ = file.tellg();
file.seekg(0, ios::beg);
std::unique_ptr<char>data_(new char[length_]);
file.read(data_.get(), length_);
file.close();
ICudaEngine* engine = runtime->deserializeCudaEngine(data_.get(), length_, nullptr);
Then ,the fualt like the follow:
ERROR: 00007FFBC2DCF2D0ResizeNearest version 001 namespace
ERROR: Cannot deserialize plugin ResizeNearest
