Created a binary file using tensorRT_optimization tool with onnx file
When initialize using dwDNN_initializeTensorRTFromFileNew got error messages below:
getPluginCreator could not find plugin ResizeNearest version 001 namespace
Cannot deserialize plugin ResizeNearest
The same onnx file works for drive software 9 using the corresponding tools and APIs. We found that this function is actually in the libnvonnxparser.so.0.1.0 on drive software 10.
Thank you, we will try to cross-compile the TRT sample on to Xavier and verify that the libraries loaded are all present when we load our software as well.
From GTC we got a temporary direction of using tensorRT libraries directly on DriveOS 10, and we’ll check with the TRT sample if we’re able to serialize and de-serialize the onnx model on Xavier
