About decode ,display and encode memory copy outof GPU
Hi all,
I receive network streams on tx1 or tx2 ,and want to decode stream ,display data. but i dont want copy out data from GPU to CPU. can I send data to the CUDA display after decode directly ?
I saw samples that decode frame to CPU Memory ,or encode CPU Memory .Can the data go through the CPU?
thanks.
We have gstreamer and tegra_multimedia_api, please check which is better for your cases:
https://developer.nvidia.com/embedded/dlc/l4t-documentation-28-1
https://developer.nvidia.com/embedded/dlc/l4t-accelerated-gstreamer-guide-28-1
About tegra_multimedia_api, I get the NvBuffer(basis of the v4l2_buffer structure) ,but it isn’t look like GPU memory. I want to know the tegra_multimedia_api that can support decode to GPU buffer, but not CPU buffer.
Hi he-lixiang,
NvBuffer is HW-accessible memory, not CPU memory. You can refer to the sample tegra_multimedia_api/samples/02_video_dec_cuda
thanks for your replay.
I read the sample tegra_multimedia_api/samples/02_video_dec_cuda in detail. and have three questions.
(1).
in the function read_decoder_input_nalu, it read the data from file stream and memcopy to the NvBuffer( HW-accessible memory), and “memcpy” is the function that to achieve the CPU memory to the HW-accessible memory?
fllow code:
char *buffer_ptr = (char *) buffer->planes[0].data; //NvBuffer * buffer
memcpy(buffer_ptr, stream_ptr, 4);
(2).
Create EGLImage from dmabuf fd, is just package the NvBuffer fd and no memory copy?
// Create EGLImage from dmabuf fd
ctx->egl_image = NvEGLImageFromFd(ctx->egl_display, buffer->planes[0].fd);
(3).how to convert eglimage to Nvbuffer?
I will use opengl to process the decoded Nvbuffer and then get new EGLImage ,convert eglimage to Nvbuffer, finally encode and record the Nvbuffer by video_enc_cuda .
This is to copy compressed H264 stream to input buffers. Loading is light.
It is not memory copy.
This may not be supported. You can do post-processing via CUDA, or create NvBuffer and call NvEGLImageFromFd() to get eglimage.
thanks .
